Dual PSA XS30s or Dual Rythmik FV15HPs - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 2 Post By basshead81
  • 1 Post By jbrown15
  • 1 Post By SaviorMachine
Old 09-11-2013, 05:05 PM - Thread Starter
Rob from NJ's Avatar
Recently moved to Triad Gold LCRs for my front stage and Bronze LCRs for my side surrounds and rear surrounds. I have an SVS PC12 Plus and am planning on upgrading. I’m now wired for a second subwoofer and will be upgrading to a dual setup.
My room is 3,700 cubic feet. The room does not open up to other rooms, however, it’s not sealed. I sit approximately 9 feet from the subs and the subs will be positioned anywhere between 5-8 feet from each other. I primarily watch movies, however, will occasionally pop in a CD.
I’ve been debating between dual PSA XS30s or dual Rythmik FV15HPs for a long time and reading the board on this topic, of which these 2 subs have been written about frequently. I still can’t decide. The FV15HP has a 5.1db advantage in the 20–31.5Hz range, however, the XS30 has a 3.1db advantage in the 40-63 Hz. range (based on PSA measurement and independent measurement for the FV15HP). Not concerned about the price difference as they both fit into max $3K budget. Also, I have time and understand the black oak FV15HP is stocked out until late October/early November timeframe.
Your thoughts and feedback on these two options, and any other suggestions are welcome. Some of the bigger subs don’t work for me based on physical space (i.e. Triax, JTR S2, 36" depth of XV30). Also, no DIY due to lack of capability, time and interest.
Robert
Rob from NJ is offline
Old 09-11-2013, 05:13 PM
brian6751's Avatar
Quoted: 776 Post(s)
Liked: 551
Depends. First, what do you mean by not open to other areas, but not sealed?
That's not science! - Cyborg
My Theater Build
brian6751 is offline
Old 09-11-2013, 05:48 PM - Thread Starter
Meaning my theater is in my basement and there's a small stairway area that leads up to the main floor. In addition, I have a drop down ceiling and while insulated, and with noise reduction ceiling tiles, sound definitely finds its way up to the main floor. However, the basement does not open itself to other rooms (i.e. a kitchen, room, hallway).
Old 09-11-2013, 07:02 PM
brian6751's Avatar
Quoted: 776 Post(s)
Liked: 551
Ok I get it.
Sounds like you might have better results from the two Rythmiks. I say this because it doesn't sound like your going to get much room gain so after EQ the Rythmiks would be better.
My Theater Build
Old 09-11-2013, 07:12 PM - Thread Starter
Ok I get it.
Brian, thanks for your feedback. Is limited room gain due to the unsealed structure of my room (i.e. sound leakage upstairs)?
Old 09-11-2013, 07:30 PM
Kini62's Avatar
Quoted: 1250 Post(s)
Liked: 1153
Why not try another PC12+ and see how that goes? Might save $1800. They have a PC13 Ultra in the outlet section as well. I would think a pair of PC12+s would sound pretty good.
If you do change to Rythmiks or PSAs what are you going to do with the SVS?
If going with the FV15s you could always run 3 subs, lay the PC behind your MLP.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
Old 09-11-2013, 07:50 PM - Thread Starter
I don't have the room to stand a second PC12+ in the front without blocking my screen. Thought about placing a PC on the floor across my front stage, however, can't get over the way it looks, as well as, don't have a cradle to hold the cylinder in place. Also, not sure if a PC13 Ultra would match well with a PC12+ due to larger amp and more output from the 13 Ultra making the PC12+ pretty much useless.
I'm wired for 2 subs in my front stage and the traditional box shape will work best. Was thinking about adding a PB12 Plus or PB13 Ultra to my cylinder, however, unsure of matching a box with a cylinder. My thinking is 2 of the same box subs would work best.
Also, could sell the PC12+. Its 1.5 years old and in great shape.
Old 09-11-2013, 08:59 PM
brian6751's Avatar
Quoted: 776 Post(s)
Liked: 551
Do you have to have both subs up front? This not ideal you know.
My Theater Build
Old 09-11-2013, 10:22 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1348
I would go with the Rythmiks. Their driver is going to be much better, so I think you can expect much better sound quality. I am certainly going to get flamed for saying this by all the PSA fans, but the Power X driver is just such a sorry sight next to the Rythmik DS1510. No amount of them are going to beat it in sound quality, especially when you throw in Rythmik's servo mechanism. I think the XS30 would beat the FV15HP in upper bass output alone, but in every other respect, distortion, compression, linearity, etc, the Rythmik will be superior.
shadyJ is offline
Old 09-11-2013, 10:27 PM
basshead81's Avatar
Quoted: 164 Post(s)
Liked: 4719
You only get flamed for your approach...hince why you have this tag in your sig by the mods over at audioholics:
shadyJ a forum troll idiot that just begs for attention
oneeyeblind and Madmax67 like this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 09-11-2013, 10:37 PM
shadyJ's Avatar
Liked: 1348
That isn't placed there by the mods, that is an automatic tag you get for having poor feedback from other users. I got in the red badly there when I disputed the validity of subwoofer isolation pads. Somehow a lot of people were bothered by that, lol. Those threads were brutal on my reputation.
shadyJ is offline
Old 09-11-2013, 10:48 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
oneeyeblind likes this.
jbrown15 is offline
Old 09-11-2013, 11:03 PM
shadyJ's Avatar
Liked: 1348
Lol, I admit it, there is more too it than that, but my rep points or whatever they are never recovered from the subdude and gramma threads.
shadyJ is offline
Old 09-12-2013, 11:07 AM
SaviorMachine's Avatar
Liked: 90
That's funny Shady, I thought you'd applied that tag to yourself, on a lark. The truth makes more sense :-)
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
Xs30
