Look for a Dual Subwoofer Setup, Budget 6000 Total - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 08-31-2013, 02:05 PM - Thread Starter
Bassfeen's Avatar
Quoted: 113 Post(s)
Hi All,
Iv not posted on here for some time, with the help of some guys here I already did purchase 2 Seaton subwoofer over 2 years ago. I am ready for 2 more subwoofers to my setup. I am looking for something that will go down very low with Finesse and accuracy both excelling at movies and sometimes music. At the moment my dual Seaton subs are set under the X32 config on the Onkyo processor.
My current setup is
Danley SH50 Left and right with SH69 as centre. Then im using a SH100 for my Surrounds.
So far I am looking at the Legacy Line of subwoofer either the XD Extreme or the Goliath
any more suggestion, has anyone got experiences with the Seaton and the Legacy subs?
Bassfeen is offline
post #2 of 20 Old 08-31-2013, 02:12 PM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Dual JTR OS LFU
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 20 Old 08-31-2013, 02:50 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Danley and JTR have some killer subwoofers. If you need something that has higher WAF, look at Funk, their sins look nice and also have great performance. But to really outdo your seatons, you will need something colossal, like the Orbit Shifter LFU. You might just want to add two more seatons though, that will be easiest to dial in and integrate with your existing subs.
shadyJ is offline
post #4 of 20 Old 08-31-2013, 06:13 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
A couple more seatons, PSA Triax or Quad FV15HP.
Is DIY an option ? a pair of sealed TC LMS 5400 would be wicked.
qguy is offline
post #5 of 20 Old 08-31-2013, 06:42 PM
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
For 6k and what you describe what you want, a pair of jtr s2's would be your best option commercially, IMO. I heard these the other day, and they were very impressive.
dominguez1 is offline
post #6 of 20 Old 08-31-2013, 09:14 PM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
Do you have the 1000 watt Submersives? If so you could upgrade by trading in old amps and getting the new amps and get 2 slave subwoofers. This would be a significant upgrade IMO going from four 15" on 2000 watts to eight 15" on 9600 watts. Also have a new dsp setting to lift the low end. This would be a nice upgrade IMO and would save some $$.
http://www.seaton-sound-forum.com/post/ubersive-masterslave-option-6453864?&trail=20
Luke Kamp is offline
post #7 of 20 Old 09-01-2013, 12:15 PM - Thread Starter
Bassfeen's Avatar
Quoted: 113 Post(s)
I need the 220-240 Volt operation and have been waiting for some time. Was looking at other companies. Need something Fast but very clean down low.
Bassfeen is offline
post #8 of 20 Old 09-01-2013, 12:17 PM
Decadent_Spectre's Avatar
Quoted: 322 Post(s)
Liked: 144
What frequencies do you feel are lacking with the Seaton subs? Do you want more impact and slam?
Decadent_Spectre is offline
post #9 of 20 Old 09-01-2013, 03:07 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
For <20 hz yes......................
For >20 hz the OS's have cleanest output I've heard.............and has +6 db's more output than S2.
I own an S2............if I could've fit dual OS's.................I'd be a happier owner biggrin.gif
doublewing11 is offline
post #10 of 20 Old 09-02-2013, 03:02 AM - Thread Starter
Bassfeen's Avatar
Quoted: 113 Post(s)
I am looking for more low end rumble and yes more impact in the room. Its a large room concrete floors. The JTRs seems massive.
Bassfeen is offline
post #11 of 20 Old 09-02-2013, 04:03 AM
Quoted: 311 Post(s)
Liked: 273
How low do you want? JTR OS would have useful output down to 10Hz. How loud below 20Hz depends on your room gain and placement. The above 20Hz impact; JTR OS is a force to reckon with. Only trouble is the size. If you can manage to fit in your listening space; it's worth every penny.
post #12 of 20 Old 09-02-2013, 04:50 AM
Quoted: 322 Post(s)
Liked: 144
Often people assume the low end rumble they seek is at 5Hz when in most cases it is the massive output in the 30-60Hz octave which is interpreted as being powerful rumble. If you can narrow down the frequency range that needs to be addressed it would be easier to provide a suggestion.
That said rumble and impact require different approaches, the rumble that most people think of is from 30-60Hz and the impact is usually from 60-180Hz. Unless you specifically need output below 30-40Hz then a pro style horn such as the JTR OS Pro or Void Psyco X or Bassmaxx B Zero would be very strong choices above 40Hz, if budget is not a concern I would suggest the Danley BC series for above 40Hz. If below 40Hz is needed then you would need to add more Seaton Submersives or JTR S1/2s assuming you want a smallish box and want to get to 5Hz. If below 15Hz is of no consequence and a larger box can be accommodated you could try to get some Gjallerhorns made for 15-30Hz as these are very powerful in the 15-30Hz octave. It really depends on what your trying to achieve as different tools are required for different problems.
SaviorMachine likes this.
post #13 of 20 Old 09-02-2013, 06:28 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5243
I second Luke Kamps suggestion. Upgrade the SubM amps and add a pair of slave units. Doubling displacement and quadrupling power should yield some solid gains.
edit* I see the hpi version not yet available for 220volt.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #14 of 20 Old 09-02-2013, 06:34 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
This makes the most sense to me as well (doing what Luke suggests).
ack_bk is online now
post #15 of 20 Old 09-02-2013, 11:32 AM
Quoted: 229 Post(s)
Liked: 938
I'm happy with my S2, but prefer dual OS's for sure.............................output above 20 hz is INSANE!
As mentioned, size is the only issue with OS............. Lord only knows how hard I tried to fit dual OS's in my front facade wall.
IMHO, OS is the BEST sub I've heard for the money!
post #16 of 20 Old 09-02-2013, 12:53 PM - Thread Starter
Bassfeen's Avatar
Quoted: 113 Post(s)
I will look at getting another 2 Seaton Subs for the time being, till they have the amplifier upgrade option. The JTR are just too big it seems more suitable for a large commercial room. Just a quick questions are the drivers the same in the HP version vs the older Seatons?
Bassfeen is offline
post #17 of 20 Old 09-02-2013, 08:26 PM
audioguy's Avatar
Quoted: 1924 Post(s)
Liked: 1242
The drivers are the same.
audioguy is online now
post #18 of 20 Old 09-03-2013, 03:49 AM
rafparedis's Avatar
The international amp (HPi+) is available. You can call mark or check the seaton forum for more information. It also enables the master/slave option where you drive two cabinets from one amp
rafparedis is offline
post #19 of 20 Old 09-03-2013, 11:08 PM - Thread Starter
Bassfeen's Avatar
Quoted: 113 Post(s)
I live outside the USA so its not always easy to call at the right time saying that I know from experience its hard to get hold of Mark, even by emails. However I have left him a private message on this forum and on his own website.
Bassfeen is offline
post #20 of 20 Old 09-04-2013, 04:01 AM
rafparedis's Avatar
Also international customer smile.gif,
when ordering my original submersive it was indeed very difficult to get a hold of Mark. This time though when mailing to sales@seatonsound.net I got a really fast reply. Mark got some help there so I think mailing at that address might give you the quickest response.
