Help with Powered Subwoofer decision - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-29-2013, 03:02 PM - Thread Starter
Dean1208's Avatar
Hello, I am new to the community. I recently had a Velodyne DLS4000 but since my move it no longer works. My question is this, I am debating on the Bic pl200 or Klipsch RW12d times 2 or a single Hsu Vtf3 mk4 or SVS pb12 nsd. Currently for my setup I have a room that is about 24 x 20, Panasonic TCP60St60 display, Mirage Omni Pristige speakers with Onkyo tx sr607 AV source and Sony Bdp-S580 player. I only watch movies and would extremely rarely listen to music on this setup. I am definitely not an audiophile by any means just a guy who googles a lot and wants to get the best bang for sound in my somewhat home theater room. Thanks.
Dean1208 is offline
post #2 of 15 Old 08-29-2013, 11:02 PM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
Dual RW-12D if you want to go with duals, which I think you must, considering your requirement.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 15 Old 08-29-2013, 11:47 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1352
You might be able to get two PA-150s for $800 shipped, maybe. That would get you an incredible amount of output. Call up the guys at Acousticsounddesign and ask them if they would be willing to send you a pair of those PA-150s for $800 shipped. They might go for that, they are definitely willing to bargain. The only problem is they will make you want to upgrade your speakers.
shadyJ is offline
post #4 of 15 Old 08-30-2013, 07:09 AM - Thread Starter
Dean1208's Avatar
The PA150's look great, I found them on Overstock for 797 shipping included for two of them, but saw that a few years ago around May 12 they were dropped to 299 at Sounddistributors. I was also thinking that whatever sub/s I do get I probably should get the Aurelex Gramma acoustic thingy for them. You don't think that 2 15's would be too much? I don't usually crank it, but usually listen at a good level that I can feel it and not bother my family.
Dean1208 is offline
post #5 of 15 Old 08-30-2013, 07:15 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
There are mixed reviews about the gramma. dual subs are preferred as a single can not effictively smooth room modes and standing waves. Duals will offer a smoother response and sound better...also more headroom is a good thing. 2 subs do not have to work as hard to achieve the same spl as a single, so the sound quality will be better.
basshead81 is offline
post #6 of 15 Old 08-30-2013, 07:23 AM
Quoted: 330 Post(s)
Liked: 287
+1 ..... OP, think of it if you were to lug JTR OS up the stairs all by yourself. Two guys will share the load 50-50, 4 guys will cut the load by 75% wink.gif
post #7 of 15 Old 08-30-2013, 08:34 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 300
Are you planning to upgrade your speakers anytime soon? Nothing against your Mirage speakers (I have owned Nanosat and OMD speakers), but I don't see the point of spending a lot of money on subs to pair with micro-satellite speakers.
With that said, you could get dual Polk PSW505 12" subs for around $400. I use one for my secondary HT (only paid 180 for it), and it's decent for the price.
tsaville is offline
post #8 of 15 Old 08-30-2013, 08:52 AM
enricoclaudio's Avatar
Quoted: 1510 Post(s)
Liked: 1658
Nothing bad with the speakers you have, but any of the subwoofers you listed could be overkill with those satellite speakers. Does not make any sense to me to put money in two subwoofers to fill that room when your speakers are not capable to do so. Now if your plan is to upgrade your speakers to bookshelf or towers, then two subwoofers is the way to go in that room.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #9 of 15 Old 08-30-2013, 09:43 AM
emcdade's Avatar
Quoted: 147 Post(s)
Liked: 145
Recommendations to mate 2x 15", 87 pound subwoofers with a micro speaker system...
I have now seen it all here at AVS
emcdade is offline
post #10 of 15 Old 08-30-2013, 09:47 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
Hey this is the subwoofer section(basshead land)....we worry about main speakers after the subs are purchased. tongue.gif
post #11 of 15 Old 08-30-2013, 10:11 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
You need to contact Sounddistributors or Acoustic Sound Design and ask what deal they would give you for two. Going rate on the make them an offer on Acoustic Sound Design is apparently $349. Maybe they'd give you a deal on two. smile.gif
However, I would agree with some of the others. This seems excessive to go with the micro satellites, unless you plan on upgrading your front speakers later on to full sized bookshelves/monitors.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #12 of 15 Old 08-30-2013, 10:34 AM
emcdade's Avatar
Quoted: 147 Post(s)
Liked: 145
Something that may be more important than low freq. extension, which has gone unmentioned, is the ability of your subwoofer to perform well up over 100-120hz where the tiny satellites should be crossed over.
Does anyone have suggestions in that regard? I would think, since your sub will be more localizable at that frequency, you should find a sub you don't mind placing up front with your front speakers to tie the front soundstage together.
emcdade is offline
post #13 of 15 Old 08-30-2013, 11:33 AM
shadyJ's Avatar
Liked: 1352
Many (but not all) of the subs discussed here have pretty flat performance to well over 200 Hz. The PA-150 in particular has excellent upper bass performance, even surpassing that of the $2k SVS PB13.
shadyJ is offline
post #14 of 15 Old 08-30-2013, 03:11 PM - Thread Starter
Dean1208's Avatar
Hi, so to answer a few questions. I don't really plan on upgrading this setup because I will be retiring from the military in 3 years and have no idea where my next job will take me so I was hoping to use this setup for the time being. The two polks sound fine to me also if they are able to produce good sound for the money. Also I was hoping to place them up front on either side of the set up
Dean1208 is offline
post #15 of 15 Old 08-30-2013, 05:09 PM
Quoted: 330 Post(s)
Liked: 287
Or so you thought........ Multiple subs are the only speakers that break the symmetry. Their prowess is best exploited when placed asymmetrically!!! wink.gif
