For movies what is the Best High End Subwoofer? JL Audio or SVS? - AVS Forum | Home Theater Discussions And Reviews
Old 09-23-2013, 03:34 PM - Thread Starter
RefTheater's Avatar
For a dedicated Theater i am building i am considering 2 subwoofer's:
- JL Fathom F113 (x2)
- SVS PB-13 Ultra (x2)
Doesn't matter the cost difference. Between these 2 what is the best for CInema experience?
Tank you
RefTheater is offline
Old 09-23-2013, 03:35 PM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
I say Orbit Shifter LFU..
rhed is offline
Old 09-23-2013, 03:37 PM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Wait sorry.. if you meant between those two? Ive read good things on the ultra..
rhed is offline
Old 09-23-2013, 03:41 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
The ultra. Hands down
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
Old 09-23-2013, 03:43 PM - Thread Starter
RefTheater's Avatar
I've heard many good things about JTR, but aren't these speakers a little "Home Made" and bulky? Please correct me if i am wrong because sometimes i also say silly things, don't get me wrong smile.gif
RefTheater's Avatar
The Ultra has very good reviews....
Old 09-23-2013, 03:49 PM - Thread Starter
RefTheater's Avatar
The ultra should i buy the "Closed" one of the one with 3 holes?
Old 09-23-2013, 03:53 PM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
It's one of many sought after id sub in these forums. If you could fit that in your HT.. that will be the last sub you'll ever need. Especially if you go duals..
rhed is offline
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1298
For HT AKA movie use get the "ported" version.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 09-23-2013, 03:55 PM
steve nn's Avatar
Liked: 433
Imo the one with three holes.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 09-23-2013, 03:57 PM - Thread Starter
RefTheater's Avatar
Tank you so much
SVS also have speakers but they are not at the lever of JBL Synthesis 1400 Array, Paradigm Signature S8 or Kef Reference 205/2 for example, are they?
Old 09-23-2013, 03:58 PM - Thread Starter
RefTheater's Avatar
As for Processor i went for Datasat, but i should also have considered Mcintosh MX-151... rolleyes.gif
Old 09-23-2013, 04:00 PM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
BTW, JTR has subs with a smaller foot print. Seaton also makes solid subs too.
rhed is offline
Old 09-23-2013, 04:01 PM - Thread Starter
RefTheater's Avatar
I've noticed JTR is very cheap price compared to other brands. It's not very expensive to make JTR Theater, and maybe it even performs better than the speakers i am considering...however i cannot live with JTR boxes, they are a bit ugly.
Old 09-23-2013, 04:03 PM
steve nn's Avatar
Liked: 433
Tank you so much
Off the top of my head that I can't tell you. I do like speakers of course but sw's are more my passion. Happy shopping
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 09-23-2013, 04:05 PM
steve nn's Avatar
Liked: 433
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 09-23-2013, 04:12 PM
LJwelr's Avatar
If this is a dedicated theater and have an acoustically transparent screen. You won't see the speakers anyway. So get the best sounding speakers you can afford
LJwelr is offline
Old 09-23-2013, 05:01 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 09-23-2013, 06:16 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
Have you considered Funk Audio? They can make pretty much any sort of sub you want in any finish you like. You're not limited to the standard models shown on their website.
http://funkaudio.ca/18.0_Overview.html
henrich3 is offline
Old 09-23-2013, 07:11 PM
Avgass's Avatar
Liked: 35
Cheaper than SVS PB-13 Ultra but very comparable (IMHO) = Rythmik FV15HP. Wouldn't bother with the JL unless I needed a really small sub and had money to burn.
Other top end subs I would look at if I had the budget/space and didn't want to build my own...
JTR Captivator 2400 or S2
Seaton Submersive HP
Funk 18.0
Rythmik F25 - Probably less output than Cap/Subm/Funk but still up there
PSA Triax - Not reviewed yet but an exciting new product nonetheless
You might get more complete/helpful advice if you provided - Size of HTspace, listening preferences (volume, sealed vs ported etc.), budget, size constraints etc.
My 2c
Phil
Avgass is offline
Old 09-23-2013, 07:21 PM
steve nn's Avatar
Liked: 433
Originally Posted by basshead81 View Post
LOL Lets see.. one,,,, two,,, yeah three holes, your right! biggrin.gifbiggrin.gif It might not be any holes with the last suggestion posted though wink.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 09-23-2013, 07:37 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
If money is no issue I would have Nathan at Funk Audio build something Custom. I would go with a design like the Triax but with 3 18's that houses a speaker power amp like the Seaton HP+...which features slave mode to drive another passive unit.
Old 09-24-2013, 04:46 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Tank you
OP if you want a reference home cinema, the front speakers and subs are behind the projector screen and are not seen. In that case JTR OS LFU duals will murder the duals of JL Fathom113 and SVS-PB-13 ultra any day with every shock wave they will belt out.
Even if room acoustics govern placement of one sub in front and one in the back, the front would be behind scree and the rear one behind the seating area.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Old 09-24-2013, 04:56 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
I told em that earlier in this thread. But the OP said JTR's are ugly boxes. I was just trying to save him from another sub upgrade down the road if incase he wanted more. Well unless the OP gonna do DIY later. But anyway, still, my first choice would be OS or S2 or SubM master/ slave combo..
rhed is offline
Old 09-24-2013, 05:00 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
rhed is offline
Old 09-25-2013, 08:39 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
SVS make great subs, JL makes great subs. Much depends on the size of your room and number of seats. Hard to give any recommendations without further data on room size.
For any kind of 'reference setup' which I assume you are going for with the DataSat processor I'd go for multiples. Minimum 4, 2 front, 2 back. There are VERY good acoustical reasons for doing this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
Old 09-25-2013, 08:50 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Dual OS's probably murder is house not just those two other subs....lol
Seriously at one GTG that had dual OS's; those two subs where causing the walls and floors to flex so much it cause the tiles on the floor above to crack along with the grout! eek.gif
To the OP keep in mind that Jeff at JTR does offer custom veneer options for his speakers and subs.
jbrown15 is offline
Old 09-26-2013, 11:11 AM
Quoted: 311 Post(s)
Liked: 273
I haven't heard these subs but went through the entire GTG thread. I can imagine what OS can do. JTR OS LFU and Rythmik FV15HP are the only subs I can buy blindly without auditioning them.
OP's desire is to have "Best Cinema Experience" yet he wants looks worthy sub. That ain't possible. JTR OS LFU is ugly as hell but sends the message; "Bring it on.....".
I think trading off aesthetics with performance is not wise if the objective is the best cinema experience.
Old 09-26-2013, 12:37 PM
steve nn's Avatar
Liked: 433
What am I looking at here? Are those subs or speakers?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 09-26-2013, 01:25 PM
its phillip's Avatar
Quoted: 62 Post(s)
Liked: 115
those are jtr quintuple speakers.
its phillip is online now
Svs Pb13 Ultra , Jl Audio Fathom F113 Gloss 13 5 Inch Powered Subwoofer
