Two JTR Captivator S2's, how low at reference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 58 Old 09-13-2013, 07:20 PM - Thread Starter
Gooddoc's Avatar
Quoted: 3106 Post(s)
Liked: 2405
I have two JTR Cap S2's on order and I was thinking about what frequencies I should anticipate at reference volume with those two S2's in my room(Of course, properly setup with measuring gear)? 15 Hz, 10Hz, 5Hz?
Anyone with a similar setup that has measured? Thanks
Gooddoc is offline
post #2 of 58 Old 09-14-2013, 11:24 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
I have an S2 in an approximately 4400 cf soundproofed/sealed space............
Should have graphs later this evening once college football games come to an end.........I could post a few graphs for you here.
Based on data will decide if I need to purchase another S2, S1/pair or some other sub........I'm looking for smoothing at seven seating positions...............
doublewing11 is offline
post #3 of 58 Old 09-14-2013, 01:26 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 721
It depend on sub location in the room, were room gain starts, number of other speakers used, ect, ect. Two to four subs is best for smoothing out a room.
derrickdj1 is offline
post #4 of 58 Old 09-14-2013, 02:14 PM
Quoted: 229 Post(s)
Liked: 968
First attempt with REW on S2...............
post #5 of 58 Old 09-14-2013, 03:00 PM
carp's Avatar
Quoted: 2827 Post(s)
Liked: 2132
You really need a minidsp to boost up that low end!
Looks great other than that null at 65hz, what smoothing is that though?
carp is offline
post #6 of 58 Old 09-14-2013, 04:10 PM
Quoted: 229 Post(s)
Liked: 968
none............
minidsp 10 X 10 is coming...............
Will take another measurement and eliminate Audyssey from chain......that might help low end
post #7 of 58 Old 09-14-2013, 04:11 PM
ironhead1230's Avatar
Liked: 49
I don't think it should not be rolling off that quickly. Your measurement rolls off more than Jeff's ground plane measurement. Try doing a close mic of one of the woofers. That measurement should be close to the ground plane response and will show if the rolloff is from your mic or room / placement.
ironhead1230 is offline
post #8 of 58 Old 09-14-2013, 04:21 PM
Quoted: 229 Post(s)
Liked: 968
Mic is located at money seat..............which is what really matters. biggrin.gif
Will try your suggestion and see what differences there are...................
post #9 of 58 Old 09-15-2013, 06:04 AM - Thread Starter
Gooddoc's Avatar
Liked: 2405
doublewing, was that measurement done after optimizing the S2's room position? Also, I'm really blown away by how smooth your FR is with a single sub in your room - even with Audyssey in the chain. It really does look like there is some serious smoothing applied, although I don't doubt you when you say there is not. It's just that I have personally never seen a single sub FR look like that without smoothing.eek.gif You must have a killer room.
Gooddoc is offline
post #10 of 58 Old 09-15-2013, 09:09 AM
Quoted: 229 Post(s)
Liked: 968
I can assure you.............no smoothing................
Just a huge null at 65 hz which is problematic..................and I bet the roll off at 30 hz is due to Audyssey. I have only one location for the S2, smack dab in the middle of my screen to hold up my Triad Gold LCR.
I will be adding more subs in back, what I don't know...................as one S2 is enough up front..............
Toying with idea using two of something behind the second row since I have five feet of empty space calling for subs. Two subs will easily elevate that 65 hz null at money seat. biggrin.gif
The room was professionally designed using Quest panels along with room dimensions selected to optimize sound..............was a little worried about the outcome, yet graphs are turning out better than I expected. Give Erskine Group credit..............
post #11 of 58 Old 09-15-2013, 09:42 AM - Thread Starter
Gooddoc's Avatar
Liked: 2405
Gooddoc is offline
post #12 of 58 Old 09-15-2013, 12:12 PM
Quoted: 229 Post(s)
Liked: 968
This graph may help..................turned off Audyssey XT32 and calibrated a little more accurately..........maybe a better representation...............three graphs compiled across front row seating.............again, no smoothing, and I've measured the sub from 0-200 hz, but mic will not measure accurately below 15 hz. Looking on the bright side................Audyssey XT32 neutered everything below 30 hz..............glad I have a minidsp coming. biggrin.gif
post #13 of 58 Old 09-15-2013, 05:58 PM - Thread Starter
Gooddoc's Avatar
Liked: 2405
Wow! What a difference! As Gru would say, "that's what I'm talking bout"smile.gif.
You might want to try a new Audyssey calibration with different mic positions. Sometimes Audyssey just gets it wrong, other times it does pretty good.
Sent from my mobile phone and approved by the NSA
Gooddoc is offline
post #14 of 58 Old 09-15-2013, 07:10 PM
Liked: 49
Looks better. A minidsp will definitely help more. It's is strange what Audyssey did below 30hz. I've read people having issues with Audyssey boosting the ULF too much from its leveling process, but don't remember reading anything about it causing a roll off like yours. If you want to try it again, take a look at the official thread and guide.
http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-1
post #15 of 58 Old 09-16-2013, 02:46 AM
jchong's Avatar
Liked: 32
Very interesting that XT32 had the effect of rolling off below 30Hz. I hardly hear of Audyssey doing that, it doesn't on my setup.
jchong is offline
post #16 of 58 Old 09-16-2013, 04:53 PM
Quoted: 229 Post(s)
Liked: 968
Yeah, but the real issue is why 10 db's difference between 20 hz and 40 hz..................the guts IMHO.
