Tutorial: Dual sub integration using the MiniDSP - Page 8 - AVS Forum
Old 09-21-2014, 05:52 PM
vinodk's Avatar
Quoted: 24 Post(s)
Not at all familiar with PEQ export function as I have not used REW before therefore not sure how steep the learning curve is for REW. Antimode is automated sub EQ.
Vinod
vinodk is offline
Old 09-21-2014, 06:53 PM
RickD1225's Avatar
Quoted: 16 Post(s)
Liked: 71
There is no need to run both.
RickD1225 is offline
Old 09-21-2014, 08:37 PM
vinodk's Avatar
Quoted: 24 Post(s)
Don't want to run both as it might muck up the whole thing. Just looking for a more time efficient setup as I already have 8033. If there is a learning curve to using REW & exporting PEQ's then its probably easier for me to just use 8033 for EQ & use miniDSP 2x4 for level & delay. In that case wondering if it is ok to place the 8033 between AVR sub out & miniDSP unit.
Vinod
vinodk is offline
Old 09-21-2014, 09:44 PM
HDgaming42's Avatar
Quoted: 150 Post(s)
Isn't there a learning curve to everything? Take a look over in this thread, post #275 and read the REW guide. That might give you an idea of whether REW is something you want to pursue or not. If you can get to the point of running a proper sweep, REW will handle creating up to 6 PEQs per sub to match your target curve (not that you necessarily want to approach it like that).
Can't comment on whether chaining your 8033 and the miniDSP is advisable or not, though I struggle to see why this would be problem.
HDgaming42 is online now
Old 11-26-2014, 03:45 PM
Chris Young's Avatar
Hi All,
I've been reading here and in some of the tutorial links in this thread and have come up with a question.
I'm thinking of getting the Mini DSP 2X4 for use with my 4 sub-woofers. I have 2 sub-woofers outs on my Denon 4311Ci. I also use Audyssey Pro-Kit in this setup. Will the DSP benefit in more adjustment in the house curve if wanted or needed or am I wasting money and time when Audyssey Pro offers a curve setting adjustment in it's software. There are limitations to it is why I'm asking.
Thank you
Chris
"The Boy has no patients" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
Work is what we do to pay for our HT.
Chris Young is offline
Old 11-26-2014, 04:42 PM
Alan P's Avatar
Quoted: 1136 Post(s)
Liked: 578
Have you measured your in-room response? Until you do, you won't know if the MiniDSP is needed or not.
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC64ii, SUR: Polk LS F/X x 4, SUB: PSA T-18 x 2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
