Open room media room - AVS Forum | Home Theater Discussions And Reviews
Old 09-22-2013, 07:48 PM - Thread Starter
chadcj7's Avatar
Quoted: 58 Post(s)
I am getting really close to purchasing a new subwoofer for my basement. I will explain my setup and get pics as soon as I can.
I currently have a denon 3313 that is pushing a Polk setup for the fronts, center, and the rears. My current subwoofer is a PSW10 from pol. I know it is missing a lot when it comes to home theatre bass performance. I did only pay $6 for it 5 years ago and it was originally in a small room. I currently have the subwoofer about 11 feet right in front of behind some velvet panels that i have made. It is in an opening. The room is about 16 wide with ceilings from 10 to 9 feet due to duct work in areas. It is an open room and with a bar in the rear and then open on the one side. The length of the room is about 20 feet.
I was looking at the NXG sub, SVS PB1000 sub and I am doing some more research on the Lava subs. I would like to spend no more then 500 or 600 bucks. This room is used mostly for TV and Movies. Looking for some opinions on this. Thanks
chadcj7 is offline
Old 09-22-2013, 08:10 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5302
Its hard to beat the SVS PB1000 or Rythmik LV12 in the 5-600.00 range.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 09-22-2013, 08:18 PM
brian6751's Avatar
Quoted: 907 Post(s)
Liked: 700
The rythmik lv12r will be the best choice under $600.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
Old 09-22-2013, 08:40 PM
steve nn's Avatar
Liked: 433
A question I have had is how does the PB-12NSD compare to the LVR. I came close to buying Jims LVR but couldn’t talk him down far enough to make the question worth it. biggrin.gif I’m sort of thinking the LVR should come in between the PB1000 and the PB-12NSD?? I hope the OP doesn’t mind me throwing this out there.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
