Any one measure that crazy bass pulse @ 1:05 into WORLD WAR Z? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By thebland
  • 1 Post By RDKing2
Old 09-21-2013, 07:51 AM - Thread Starter
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
I don't know how low it went but holy crap it was loud and sustained. I'm sure many wimpy subs bit it! But it has been a while since I've heard anything so potent on a Blu Ray disc. The seen was in Jerusalem at 1 hour 5 min.
I had my volume at -3 and I thought as the increased in volume, something was going to give... and my subs can handle anything at any level.
Very cool!
kliiez8 likes this.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
Old 09-21-2013, 08:00 AM
steve nn's Avatar
Liked: 433
Cool! sounds good! I have been thinking of picking it up.. so how did you feel the rest of it was sound and story wise?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 09-21-2013, 08:07 AM - Thread Starter
thebland's Avatar
Liked: 841
I enjoyed it. Not bad even though it had to be reworked. I'm not sure how low this pulse went but it was very, very loud and dynamic.
steve nn likes this.
thebland is offline
Old 09-21-2013, 08:27 AM
Toe
Toe's Avatar
Quoted: 1450 Post(s)
Liked: 1831
Toe is online now
Old 09-21-2013, 12:36 PM
eNoize's Avatar
Quoted: 24 Post(s)
Liked: 88
It's been measured a few times already
by Mrkazador
by nube
and
M. Enois Duarte
High-Def Digest
eNoize is offline
Old 09-21-2013, 03:40 PM
K5/SS's Avatar
Quoted: 71 Post(s)
Liked: 127
I just picked up a Earthquake Supernova MVIV-12 for near-field placement directly behind my couch. I can't wait to watch that movie in 3D on Tuesday. Will be my first ever 3D movie experience, fingers crossed:)
"The bitterness of poor quality remains long after the sweetness of low price is forgotten"
K5/SS is offline
Old 09-21-2013, 04:05 PM - Thread Starter
thebland's Avatar
Liked: 841
by Mrkazador
by nube
and
OK... I guess my excitement was warranted. Thanks!
thebland is offline
Old 09-21-2013, 04:37 PM
steve nn's Avatar
Liked: 433
I just came home with it and plan on checking it out soon! Thanks!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 09-21-2013, 05:56 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Is that the second granade that exploded? if so, yes that was a wicked scene
qguy is offline
Old 09-22-2013, 07:40 AM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
Very cool!
Thebland, what subs do you have? I am limited by the breaker tripping but I have to have the subs pretty far over reference for that to happen. Still, I don't like limits of any kind...
carp is offline
Old 09-22-2013, 08:27 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
That was one of the most intense scenes I have herd yet...granted thats not been alot but man it was awsome! First time my ears popped from subwoofer pressure. Kind of like when you take off in a air plane and the elevation change causes your ears to pop.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 09-22-2013, 08:31 AM
BeeMan458's Avatar
Liked: 813
Just a thought. How old are your breakers?
You might benefit replacing your breaker with like, kind and quality (same manufacture) as the breaker may have aged and is simply in need of being replaced.
BeeMan458 is offline
Old 09-22-2013, 08:34 AM - Thread Starter
thebland's Avatar
Liked: 841
I have two BDEAP32s.. An earlier design of Tom Danley which Mark Seaton recommended and installed. They are each powered by a 2500W amp. They are boundary dependent design (meaning, putting them against a wall is mandatory) and are able to play extremely loud and low (with EQ). They are 200 lbs each and have an incredible sensitivity of at least 100-110 db loading dependent.
Because most of my equipment consists of compression drivers and all very high sensitivity (with roots from the pro audio world), I can play soundtracks as loud as my processor will allow (and have) minimal distortion and no driver compression (and I have a generous house curve below 20 Hz)!
Both amps share a 20 amp breaker and I have never popped a circuit. I plug the sub amps directly in to the wall. The rest of my equipment receives filtered power from Equitech isolation transformers.
thebland is offline
Old 09-22-2013, 08:50 AM
carp's Avatar
Liked: 1741
Nice, yeah I thought you had a system installed by Mark.
Yeah, my speakers are all the high sensitivity/compression driver style too (I have JTR Noesis 212's), I remember we talked in another thread about it.
