Wireless Subwoofer Setup for Dual Subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-27-2013, 10:05 AM - Thread Starter
Jobio's Avatar
Just a (hopefully) quick question:
When using dual subs, should both be set-up using a wireless system like Rocketfish, or can one be wired and one wireless? My receiver has Audyssey MultiEQ XT for room correction, and I'm worried about it setting proper delays (distances) for the dual subs if they use different means of receiving the signal from the AVR.
Jobio is offline
post #2 of 10 Old 09-27-2013, 10:59 AM
PoppaC's Avatar
Quoted: 29 Post(s)
Liked: 40
I don't think it makes any difference if one is wired and one wireless. I currently have two Rythmiks connected that way.
PoppaC is offline
post #3 of 10 Old 09-27-2013, 03:50 PM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
Typically there is a small delay caused by the process transmitting the signal wirelessly. If you can account for this delay by adjusting the distance of each subwoofer independently you should be fine. Even if you cannot, you should feel free to test it out, the delay may be below your personal threshold to notice.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
post #4 of 10 Old 09-27-2013, 09:24 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Forget rocket fish. Use these
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-580
If the subs are not the same distance from the listening position, you will need to use the phase adjustment to fine tune them regardless of the connection choice.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #5 of 10 Old 09-27-2013, 09:36 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
why forget the rocket fish? they are the only ones that operate on a 5ghz band so there is no interference with 2.4ghz devices such as wifi internet. They also do not have a hpf below 20hz...and lastly I have a pair and they work flawless. smile.gif
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #6 of 10 Old 09-27-2013, 10:00 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Where do you see it transmits below 20?
Also the wireless tech isn't the same as wifi
Rivers Edge Theater
post #7 of 10 Old 09-27-2013, 11:26 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
Because i have measured with and without the wireless and get the same extension smile.gif. And yes folks have reported having issues with wireless internet interference with 2.4ghz wireless sub devices. AustinJerry is the first person that comes to mind.
post #8 of 10 Old 09-28-2013, 05:38 AM
Ed Mullen's Avatar
Quoted: 80 Post(s)
Liked: 268
The Dayton SubLink can work with one transmitter and two receivers, provided two kits are purchased. We measured this unit -3 dB @ 6.5 Hz, it links up quickly, stays connected, has a decent S/N ratio, and in my testing proved quite immune to 2.4 GHz interference. I threw the 2.4 GHz book at it and it passed all tests, only to finally act up a bit with my iPhone literally 2" inches from the transmitter.
The latency of this unit is about 25 ms, which equates to ~27 feet of subwoofer distance, so I definitely recommend going wireless to both units unless the AVR has the ability to independently set distance for each subwoofer. Phasing wired and wireless subs using the variable phase control is also an option, but in my testing proved less optimal than starting with both subs wireless and then using the variable phase to fine-tune.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #9 of 10 Old 09-28-2013, 08:12 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5208
I was originally going to go with these per Tom V. but they were out of stock at the time, so fortunately the Rocketfish proved to be a great alternative. smile.gif
The delay is about the same per your post, but I can sit my Note 2 right next to transmitter with no issues. smile.gif
I ended up using 2 wireless devices and you are correct it was easier to tune the subs. The AVR did a better job getting the distances set correctly.
post #10 of 10 Old 09-28-2013, 02:46 PM - Thread Starter
Jobio's Avatar
Thanks for the suggestions, everyone. Sounds like having both subs on a wireless transmitter will be easier to set-up, especially since I'll have one near field and the other one in the front of the room, and my AVR only has a single sub eq.
Jobio is offline
