Official PSA Triax Thread - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
post #3511 of 3564 Old 11-29-2014, 07:16 PM
ahblaza's Avatar
Quoted: 1566 Post(s)
Liked: 1694
Originally Posted by raynist View Post
Do you use the minidsp with your triax?
Was there any elaboration on how the .9 can work? I already have that one and it is easier to work with the RCA connections. I will get the balanced if needed though. I don't want to hook the unbalanced .9v output unit up if it isn't going to work and mess up my current settings/calibration.
Ray, I honestly would wait for a definitive answer if I were you, that's a big deal and having to do over everything you already did. Sorry for my dumb answer earlier I wasn't considering the miniDSP in the chain only the 5 volt preout driving the Triax, sorry.
Jeff
ahblaza is offline
post #3512 of 3564 Old 11-29-2014, 07:24 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
No, I don't use a miniDSP. I remember reading about concerns clipping the miniDSP's input and limiting headroom, so I never tried one.
I did try an Antimode, but frankly it didn't make much difference and a few times I did see the input clipping light flicker, so I sold it.
Even without any EQ, my single Triax sounds great. Tom says my measurements look good (others here said not so good when I posted my measurements).
Tom didn't elaborate about the .9v miniDSP setting. I just figured he meant the gain adjustment on the Triax could accommodate it.
Saturn94 is offline
post #3513 of 3564 Old 11-29-2014, 07:41 PM
raynist's Avatar
Quoted: 1446 Post(s)
Liked: 1371
I am currently using Audyssey XT32 to EQ everything. The minidsp is for a house curve.
Yeah, I will wait for a definitive answer before joining it up. I have 2 of the triax's on each output of the onkyo. Two of them are no where near each other so I have the output of the onkyo going into an SVS Sub-EQ and then to each triax. The other two triaxs are very near each other so they are eq'd as one.
Having to run the SVS sub EQ first (8-32 positions) then Audyssey (8 positions) and then doing the Audyssey Sub Distance Tweak and then EQ tweaks on my Inukes takes probably 2-3 hours when all said and done. I would hate to do all of that only find out that I need the balanced version.
ahblaza likes this.
raynist is online now
post #3514 of 3564 Old 12-10-2014, 10:40 AM
Alan P's Avatar
Quoted: 4892 Post(s)
Liked: 3525
Did anyone ever get a definitive answer concerning the .9v/2.0v MiniDSP preferred output voltage with the Triax/T-18?
Alan P is offline
post #3515 of 3564 Old 12-10-2014, 01:50 PM
raynist's Avatar
Liked: 1371
Tom and Jim were testing it last week. They found that it did limit output on the triax in their office. They are working on a solution.
post #3516 of 3564 Old 12-10-2014, 02:00 PM
Alan P's Avatar
Liked: 3525
Yeah, I just heard from Tom via email and he said they are "testing out a couple new DSP programs that change the gain sensitivity on the T-18 right now".
Alan P is offline
post #3517 of 3564 Old 12-10-2014, 02:16 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Woild this be with any minidsp sub combination? (The limiting of output?)
Brian Fineberg is offline
post #3518 of 3564 Old 12-10-2014, 02:19 PM
raynist's Avatar
Liked: 1371
I don't think so. I think it is specific to the Speakerpower amps.
post #3519 of 3564 Old 12-10-2014, 02:38 PM
Alan P's Avatar
Liked: 3525
I had issues with my XS15s + MiniDSP.
Alan P is offline
post #3520 of 3564 Old 12-10-2014, 02:40 PM
McLuvin's Avatar
Quoted: 247 Post(s)
Liked: 75
Do we know which miniDSP unit they are testing? I see on their web site that they sell the 2x4 but it is the non-balanced version. I just ordered the 2x4 balanced and was curious since I believe it has better output voltage.
Well, here is how miniDSP describes it for the 2x4 balanced:
  • Maximum input level <1% THD Input sensitivity configurable by jumpers from 0.9Vrms(7dBu in balanced mode) to 2Vrms(14dBu in Balanced mode)
  • Maximum output level <1% THD 2Vrms (5.6Vpp) referenced to ground, i.e. 14dBu in balanced mode
Here is the info for the 2x4 non-balanced version:
  • Maximum input level <1% THD 0.9Vrms (Reva) or 2Vrms (Revb)
  • Maximum level, unbalanced, <1% THD 0.9Vrms (2.5Vpp)
So again I would curious which model they are using for testing as it seems to make a difference.
McLuvin is offline
post #3521 of 3564 Old 12-10-2014, 02:48 PM
Liked: 3515
Confirmed by Tom no issue with xs30's and minidsp
ahblaza likes this.
post #3522 of 3564 Old 12-10-2014, 03:23 PM
raynist's Avatar
Liked: 1371
It
It was the unbalanced. I don't think there will be any issues with the balanced.
post #3523 of 3564 Old 12-12-2014, 09:20 AM
Tom Vodhanel's Avatar
Quoted: 1682 Post(s)
Liked: 4874
T-18s begin shipping again today. Couple pictures.
We do productions runs of six...
1) 24,000 watts programmed, tested and waiting.
2) Eighteen 18" drivers bench checked, waiting
Tracking info will be going out between 4 and 6pm(when RL Carriers pops in).
Thanks to all for all the patience shown during our back order situation.
Tom V.
