Your Home Theater ULF Score - Page 95 - AVS | Home Theater Discussions And Reviews
 150Likes
post #2821 of 2830 Old 01-18-2015, 01:41 PM
Pain Infliction's Avatar
Quoted: 435 Post(s)
Liked: 252
Originally Posted by Brian Fineberg View Post
Cool
How do you tune a port? Those are waaaaay to big for my place
You don't tune the port. Port tune is what the sub is supposed to play down to before roll off begins. Port tune is made up of driver parameters, box size, port size, and amplification. Simulations can help you decide on your dimensions and amplification.
Pain Infliction is online now
post #2822 of 2830 Old 01-18-2015, 02:30 PM - Thread Starter
dominguez1's Avatar
Quoted: 155 Post(s)
Liked: 220
Originally Posted by jbrown15 View Post
I thought the data-bass 18.1 numbers are for the passive unit using Josh's amp?
Hmmm, good point. I'll look at db to see how many volts it was given...I'm guessing it wasn't that much relatively speaking, meaning the speaker power amp would have enough juice to compensate for the small box.
dominguez1 is online now
post #2823 of 2830 Old 01-18-2015, 03:29 PM
raynist's Avatar
Quoted: 310 Post(s)
Liked: 388
Originally Posted by dominguez1 View Post
Time to estimate a couple of more subs' ULF performance:
Triax T-18
Reaction Audio PS-18x
Similar to the Chase Subs, the T-18 run a variant of the Eminence 18. Perhaps a starting point would be 3 Chase 18.1 (or 1.5 18.2s)?
For the PS-18X, perhaps similar performance to the UXL?
Thoughts? Sounds pretty reasonable to me.
Supposedly the new T-18 has a bit more output than the original triax but I haven't seen any data posted yet. Someone mentioned they were told 1.5 more db's across the board. According to your estimates it is less powerful. I thought I heard Ricci was going to get one to test.
raynist is offline
post #2824 of 2830 Old 01-18-2015, 04:14 PM - Thread Starter
dominguez1's Avatar
Quoted: 155 Post(s)
Liked: 220
I would agree that it has more overall output, but my guess that's more in the bass and upper bass ranges given what we've seen of the chase 18in eminence. In fact, it probably has some MASSIVE output in the upper ranges.
But, it wouldn't surprise me if this does have less output in the ULF range than the prior triax. The box is very small for 3 18's and the eminence driver in the chase wasn't a bottom feeder by any means.
Of course, we're comparing estimates to estimates; so really hard to say.
post #2825 of 2830 Old Today, 01:01 PM
Sibuna's Avatar
Quoted: 291 Post(s)
Liked: 353
I think I did this correctly
There is however no entry for the SI24 in a 15 CUFT sealed box so I just used the IB entry,
Sibuna is offline
post #2826 of 2830 Unread Today, 03:55 PM
Alan P's Avatar
Quoted: 1214 Post(s)
Liked: 613
A thing of beauty Sibuna!
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC64ii, SUR: Polk LS F/X x 4, SUB: PSA T-18 x 2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #2827 of 2830 Unread Today, 05:12 PM
Sibuna's Avatar
Quoted: 291 Post(s)
Liked: 353
Sibuna is offline
post #2828 of 2830 Unread Today, 07:16 PM - Thread Starter
dominguez1's Avatar
Quoted: 155 Post(s)
Liked: 220
That's the correct one to use. I'm not sure why I have IB there in the name. It should just be the driver name...I'll fix in the next update. I believe @MKtheater put that sim together. He uses .707 for the box, which I believe is the optimal size? Not a sim person, so not sure what that means...
Solid score for 3 sealed subs! That nearfield 24 must be punishing...does your couch shake for the really low stuff (12.5hz and below)?
If you post your FR down to 5hz, I'll add you to the club and give you the 5hz ULF card badge...
post #2829 of 2830 Unread Today, 07:33 PM - Thread Starter
dominguez1's Avatar
Quoted: 155 Post(s)
Liked: 220
Triax T-18
Going once....twice....
Name:	T-18 and PS-18X.png
post #2830 of 2830 Unread Today, 10:22 PM
MKtheater's Avatar
Quoted: 440 Post(s)
Liked: 555
You have been pretty good so far.
AVR-Yamaha A830
amps-5 Adcom 555 in 850 watt monoblock mode
sub amp-Sanway FP14K
LCR-Dual stacked BFM DR-250's
Surrounds- Dual stacked BFM W10's
subs-12 SI 18's ported 6hz.
MKtheater is online now
ae ib15 subwoofer , Bic Pl 200 Acoustech Platinum Series Subwoofer , Bowers Wilkins Asw 610 , Danley Sound Labs Dts 10 , Elemental Designs A7s 450 , Epik Empire , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer , Klipsch Sw 311 , Seaton Sound Submersive H P , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Velodyne Eq Max 15 15 Subwoofer
