Modestly priced subwoofer for huge space - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2013, 09:43 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
I don't remember where I read it exactly, but it was explained in a post by one of the staff over at Audioholics (can't remember who) that in order to get considered for product of the year, you have to submit your product for nomination. But hey, if you think I am just making up stuff, go shoot Gene DellaSala an email asking him about how products of the year are decided and how many entries were submitted for their 2012 subwoofers. It's a very simple matter to prove me wrong, it would only take 5 minutes.
shadyJ is offline
Old 09-03-2013, 09:50 AM
shadyJ's Avatar
Liked: 1350
Originally Posted by NewHTbuyer View Post
The -3 dB spec on your speakers is 85Hz. You usually want to set your crossover above this number, so for you 100 Hz would probably work.
It turns out even 100 would be too low; the f3 isn't so good as 85 Hz. Probably 120 would be more appropriate.
shadyJ is offline
Old 09-03-2013, 09:58 AM
NewHTbuyer's Avatar
Liked: 41
Thanks. Measurements are definitely better than manufacturer's specs. If he sets it at 120, that argues even more for placing the subs up front so you don't localize them.
NewHTbuyer is offline
Old 09-03-2013, 11:23 AM - Thread Starter
RockDawg's Avatar
Quoted: 59 Post(s)
Liked: 33
What is f3?
RockDawg is offline
Old 09-03-2013, 11:32 AM
shadyJ's Avatar
Liked: 1350
The f3 is in the low end roll off where the frequency response is 3 dB down, in other words it's where the speaker starts running out of gas in the bass region.
shadyJ is offline
Old 09-03-2013, 01:18 PM - Thread Starter
RockDawg's Avatar
Quoted: 59 Post(s)
Liked: 33
Does that still leave me OK or should I deal with that somehow? What about using my current Dayton 10" sub as a midbass (I thought it was 12", but that was wrong) along with the VF15? I'd imagine I would need to filter out it's bottom end, but might I be able to use that with good results?
RockDawg is offline
Old 09-03-2013, 02:05 PM
tenderchkn's Avatar
Just cross your mains over at 100hz. It's not going to be a huge difference compared to 80hz in terms of being able to localize your sub, especially if you get duals.
tenderchkn is offline
Old 09-03-2013, 02:40 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5282
this...also you can cascade both the avr and sub cross at 100hz and his will make the roll off steeper past the cross point. It actually works very well. I believe Bill Fitzmaurice recomends it, especially on systems that utilize small driver main speakers
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 09-03-2013, 04:30 PM - Thread Starter
RockDawg's Avatar
Quoted: 59 Post(s)
Liked: 33
It turns out my mains are actually Klipsch RB-51's, not 41's like I posted. I remember considering both when I bought them and I think because my center channel is the Klipsch RC-41 II, I was thinking they were all 4". Boy, do I feel stupid. At least that turns out to be good news and, while I can't find a FR graph for them, they must go a fair bit lower than the 41's (Klipsch says down to 50Hz). So that should alleviate my concerns.
I guess I am going to go with two of the VH15's then. I also just noticed that Power Sound Audio is located about 15 minutes away from me. Maybe they will give some kind of discount if I pick them up instead of them shipping them.
Anyway, I now need to read up on how to set them up properly. If you have any good links regarding set up, please post them. I'd appreciate it.
Thanks everyone for all your help and advice.
RockDawg is offline
Old 09-03-2013, 04:37 PM
tenderchkn's Avatar
In that case, you can cross the fronts at 80 and the center at 100.
This is pretty much a no brainer reason to go PSA. I'm sure that you'll get a discount for pick up and imagine how easy it would be to get support.
Old 09-03-2013, 04:51 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I believe Tom would discount them to you if you can pick them up to offset the state tax you'll have to pay on them. Anyone out of state doesn't pay the tax.
jbrown15 is offline
Old 09-13-2013, 11:49 PM - Thread Starter
RockDawg's Avatar
Quoted: 59 Post(s)
Liked: 33
I ended up buying one XV-15. I was going to get two, but I just found out my dog needs some surgery and that takes priority. I might add a second one later on.
So far all I can say is that this thing is awesome! Keep in mind I was using a Dayton 10" until now and I don't have much experience with subs, but this thing just blows the Dayton away. I know that's to be expected, but I didn't expect there to be this large of a difference. Especially in my huge space. While watching movies, there are rumbles and pulses that you can feel in your chest. And I don't even have it calibrated yet. Just plugged it in, turned the gain and crossover to half and turned it on. Thanks so much to all of you for your feedback and advice. I really appreciate it.
No buyer's remorse here. Definitely $800 well spent! Can't wait to get it calibrated with my receiver.
RockDawg is offline
Old 09-14-2013, 06:46 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Turn the crossover all the way up on the sub and set the avr to crossover at 80hz. That way you do not have two crossovers filtering. That is a nice sub and enjoy!
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 09-14-2013, 09:58 AM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5282
There is nothing wrong with using 2 crossovers for filtering. Many AVR's have a shallow roll off on the LPF(12db) that allows alot of higher frequencies to pass through, which can lead to localization. Cascading both crossovers will filter out those higher frequencies and imo the sub sounds better. You can actually get away with crossing up around 100hz with no localizatiin issues. I have measured and tested this method and it works well on contrary to what the internet says. Bill Fitzmaurice is who I got the tip from. smile.gif
Old 09-14-2013, 02:06 PM
Quoted: 978 Post(s)
Liked: 506
I personally do not want 100Hz going to the sub. All of my speakers can handle that without issue. I feel there is no reason for the sub to have 100Hz going to it.
Old 09-14-2013, 02:47 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5282
my POINT is even with your crossover in the AVR set to 80hz your sub is getting frequencies clear out to 120-150hz. If you cascade the crossovers and set the sub @ 80 and AVR @ 80, you will notice a big difference and not much will pass thru. I previously crossed my subs at 60hz until I seen Bill F. mention to try cascading crossovers. Now I have the subs set back to 80hz, I get plenty of mid bass slam with music and no low voice rumbles watching TV. Where previously only using the AVR crossover I could not find a sweet spot for both sources.
Old 09-14-2013, 03:23 PM
Bill Fitzmaurice's Avatar
Liked: 4682
+1, If it works better for you that's what matters, not blind adherence to a protocol that isn't even necessarily a technically sound one.
Bill Fitzmaurice is offline
