Connecting a Sub with Line-In - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-03-2013, 05:19 PM - Thread Starter
mijotter's Avatar
Liked: 59
Was wondering what cable I need to connect my sub Line in to my AVR and where on the AVR it connects to.
Sub - Rythmik LV12R
AVR - Pioneer 1222
mijotter is offline
post #2 of 12 Old 09-03-2013, 05:43 PM
Kal Rubinson's Avatar
Quoted: 761 Post(s)
Liked: 526
Any decent cable with an RCA connector on each end.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 12 Old 09-03-2013, 05:59 PM
BeeMan458's Avatar
Liked: 813
On your AVR, you have two "subwoofer" out connections. See page 18 of the manual. It's the two connections in the white section, in the middle of the below image.
Any decent subwoofer cable of an appropriate length will connect your AVR and subwoofer.
I prefer "Mediabridge" subwoofer cables.
BeeMan458 is offline
post #4 of 12 Old 09-03-2013, 06:19 PM - Thread Starter
mijotter's Avatar
Liked: 59
Awesome. For the LINE in. Is there cable a "Y" at one end for the red and white then a singular input to go in to one of the sub outs on the AVR?
mijotter is offline
post #5 of 12 Old 09-03-2013, 07:24 PM
BeeMan458's Avatar
Liked: 813
I am clueless why the line in are designed the way they are. The subwoofer is a mono connection. You can use a "Y" connector, connecting both red/white connections to the single subwoofer cable which increases the signal strength (beneficial for the auto on feature) or one can simply connect to just one of the subwoofer's line in connections.
The best connection, should the subwoofer have one, is to connect the cable to the LFE connection on the subwoofer.
post #6 of 12 Old 09-03-2013, 07:40 PM
Quoted: 761 Post(s)
Liked: 526
Again, any decent cable with an RCA connector on one end and two on the other.  OTOH, a regular straight-through cable should do it anyway.
Kal Rubinson
post #7 of 12 Old 09-03-2013, 07:42 PM
Quoted: 761 Post(s)
Liked: 526
The reason for two inputs is to permit stereo users to connect the unbuffered/unisolated L and the R outputs to a single sub without shorting the channels and eliminating stereo separation in the main speakers.
Kal Rubinson
post #8 of 12 Old 09-03-2013, 07:44 PM
BeeMan458's Avatar
Liked: 813
I've been hanging with Home Theater, sub pre-outs and Dolby Digital (5.1) so long, I completely forgot about connecting subwoofers with stereo speakers.
(Stereo? What's that?)
post #9 of 12 Old 09-03-2013, 07:47 PM - Thread Starter
mijotter's Avatar
Liked: 59
mijotter is offline
post #10 of 12 Old 09-03-2013, 07:59 PM
BeeMan458's Avatar
Liked: 813
post #11 of 12 Old 09-03-2013, 08:10 PM - Thread Starter
mijotter's Avatar
Liked: 59
Thanks a lot guys.
mijotter is offline
post #12 of 12 Old 09-03-2013, 08:20 PM
BeeMan458's Avatar
Liked: 813
steve nn likes this.