With the length.............room mode is not an issue. I measured one meter from S2 and had almost the same graph but everything was lifted.........................have to figure out what is going on for sure. Looks like a pair of subs will have to be placed behind seating to level things out. Behind seating, I have more options for placement.
post #17 of 58 Old 09-16-2013, 08:16 PM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
Almost 120db though with a single S2 in a room that size, very nice!
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #18 of 58 Old 09-16-2013, 08:18 PM
jlpowell84's Avatar
Liked: 915
Hey Carp, where would you recommend would be a good place to learn about using the mini dsp? Something along the lines of a 101/201 course?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #19 of 58 Old 09-16-2013, 08:27 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
Jlpowell, check out hometheatreshack.com for mini dsp tutorial.
basshead81 is offline
post #20 of 58 Old 09-16-2013, 09:10 PM
jlpowell84's Avatar
Liked: 915
Ok, Thanks man! From the little I know what they do I am sure that is the EQ route I want to head down
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21 of 58 Old 09-17-2013, 07:33 AM
MKtheater's Avatar
Quoted: 1736 Post(s)
Liked: 1304
Was the mic and REW calibrated for levels? How close was the subs to the mic? What mic was used?
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is online now
post #22 of 58 Old 09-17-2013, 08:53 AM
jlpowell84's Avatar
Liked: 915
I don't know. Double wing would have to confirm that
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #23 of 58 Old 09-17-2013, 04:32 PM
Quoted: 229 Post(s)
Liked: 968
Yes......................mic was calibrated and used calibration file to do so. All levels were calibrated and reinforced with my SPL meter.
Mic was at money seat ie. middle front row. I also took measurements 1 meter from sub too and graphs were basically the same except elevated levels............same peaks and valleys.
Mic was sourced through Cross-Spectrum and was calibrated.................UMM-6.
post #24 of 58 Old 09-17-2013, 04:55 PM
jlpowell84's Avatar
Liked: 915
Nice! I got the same mic but don't have a system to use it on yet smile.gif. Those numbers are really encouraging to me as I am looking at a pair of S2's. and years down the road the plans will call for a 22x14ish room all sealed up so I will get great extension as well! Thanks for running such a high spl sweep smile.gif
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #25 of 58 Old 09-17-2013, 05:06 PM
MKtheater's Avatar
Liked: 1304
How close is the LP or money seat? What was the difference between the speaker and LP measurement? How many dBs or his much do you lose?
Marantz 7702 Atmos
post #26 of 58 Old 09-17-2013, 05:40 PM
Quoted: 229 Post(s)
Liked: 968
Front row seat is 12.5 ft from sub.......................................when I did a 1m measurement, I was looking at approximately 3-4 db's more.........maybe five. Just a bump in SPL, but no real difference in graph form.
I thought that was very odd.........especially concerning huge difference between 30-40 hz
post #27 of 58 Old 09-17-2013, 05:44 PM
Quoted: 229 Post(s)
Liked: 968
Yeah...........and I'm paying for it!
I'm so used to running a chainsaw.........................didn't think I'd have issues. WRONG!
post #28 of 58 Old 09-17-2013, 07:28 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 444
My stepdad and I used to run an Alaskan sawmill to cut boards for horse stalls & corrals from oak and hickory. Talk about loud, and unbelievably dangerous. Gotta use ear protection, man! Protect your hearing and your teeth, and you'll enjoy your old age. wink.gif
Grats on the awesome results with the Captivator S2, too!
nube is offline
post #29 of 58 Old 09-17-2013, 09:47 PM - Thread Starter
Gooddoc's Avatar
Liked: 2405
[quote name="doublewing11" url="/t/1490537/two-jtr-captivator-s2s-how-low-at-reference#post_23745765"]Yes......................mic was calibrated and used calibration file to do so. All levels were calibrated and reinforced with my SPL meter.Mic was at money seat ie. middle front row. I also took measurements 1 meter from sub too and graphs were basically the same except elevated levels............same peaks and valleys.Mic was sourced through Cross-Spectrum and was calibrated.................UMM-6.[/quote]Nice! I got the same mic but don't have a system to use it on yet :). Those numbers are really encouraging to me as I am looking at a pair of S2's. and years down the road the plans will call for a 22x14ish room all sealed up so I will get great extension as well! Thanks for running such a high spl sweep :)
I've got 2 S2's on the way as well for my 13X28 room. Those numbers are VERY encouraging. I'll be running a couple sealed CHT 18.1s along with them. I intend to spread the subs into all 4 corners with the CHT's acting as fillers with reduced gain so they don't get overdriven.
Gooddoc is offline
post #30 of 58 Old 09-17-2013, 10:04 PM
jlpowell84's Avatar
Liked: 915
Nice! I was at a demo in August where 2 submersives up in the front corners were doing most of the work with a couple SVS 13's in the rear corners acting as frequenting smoothing subs. It sounded really really good! Of course Mark Seaton tuned the system so there ya go... :/
JLPowell84's Room
FTW21 Ported Build
Spoiler!
