Is there such a thing as a 9" deep subwoofer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-22-2013, 08:55 PM - Thread Starter
StupidHead's Avatar
I just moved in to a small place that has a cabinet in the corner where I've been told by the wife is the only place a subwoofer can/will be placed. Either something goes in there, or no sub. I'm easy either way, and right now I'm leaning towards no sub, but thought I'd fire this out there.
The cabinet (I know, bad idea for a sub; work with me here) is 9 5/8" deep, 22" wide, and 12 1/2" high. The last guy must have either had a sub in there, or took the door off (not an option for me I've been told), because there is a power jack and a sub cable. There are 3x in-wall 6 1/2" monoprice speakers that I haven't tried out yet, and I'm thinking that an 8" sub probably won't give me that much more than the in wall speakers.
I found one 8" sub that was a 10" cube, and it's soooo close, but no cigar. I'm open to options - a car sub, a tube design, etc. I'm not an audiophile by any means, but wouldn't mind hearing a boom every so often. So, does anything exist that would fit in there that is "ok"? Budget is a consideration - max $500.
StupidHead is offline
post #2 of 11 Old 09-22-2013, 09:02 PM
RapalloAV's Avatar
Quoted: 1310 Post(s)
Liked: 292
There are wall subs that are slim. There are passive subs that are slim with the amp you store in a separate cabinet. Its not the driver that takes up all the room in a sub box, its the amp.
http://www.ebay.com/itm/Velodyne-2x-SC-8-Subwoofers-NEW-1x-SC-1250-Amp-CERTIFIED-REFURB-Bundle-/150963681360
Rob Morse likes this.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #3 of 11 Old 09-24-2013, 07:49 PM
Trendy's Avatar
Well for “she who must be obeyed”, what you do is mount a small, blown, damaged, non-functional 8” sub into the wall space available. Every now and again comment on how impressive the bass is.
After a couple of months bring home a 12” sub which a dealer/acquaintance/friend recommended because 2 subs will smooth out the acoustics in the room. Wait for her to notice the difference. When she does, suggest that you could rebuild that wall unit to accommodate the larger sub.
Now you get to score that Delta 10” Cabinet Saw you always wanted. And can start to experiment with sub cabinets in the 12 cu ft range. Isn’t marriage wonderful.
Trendy is offline
post #4 of 11 Old 09-24-2013, 08:17 PM
Bill Fitzmaurice's Avatar
Liked: 4742
The result will be no bass. You may have to obey WAF, but the laws of physics won't.
Bill Fitzmaurice is online now
post #5 of 11 Old 09-25-2013, 06:27 AM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 889
I have a Mirage MM-6 subwoofer on my basement computer. It's not that bad. I think many people on this forum would be surprised at how good it sounds. It probably doesn't give much below 40 Hz, but it can give a decent thump. Much better than nothing. I think I paid $200 for it.
KidHorn is offline
post #6 of 11 Old 09-25-2013, 06:49 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Slim subwoofers are fairly common in car audio - raw drivers are readily available.
Here is a 12" driver with 14 mm Xamx - only about 4 inches dee.
http://stereointegrity.com/index.php?id=47
and another
http://www.jlaudio.com/12tw3-d4-car-audio-tw3-subwoofer-drivers-92185
Just google around...
arnyk is offline
post #7 of 11 Old 09-25-2013, 09:49 AM
Bazzy's Avatar
Quoted: 57 Post(s)
Liked: 37
Hi,
The KEF T2 is less than 9" deep I believe & about 14" high - will that work for you? Just putting out an option!
Bazzy!
Bazzy is offline
post #8 of 11 Old 09-25-2013, 11:52 AM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
I don't think you'll be happy with the results of this arrangement. You might be better off getting beefier mains and skipping a sub if you can't place it properly. My parents have this kind of setup in their gameroom (they had the room custom built with a cabinet that would fit a sub). The sub causes the whole cabinet to rattle, and it sounds terrible.
Maybe if you posted a picture of the room we could offer more suggestions on subs/placement options that the wife might be willing to compromise on.
tsaville is offline
post #9 of 11 Old 09-25-2013, 03:22 PM
Kini62's Avatar
Quoted: 1438 Post(s)
Liked: 1327
There's this. Not sure if it will fit and it's a wee bit pricey-
http://www.paradigm.com/products/type=subwoofer/model=milleniasub/page=specs
And there is this, don't know the price though
http://www.focal.com/en/subwoofers/428-sub-air-3544057690335.html
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #10 of 11 Old 09-25-2013, 04:42 PM
KyleLee's Avatar
Most driver are less than 9" deep so you can design a shallow box for a woofer and make your own if your up for it? I would design a passive sub with an external amp. GL
data-bass.com
@databass_audio
KyleLee is offline
post #11 of 11 Old 09-25-2013, 06:59 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
Talk to the DIY guys. See if you can't come up with a design for sealed sub box.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
