POLK SUBWOOFER HELP!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-28-2013, 09:17 PM - Thread Starter
TheBigSmooth's Avatar
Hi my name is Dan im new to the site and i am in need of your help!
I am currently am looking at these 2 subwoofers. Polk PSW121  and the Polk PSW10
I honestly dont know the difference i cant find what makes what one better. On Newegg they are the same price ill link them
PSW121
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290286&Tpk=PSW121
PSW10
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290034
Also
There is no LFE on the subs but my new reveiver has only LFE out. How can i do this perfectly with these 2 subs?
TheBigSmooth is offline
post #2 of 16 Old 09-28-2013, 09:23 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5214
you can just plug into the Left rca input or use a Y adapter and plug into both rca inputs on sub.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #3 of 16 Old 09-28-2013, 09:51 PM - Thread Starter
I have seen the splitters. Would that degrade sound? What is the benefit of using a splitter vs not
post #4 of 16 Old 09-28-2013, 09:56 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5214
no not at all.
post #5 of 16 Old 09-28-2013, 10:00 PM - Thread Starter
So why would i use the splitter?
post #6 of 16 Old 09-28-2013, 10:07 PM
tenderchkn's Avatar
There's no real reason to. Using both left and right inputs will strengthen the input signal, but you can achieve the same thing by simply turning up the gain knob.
tenderchkn is offline
post #7 of 16 Old 09-29-2013, 12:27 AM - Thread Starter
Well what are some good cables? I see splitters that go 2RCA Male to 1 RCA female. dont i need 2 male ends?
post #8 of 16 Old 09-29-2013, 01:14 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
http://www.amazon.com/Mediabridge-Ultra-Series-1-Female-Subwoofer/dp/B004EBX5GW/ref=sr_1_5?ie=UTF8&qid=1380438790&sr=8-5&keywords=y+cable+one+female+to+two+male
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #9 of 16 Old 09-29-2013, 01:15 AM
Quoted: 311 Post(s)
Liked: 273
post #10 of 16 Old 09-29-2013, 02:22 AM - Thread Starter
but my LFE port is female how will i connect it?
post #11 of 16 Old 09-29-2013, 02:27 AM
Quoted: 311 Post(s)
Liked: 273
Stick the two male ends into LFE and right input, and connect other female end with the sub rca cable
post #12 of 16 Old 09-29-2013, 09:01 PM - Thread Starter
my receiver is a 7.2 but the .2 is really just a .1 split. what if i got you subwoffer rca cables and pluggled them into left and right?
post #13 of 16 Old 09-30-2013, 04:56 AM
Quoted: 311 Post(s)
Liked: 273
Running two sub cables to feed Left/Right inputs on one sub is simply wastage of resources and money. Run one rca cable from any of the two sub pre outs from avr, and use 1 female to 2 male y-adaptor at the end of it to terminate into Left/Right input on the sub.
steve nn likes this.
post #14 of 16 Old 09-30-2013, 05:30 AM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
It wouldnt be correct.
Licence to Kill
Bond 007 is online now
post #15 of 16 Old 09-30-2013, 05:31 AM
Bond 007's Avatar
Liked: 1907
+1
Licence to Kill
post #16 of 16 Old 10-05-2013, 02:00 PM - Thread Starter
Ok thank you so much for all your help!
