Subwoofer help please - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2013, 06:32 AM - Thread Starter
kuiwik's Avatar
Hi i am trying to get my sub woofer going but am having a little trouble. Reciever is a Yamaha 5950 and sub is from a set of speakers given to me from a friend. Any help would be really appreciated.
Karl
AppleMark
AppleMark
kuiwik is offline
Old 09-29-2013, 06:43 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
That is a passive (unpowered) subwoofer. It was likely powered by the receiver of the HTiB (home theater in a box) it originally came with.
For your purposes, you'll need to purchase a separate subwoofer amplifier (example, from parts-express.com).
Alternatively, you could dump that sub and buy an active (powered) sub, which you would connect to your receiver's subwoofer output.
eljaycanuck is offline
Old 09-29-2013, 07:25 AM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
You could buy a small sub amp for that to make it work... but you could do better and cheaper in the long run by just buying a used POWERED subwoofer or get a new budget Powered subwoofer. Used Jbl, M&K, Polk, Klipsh, KEF can be had for less than $100 at Craigslist if your patient enough.
qguy is offline
