What's the best crossover point for a Rythmik LV12R + Ascend 340 5 speaker system? - AVS Forum | Home Theater Discussions And Reviews
Old 09-26-2013, 07:39 PM - Thread Starter
lexlynx's Avatar
Quoted: 18 Post(s)
Audyssey defaults it around 40Hz for some speakers, but that's a no go since the Ascends only go down to 45Hz. I knw 80Hz is the THX default, but would leaving as much bass to the LV12R as possible (100Hz) be best, as it (possibly) has superior bass than the Ascends, what with its direct servo technology and all?
lexlynx is offline
Old 09-26-2013, 07:46 PM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
Since room interaction with your speakers/sub can affect which would work better for you, use whichever of 80hz or 100hz sounds best to you smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 09-26-2013, 08:00 PM - Thread Starter
lexlynx's Avatar
Quoted: 18 Post(s)
Ok...
Sadly, I think most of my room is a null, possibly because there are these 2 closets on one wall, and the room widely opens up into an adjacent room. Hopefully a 2nd sub will fix it.
lexlynx is offline
Ascend Acoustics Cmt 340 Se Center
