Subwoofer height, is it important ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-23-2013, 11:34 PM - Thread Starter
Mongao's Avatar
Hi friends,
Please does it make any difference to have the sub say on the top of a cabinet instead of directly on the floor ?
The position in the room would be the same, I am only considering coming up with a wood cabinet where the sub is (the cabinet is say 3' high) and put the sub on the top of it;
Thanks a lot,
Mongao
Bigsky HiFi likes this.
Mongao is offline
post #2 of 6 Old 09-24-2013, 12:03 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
How high is your roof? How tall is the sub itself? What kind of cabinet are you talking about? Is it hollow from inside?
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 6 Old 09-24-2013, 12:36 AM
rcohen's Avatar
Quoted: 1215 Post(s)
Liked: 519
Try the room analyzer in Room EQ Wizard 5.01. It will let you simulate height and other layouts:
http://www.hometheatershack.com/forums/downloads-area/47460-v5-01-beta-downloads-asio-support.html
rcohen is offline
post #4 of 6 Old 09-24-2013, 06:05 AM
Bill Fitzmaurice's Avatar
Liked: 4655
Probably not. Subs are usually placed on the floor because their size and weight tend to be too much for placing them on a cabinet.
Bill Fitzmaurice is offline
post #5 of 6 Old 09-24-2013, 06:53 AM
KidHorn's Avatar
Quoted: 1375 Post(s)
Liked: 883
Give it a try and see how it goes. I think the only issue may be the cabinet vibrating if it's not solidly put together. Some of my subs vibrate a lot.
KidHorn is offline
post #6 of 6 Old 09-24-2013, 09:01 PM - Thread Starter
Mongao's Avatar
Thanks to everybody that replied, I may give it a try,
Mongao
Mongao is offline
