Received Bic F-12 — Has a rattle like a screw is loose inside. Return it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-28-2013, 05:06 AM - Thread Starter
kkirsche's Avatar
Hey everyone,
I ordered the BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer from Amazon and received it yesterday (first item of my new home theater set so not able to test the actual sound of it). I took it out of the box and noticed that if you tilt it from side to side there is something that rattles inside of it like a screw or something that came undone and is sliding across the laminate inside. I was wondering if this is normal or something that should be replaced.
This is exactly what I am hearing:
http://www.youtube.com/watch?v=uopTfR5p7BY
kkirsche is offline
post #2 of 4 Old 08-28-2013, 07:12 AM
MitchFlorida's Avatar
Liked: 24
I doubt if it's normal.
kkirsche likes this.
MitchFlorida is offline
post #3 of 4 Old 08-28-2013, 07:33 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 300
It's not difficult to take off the plate amp and have a peek inside.
tsaville is offline
post #4 of 4 Old 08-28-2013, 08:29 AM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1063
+1
Reefdvr27 is offline
Bic America , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