Power Sound Audio
ID:	417538   Click image for larger version
cesar123 likes this.
Tom Vodhanel is offline
post #3524 of 3564 Old 12-12-2014, 09:45 AM
McLuvin's Avatar
Quoted: 247 Post(s)
Liked: 75
Tom V.
Power Sound Audio
Tom - was just curious... how are the Triax's wired up and what is the impedance on the amp? For example, is the amp seeing a 4ohm load and putting out 4000 watts? And if so, how are the subs wired to achieve the impedance target? I ask because of the odd number of drivers you use. If that is something you prefer not to divulge then I would understand.
McLuvin is offline
post #3525 of 3564 Old 12-12-2014, 10:06 AM
Liked: 4874
6 coils total. Each driver is wired in series between the dual coils and then all three loads(drivers) are paralleled together into the amp. Final load is a bit over 2ohm.
Tom V.
Power Sound Audio
post #3526 of 3564 Old 12-12-2014, 10:44 AM
McLuvin's Avatar
Quoted: 247 Post(s)
Liked: 75
Tom V.
Power Sound Audio
Ok, so it sounds like each voice coil is 4ohm; each driver is then wired in parallel to get 8ohm, and then all 3 drivers series together to get around 2.67 ohms. Sound about right? Appreciate the info.
McLuvin is offline
post #3527 of 3564 Old 12-12-2014, 11:39 AM
Alan P's Avatar
Liked: 3525
Tom V.
Power Sound Audio
Alan P is offline
post #3528 of 3564 Old 12-16-2014, 07:05 AM
Alan P's Avatar
Liked: 3525
Hey guys,
The tracking for my T-18s (R+L Carriers) says "an estimated due date of 12/17/14".
Does that mean I will definitely be getting them tomorrow, or does that mean that they will be calling me tomorrow to schedule delivery and it may be a day or two before I get 'em??
oneeyeblind likes this.
Alan P is offline
post #3529 of 3564 Old 12-16-2014, 07:08 AM
Liked: 3515
That means they will get it in their warehouse on 12/17 and call you to setup a delivery time.
post #3530 of 3564 Old 12-16-2014, 07:17 AM
Alan P's Avatar
Liked: 3525
Thanks Brian....but does that mean they will schedule delivery tomorrow, or a day or two later...or is there no way to know??
Just trying to plan so I can take the day off from work.
Alan P is offline
post #3531 of 3564 Old 12-16-2014, 07:40 AM
Liked: 3515
Call them and bug them. That's what I did with each of my xs30's haha.
In fact I am not 100% I would have gotten them the next day if I hadn't called first. It would have been a few days until they called.
post #3532 of 3564 Old 12-16-2014, 07:49 AM
Alan P's Avatar
Liked: 3525
I'll do that Brian. Gonna wait until it says they actually left Minneapolis (arrived there 11pm last night and haven't moved) before I call though.
Alan P is offline
post #3533 of 3564 Old 12-17-2014, 03:51 PM
ahblaza's Avatar
Liked: 1694
Alan, I believe you will have them by Friday
ahblaza is offline
post #3534 of 3564 Old 12-17-2014, 03:57 PM
Alan P's Avatar
Liked: 3525
Yeah, there gonna be here tomorrow (Thursday) between 9a-noon.
Alan P is offline
post #3535 of 3564 Old 12-17-2014, 05:24 PM
ahblaza's Avatar
Liked: 1694
Alan, I knew that but I wanted you to sweat for an hour or so, I've only had 11 subs delivered and picked up by FedEx, ENJOY and post your impressions
ahblaza is offline
post #3536 of 3564 Old 12-28-2014, 07:49 AM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
My apologies if I missed it, but is there any further info on the issue of using the MiniDSP with the Triax? I know it was mention Tom was doing sone further testing, but I don't remember any post about the conclusion of those tests.
Saturn94 is offline
post #3537 of 3564 Old 03-01-2015, 12:21 PM
raynist's Avatar
Liked: 1371
Wondering if anyone wants to trade a black Triax for my cordovan cherry straight up?
It is about to go behind an AT screen never to be seen again. It is too pretty for that.
Located in Pittsburgh.
post #3538 of 3564 Old 03-01-2015, 12:48 PM
Saturn94's Avatar
Quoted: 138 Post(s)
Liked: 468
So true!
I wish I had the budget to buy it from you. It would complement my single Cordovan Cherry Triax quite nicely!
Saturn94 is offline
post #3539 of 3564 Old 03-02-2015, 11:39 AM
Reefdvr27's Avatar
Quoted: 1567 Post(s)
Liked: 1047
Nice Gesture, but I would hang on to it. Think resale!!
ahblaza likes this.
Reefdvr27 is offline
post #3540 of 3564 Old 05-14-2015, 01:17 AM
stm69's Avatar
Quoted: 17 Post(s)
Liked: 26
Wow guess I've been out of the loop awhile.. didn't even realize the Triax had been discontinued. Haven't had a lot of time recently and think I've only put 100 hours on my Triax. Turned it on for the first time in a few months and looks like the amp's dead. According to the manual:
230VAC Model (Long flash - Short flash)
4-1 = Fault from gate PCB while amp was working ok. May reset with power cycle
So I will call Tom in a few days and see what it might be. Pity, I get in moods to want to rock the foundation now and then...
stm69 is offline
Power Sound Audio Triax
