Two JTR Captivator S2's, how low at reference? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 58 Old 09-18-2013, 07:22 AM - Thread Starter
Gooddoc's Avatar
Quoted: 2672 Post(s)
Liked: 1845
Originally Posted by jlpowell84 View Post
[quote name="Gooddoc" url="/t/1490537/two-jtr-captivator-s2s-how-low-at-reference#post_23746698"]I've got 2 S2's on the way as well for my 13X28 room. Those numbers are VERY encouraging. I'll be running a couple sealed CHT 18.1s along with them. I intend to spread the subs into all 4 corners with the CHT's acting as fillers with reduced gain so they don't get overdriven.Sent from my mobile phone and approved by the NSA[/quote]Nice! I was at a demo in August where 2 submersives up in the front corners were doing most of the work with a couple SVS 13's in the rear corners acting as frequenting smoothing subs. It sounded really really good! Of course Mark Seaton tuned the system so there ya go... :/
Well, hopefully it works for me too. I don't see why it wouldn't. It seems to me it's likely I'll see a better FR using the 2 CHT's to fill some nulls than just the 2 S2's alone. The trick will be getting the gain on the CHT's high enough to be effective in that role, but low enough that they are not overdriven at the limits of the S2's.
What I need to experiment with is to see if it's better to have both S2's in the corners of the front soundstage and the CHT 18.1's in the back corners, or have an S2 and CHT 18.1 in the front and a S2 and CHT 18.1 in the back( but opposite to one another (if that makes sense:o).
Assuming, of course, that the corner positions even works well...
Gooddoc is offline
post #32 of 58 Old 09-18-2013, 08:27 AM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
You should try and get Jeff's opinion. Also send Mark Seaton a PM and I'm sure he will give you a couple really good pointers.
jlpowell84 is offline
post #33 of 58 Old 09-18-2013, 08:51 AM - Thread Starter
Gooddoc's Avatar
Liked: 1845
Yes, no doubt. I don't want to bother Jeff until he's done building my speakers and sub's smile.gif. But I also like to flesh out the thought process before I talk to either one of them since I get more out of the discussion.
Gooddoc is offline
post #34 of 58 Old 09-18-2013, 09:10 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
The less capable sub should be placed closer to the seating area...so put the CHT's back by the seats and the S2's up front.This way you can run less gain on the CHT's and not limit the S2's capability.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #35 of 58 Old 09-18-2013, 09:53 AM - Thread Starter
Gooddoc's Avatar
Liked: 1845
That's very well how things could end up. With identical subs my plan for all 4 corners would be solid, but given the disparity with output I'm not so sure. But, since I've never had 4 subs to put in the corners of my room, I'm going to try it and see what the FR curve looks like.
Gooddoc is offline
post #36 of 58 Old 09-18-2013, 11:09 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
You might consider the "Geddes technique" as explained by Marcus Mehlau here: http://mehlau.net/audio/multisub_geddes/
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #37 of 58 Old 09-18-2013, 11:53 AM - Thread Starter
Gooddoc's Avatar
Liked: 1845
Thanks Craig. I'm very familiar with the Geddes approach and what I'm doing I guess could be considered a variation/modification. The Geddes approach is really for use with 3 subs, but the biggest problem I have with the approach is that it sacrifices a lot of sub output.
Not only do I want to use my fourth sub, but I want to use both the third and fourth sub to a greater degree then what a strict Geddes approach would get me.
What I have in mind at this point is a Harman/Geddes hybrid approach smile.gif
Gooddoc is offline
post #38 of 58 Old 09-18-2013, 01:14 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
I was primarily referring to the level-setting part of the Geddes technique. If you use the placements suggested by basshead81, or any other placements for that matter, you'll still need to decide how you set the levels of the different subs. You have 3 choices: level-matching, gain-matching, (although this is harder to do with dissimilar subs), or the Geddes technique.
I am using the rather "random" placement of the Geddes technique but without the volume attenuation. I run my 3 identical Submersive HP's all at the same gain settings, (gain-matched), irrespective of their in-room positioning or the levels measured at one position in the room, (the primary LP.) So I guess I too am using a variation/modification of the Geddes technique, and a hybrid Harman/Geddes approach, (the Harman approach uses identical subs with gain-matching), although a different hybrid than the one you'll be using.
BTW, I think you can use more than 3 subs with the Geddes technique. You just keep repeating the same procedure for the additional subs. In your case, my suggestion would be to gain-match the 2 S2's and then use the Geddes level setting techniques for the CHT subs. If you level match them at the LP, you will likely end up with the CHT subs set too high. The Geddes level-setting technique allows you to get optimal benefit from the CHT subs while staying within their output wheelhouse.
Bottom line, just do whatever works best in your system. You have the benefit of being able to measure your response. Let the measurements guide you and you'll be fine.
Good luck.
Craig
Lombardi said it:
My System
post #39 of 58 Old 09-18-2013, 02:04 PM - Thread Starter
Gooddoc's Avatar
Liked: 1845
Thanks for your thoughts Craig, very well said and appreciated. I will certainly update this thread as I progress. I hope to have the S2's end of next week.
Gooddoc is offline
post #40 of 58 Old 09-19-2013, 07:59 PM
jlpowell84's Avatar
Liked: 712
Originally Posted by basshead81 View Post
Jlpowell, check out hometheatreshack.com for mini dsp tutorial.