I definitely have a ton of bass output, I'm running 8 subs all 18" Stereo Integrity subs. In a bass heavy movie like War of the Worlds I can run the subs at 8 over reference with a house curve on top of that boosting the low end (L/T using the minidsp) so that 15hz-25hz would be even louder and not trip the breaker. Much more than that and it trips. However recently I tripped the breaker with the subs at reference with the boosted house curve (Olympus Has Fallen) so it got me to thinking about limits again.
When I put the system together I was advised by many here that a separate 20 amp line would suffice, so I ran 2 of them but it's not enough to give me no limits.
It's probably a good thing for my ears that my system has a limit (tripping breaker) but I still eventually want no limits at all.
carp is offline
Old 09-22-2013, 12:08 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
thebland,
Are you still using the Ada gear? How is it sounding?
Marantz 7702 Atmos
MKtheater is online now
Old 09-22-2013, 02:03 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
Actually, the opening scene had a few moments that was more impressive to me.......................some of the explosions had extreme LF which was a first in my room when actual thoughts of room integrity came to mind!
doublewing11 is offline
Old 09-22-2013, 04:26 PM - Thread Starter
thebland's Avatar
Liked: 841
Originally Posted by MKtheater View Post
thebland,
It's good. But I am moving to a full Trinnov system in the next 2-3 months and am looking for new speakers (13.1). BIg changes on the audio side.smile.gif
thebland is offline
Old 09-23-2013, 09:57 AM
audioguy's Avatar
Quoted: 1913 Post(s)
Liked: 1239
13.1? How about 13.x where x is a very large number?? :-)
audioguy is online now
Old 09-23-2013, 10:30 AM - Thread Starter
thebland's Avatar
Liked: 841
Yes... 13.x depending on how many we need to achieve optimal SPLs!! Good catch!smile.gif
thebland is offline
Old 10-05-2013, 09:28 AM
TenTonBass's Avatar
Quoted: 16 Post(s)
Yes, the grenade scene took me by surprise.
I feared for the structural integrity of some of my windows during that scene. It was scary!
TenTonBass is offline
Old 10-06-2013, 12:49 AM
RDKing2's Avatar
Watched the 3D version last weekend. Except for that one grenade scene the soundtrack was kind of lackluster IMO. My friends wife was in the bathroom during that scene, heard an OMG remark directly after smile.gif Running Dual LMS 5400's on a 14k clone. was at -15 on the volume. I was expecting more from the chopper scenes. 3D was meh, not even very much depth. I would have been fine to see it without.
RickyDeg likes this.
RDKing2 is offline
Old 10-06-2013, 01:04 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Dang.. I just can't wait till my subs arrive. After reading about different LFE or ULF parts on newly released BD's. I'm holding off watching a lot of them till my new subs arrive. WWZ, STITD,IM3,OHF.. Are the most recent BD titles I bought and haven't even watched it yet. Not even in the movies. Lol.. Just a couple more weeks. Yea, I can do it! I know I can.. Lol
rhed is offline
Old 10-06-2013, 07:31 AM
SaviorMachine's Avatar
Liked: 90
I think you should watch them now AND after the upgrade, it's like growing up poor so you can appreciate it when you strike it rich. What are you upgrading from?
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
Old 10-06-2013, 08:19 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Lol.. Well I did buy TLM in 3D. Watched it with my daughter last night. One of her favorites. Mines too! Nah, just kiddin.. Anyway, if any of you have kids I suggest go out and get it. And pop it in. There's some pretty good LFE in that movie. Very surprising... My old dual Supercube Reference still does some good LFE duty. Well not really old. Like 6 months old. Already sold it to my brother..
rhed is offline
Old 12-18-2013, 09:41 AM
Sinistre1's Avatar
Liked: 30
That's not a grenade that's a low frequency sweep pulse generating device:D Me Likey!!!! In my system (decidely less capable than some on here) that scene was squarely in the arena with greats like U 571, War of the Worlds, Flight of The Phoenix, Black Hawk Down and Master and Commander. It really was that good!!! Though very short in duration. That's exactly the kind of scene I wanted a sub for.
I'm getting there....!!!
Sinistre1 is offline
Old 10-23-2016, 06:40 PM
SteveCallas's Avatar
Quoted: 138 Post(s)
Liked: 56
Late to the party on this one, but this has just become a new demo scene for me. Watched it last night and this hit me be surprise, nearly shook the mirror above my mantle off the screws in the wall.
The house coming alive in Monster House will still be my go to demo, but this will also be used.
SteveCallas is offline
World War Z Blu Ray Dvd Digital Copy
