Which sub would you recommend for this Home Theater? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-13-2013, 03:44 PM - Thread Starter
lexlynx's Avatar
My stepfather is building a home theater in his basement. He already has the speakers all selected, and is using a 70" HDTV. He isn't sure yet about the sub. As you can see from the pics, the sub is going in an adjacent closet to be kept out of sight. What you can't see in the pics though is that there is a little dog-door-sized opening between the closet and the room. I personally have a Rythmik LV12R in my apartment that I really like, but I'm not sure if it would be sufficient here. I've used a HSU sub before, and it also sounded really good. Would a VF3 MK4 be a good fit? Any other thoughts on the setup?
lexlynx is offline
post #2 of 11 Old 09-13-2013, 03:55 PM
tenderchkn's Avatar
Let me start by getting the obvious point out of the way first: no sub is going to sound good if it gets stuck in a closet.
kemiza likes this.
tenderchkn is offline
post #3 of 11 Old 09-13-2013, 04:02 PM - Thread Starter
lexlynx's Avatar
I see, that's what I figured...What if it were a front-firing sub and was brought right up to the opening in the closet wall?
lexlynx is offline
post #4 of 11 Old 09-13-2013, 04:49 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Well first things first, what's his budget?
jbrown15 is offline
post #5 of 11 Old 09-13-2013, 06:39 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Might be better to just talk him out of the closet. He's building an HT room, right? Tell him that showing off your great sub (making it visible) is part of having an HT setup. And if he's not restricted to the size of that cubby in the closet, he can get a sub that will really impress people smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #6 of 11 Old 09-13-2013, 06:54 PM - Thread Starter
lexlynx's Avatar
Well...my Mom doesn't want to have to see it (even though I don't think she's ever seen one at all before). Female aversion to subwoofers seems to be a recurring theme on this forum...Which is why I feel it's better to build one's home theater BEFORE starting a relationship smile.gif
In my case I literally built everything...but anyway, I do think there are a few spots in the room where it could be discretely placed, but they'll have to work out if whether they want to go the visible route. Their A/V guy says they'll use this special sound-conducing thin white fabric on the floor to help the bass leave the closet, or something. It sounds a little hokey, but then I've never heard of that at all before, so who knows? I'll try to get my Stepfather to join in on this thread...
As far as that room's size goes though, can anyone recommend a particular sub? Or wattage?
lexlynx is offline
post #7 of 11 Old 09-13-2013, 06:59 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Well, you already have the LV12R. why not bring it over for a test run
cel4145 likes this.
qguy is offline
post #8 of 11 Old 09-13-2013, 07:01 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
I disagree...I had a Diy 15" bandpass sub that sounded amazing placed in a closet and had significant more output then being placed in the room. Years ago back when I still lived with my parents, my dad had a Martin logan electrostatic setup with a paradigm reference 12" sub. We moved it from out in the room to the closet behind the main speakers and it was a night and day difference. A friend of mine also did the same thing with a psw505 and had great results. Not saying this will work in every situation but it can be worth a shot if placement is limited.
basshead81 is offline
post #9 of 11 Old 09-13-2013, 07:06 PM - Thread Starter
lexlynx's Avatar
Because I would need to take this 70 lb cube on a bus to Reading...
Interesting...So I think we should get the sub first, then figure out the placement.
lexlynx is offline
post #10 of 11 Old 09-13-2013, 07:15 PM
cel4145's Avatar
Liked: 3002
I think you should get an XV30. Then your stepdad can tell your mom it's too big to ship back--158lbs eek.gifbiggrin.gif
cel4145 is offline
post #11 of 11 Old 09-13-2013, 09:43 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
Eaxctly...the best thing to do is try all placement options. Let the sub decide where it should be placed. smile.gif