Hey basshead. Can you link that for me? Couldn't find it
post #41 of 58 Old 09-19-2013, 09:07 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
http://www.hometheatershack.com/forums/rew-forum/
post #42 of 58 Old 09-20-2013, 06:23 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
did that help you? there is a youtube tutorial stickied in that forum. thats what I used to get started. smile.gif
post #43 of 58 Old 09-20-2013, 07:01 PM
jlpowell84's Avatar
Liked: 712
Hey ya! Thanks again. I'm going take some time this weekend and get into those threads and educate myself., I wanna go with a mini dsp I'm pretty sure!
post #44 of 58 Old 09-21-2013, 12:52 PM
jlpowell84's Avatar
Liked: 712
Basshead81, I see a number of REW tutorials on your link but I don't really see any info on how to get acquainted with the mini dsp. I did find some forums linked from the mini dsp website though biggrin.gif
post #45 of 58 Old 09-21-2013, 05:57 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
oops I linked ya to the wrong section...for some reason I was thinking REW not MINI DSP.
http://www.hometheatershack.com/forums/tags/minidsp.html
post #46 of 58 Old 09-21-2013, 06:23 PM
jlpowell84's Avatar
Liked: 712
post #47 of 58 Old 09-21-2013, 06:25 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Good stuff guys.
Lombardi said it:
My System
post #48 of 58 Old 09-21-2013, 06:39 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
^sweet! So do you use a mini dsp?
Yep...pm of you have any more questions. The forum police showed up. rolleyes.gif
post #49 of 58 Old 09-21-2013, 07:56 PM
jlpowell84's Avatar
Liked: 712
Originally Posted by craig john View Post
Good stuff guys.
Hey you bet Craig!
post #50 of 58 Old 09-21-2013, 08:14 PM - Thread Starter
Gooddoc's Avatar
Liked: 1845
Any topic is welcome...I get my subs and speakers Friday, so until then, well, its all good. After that I'll have plenty to keep the thread focused. smile.gif
Gooddoc is offline
post #51 of 58 Old 09-21-2013, 08:21 PM
jlpowell84's Avatar
Liked: 712
Thanks for not being a forum Nazi. It goes a long way man! I'm really excited for you to get your gear. What exactly did you order again? Also did you make the Sherbourn amp deal too?
post #52 of 58 Old 09-21-2013, 08:30 PM - Thread Starter
Gooddoc's Avatar
Liked: 1845
I've got 3 Noesis 212HT's and two Cap S2's. I saw the Sherbourne feeding frenzy today, lol. I've got a Sunfire 7401 that I'm VERY happy with, and at 800 watts/channel x 7 I just don't think another amp will add any more joy to my life smile.gif
Gooddoc is offline
post #53 of 58 Old 09-21-2013, 09:21 PM
jlpowell84's Avatar
Liked: 712
Nice, your amp is similar but a little more juice! Nice one indeed! Nice order! That is actually the exact order I will most likely be placing. The 212's for sure. I am looking forward to your impressions on dual CapS2's. I was certainly impressed with double wings graph of about 118 db in a 4000cu ft room! I have also heard that a CapS2 will be -6db less than an Orbit Shifter above 20hz and +6db more than an OS below 20hz. My rental is fairly small but open, but years down the road I plan on a sealed room all done up with wall decoupling, double drywall, expensive doors, etc. anyway dual Cap should play 115 db ref down pretty low in a sealed room and decent in an open room. I would do OS's but the are just so damn big! But CapS2's lack just a little headroom so...can't wait for your impressions. Congrats wink.gif
post #54 of 58 Old 09-21-2013, 10:40 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
post #55 of 58 Old 09-22-2013, 01:52 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
What are you running for surrounds Gooddoc?
jbrown15 is offline
post #56 of 58 Old 09-22-2013, 04:26 AM - Thread Starter
Gooddoc's Avatar
Liked: 1845
Yessir! It is finally the reference setup I've been pining for for many years but have held off due to cost. After seeing and hearing those Noesis 212's at a GTG though....couldn't shake the upgrade bug smile.gif.
Headroom is all relative:). I was actually fairly satisfied with my current subs (dual CHT 18.1's) and they didn't extend very deep in my room. They dropped off after 30 Hz and had essentially nothing below 20 Hz(apparently I'm easy to please). So as far as I'm concerned any improvement will put a huge smile on my face.
I'll be running CHT SHO-10's as sides and rears. JTR surrounds are the next upgrade to complete the system. I just couldn't justify the immediate cost given the CHT's are very capable in that role.
Gooddoc is offline
post #57 of 58 Old 09-22-2013, 12:05 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
Gooddoc,
Hey man, I didn't realize it was you! CHT is good stuff for sure and a great bang for buck. The JTR is a great bang, period. Let me know what you think when all said and done which I am sure you will!
Marantz 7702 Atmos
MKtheater is online now
post #58 of 58 Old 09-22-2013, 10:49 PM - Thread Starter
Gooddoc's Avatar
Liked: 1845
Will do MK. There's no doubt the Noesis is a big step up from the SHO-10's, particularly with music.
And the S2's are monsters, I can't wait to get them in the system.
Gooddoc is offline
