Official PSA Triax Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 80Likes
post #91 of 3565 Old 10-09-2013, 07:44 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Originally Posted by Saturn94 View Post
I just ordered this to help get my Triax into place and move when needed. Anyone use this before?
http://www.amazon.com/EZ-Moves-Furniture-Moving-System/dp/B005FGAP7W/ref=sr_1_2?ie=UTF8&qid=1381368328&sr=8-2&keywords=Furniture+lift
You don't have any buddies willing to give you a hand moving it?
jbrown15 is offline
post #92 of 3565 Old 10-09-2013, 07:55 PM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
I have one volunteer.
Saturn94 is offline
post #93 of 3565 Old 10-10-2013, 07:28 AM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1063
We have that same kit. My wife bought it. We actually use it for our coffee table. We bought a new leather sofa and it has two recliners, so we put those sliders under the legs of the coffee table to move the table back and forth when we recline. They work well.
Reefdvr27 is offline
post #94 of 3565 Old 10-10-2013, 07:45 AM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
Do you think the lifter will be adequate to lift the Triax enough to get the sliders under it?
Saturn94 is offline
post #95 of 3565 Old 10-10-2013, 07:53 AM - Thread Starter
BeeMan458's Avatar
Liked: 813
(oh wait, you mean the leaver thingy)
One hand turned backwards should be able to lift the subwoofer sufficient to get sliders under the legs. A simple block of wood and a two foot piece of 1x2 would tip the subwoofer up as it wouldn't take but twenty-five to fifty pounds of downward force to tip the subwoofer up.
BeeMan458 is offline
post #96 of 3565 Old 10-11-2013, 07:03 AM
ndskurfer's Avatar
Quoted: 43 Post(s)
Liked: 53
I bought a set of these for my pair of XS30's. It came in extremely handy when I was running sweeps and finding placement for them. I have the outlaw wireless kit, along with a good extension cord, placement and setup was very easy with the sliders. They will work.
ndskurfer is offline
post #97 of 3565 Old 10-11-2013, 07:08 AM
Reefdvr27's Avatar
Liked: 1063
I don't think you will need the lifter to lift it. Honestly, I never used the lifter, just the sliders.
post #98 of 3565 Old 10-11-2013, 07:11 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
We use the furniture sliders frequently on 650-700lb pool tables, so they should work fine for a 230lb sub.
basshead81 is offline
post #99 of 3565 Old 10-11-2013, 07:39 AM
ndskurfer's Avatar
Quoted: 43 Post(s)
Liked: 53
Lifter is overkill, agreed. I do not have this exact "kit".
post #100 of 3565 Old 10-11-2013, 07:42 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
Looks like the Triax 2m rms data was updated.
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
The 20-63hz average is down about 2db from Tom's initial post on the new drivers. I assume thats why he didnt update the info right away. Either way still looks to be about a 1.5db gain across the board...more is better smile.gif
post #101 of 3565 Old 10-11-2013, 07:48 AM
steve nn's Avatar
Liked: 433
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #102 of 3565 Old 10-11-2013, 08:03 AM - Thread Starter
BeeMan458's Avatar
Liked: 813
Where did you locate the new 2m information? So as to update the first post, I looked all over the PSA website and was not able to find your information. confused.gif
post #103 of 3565 Old 10-11-2013, 08:10 AM
jbrown15's Avatar
Liked: 1995
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
Holy cow, if that's the case the Triax will officially knock the Paradigm Sub2 off as the top sealed commercial sub as soon a Josh Ricci tests one! (hopefully he tests one biggrin.gif)
jbrown15 is offline
post #104 of 3565 Old 10-11-2013, 08:27 AM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
That seems to fall more in line with Tom's description of improvements being "subtle".
Saturn94 is offline
post #105 of 3565 Old 10-11-2013, 08:45 AM
jbrown15's Avatar
Liked: 1995
Lets not forget all about all of the doubters and haters (aka shadyJ...lol) that will come out and say "I'll believe it when I see some third party measurements" rolleyes.gif
Personally I think Tom and Jim have no reason to lie because they know that eventually someone like Josh will test it and the truth will come out anyways.
I 110% believe that under what ever 2m ground plane testing conditions they achieved these numbers under were the numbers the Triax actually hit with the new drivers.
SaviorMachine likes this.
jbrown15 is offline
post #106 of 3565 Old 10-11-2013, 08:57 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
I agree but when he initially posted 125.35db 20-63hz, that is alot more then subtle compared to the 121.9db average of the original drivers. Thats all I was basing my info on...my apologies for thinking ahead. I was hyped up for you pre order folks that waited this whole time. It is still a solid upgrade none the less. smile.gif
post #107 of 3565 Old 10-11-2013, 09:00 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
For alot less money too! Thats getting up there with the folded horn subs...better add one to them XS30's lol.
post #108 of 3565 Old 10-11-2013, 09:12 AM
steve nn's Avatar
Liked: 433
Those are incredible numbers, look at those even compared to vented! No there is no way Tom fudged on the numbers, sounds like maybe you remember a post by Bill F regarding something like that. NOPE! not gonna happen.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #109 of 3565 Old 10-11-2013, 09:15 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Old Triax Drivers: 2m rms
Ultra-low bass (20-31.5 Hz): 116.4dB
Low bass (40-63Hz): 127.1dB
New Triax Drivers: 2m rms
Ultra-low bass (20-31.5 Hz): 117.8dB
Low bass (40-63Hz): 128.9dB
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #110 of 3565 Old 10-11-2013, 09:20 AM
jbrown15's Avatar
Liked: 1995
jbrown15 is offline
post #111 of 3565 Old 10-11-2013, 09:36 AM
nfraso's Avatar
Liked: 172
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
117.8dB at 20-31Hz (2m) requires 3 x 800cm^2 Sd (15") drivers to each move 40mm one way (cleanly, of course). So we're in the ballpark with what physics says is possible, but it's probably a bit overstated comparable to Data-Bass numbers (just like the XV-15 was).
I'd knock that number down ~2dB, expecting somewhere around 30mm of clean throw one way.
nfraso is offline
post #112 of 3565 Old 10-11-2013, 09:49 AM
Tom Vodhanel's Avatar
Quoted: 2017 Post(s)
Liked: 5980
20-31hz 117.8db
40-63hz 128.9db
20-63hz 123.35db
If you don't convert to pascal (per CEA) before doing all of this you will end up with a completely different data set. Our current data set averages to about 125dB from 20-63hz which is within 0.4(?) of my last posting.
Tom V.
Power Sound Audio
“Quality isn't expensive, it is priceless" --- fortune cookie
Tom Vodhanel is offline
post #113 of 3565 Old 10-11-2013, 09:53 AM
Liked: 5980
Remember, the 117.8dB is an average of 20,25,31hz..
There's always going to be 0.5dB here or a dB there between test sessions.
Also, if you consider the differences in enclosure orientation for the XV15 the data is within 0.5 - 0.75dB which is really a tight tolerance. Anyone who has experience measuring outside would agree.
Tom Vodhanel
post #114 of 3565 Old 10-11-2013, 09:53 AM
Bigotis's Avatar
Quoted: 25 Post(s)
Liked: 31
Got the email I've been waiting for, my first Triax is shipping this afternoon, really have anticipated this for a long time. I can't wait to hear the first reviewer.
Bigotis is offline
post #115 of 3565 Old 10-11-2013, 10:04 AM
jarretc's Avatar
Quoted: 20 Post(s)
Liked: 163
Denon X4000
Power Sound Audio (MT-110 / MTM-210C / MT-110)
Oppo BDP-103
Dual Power Sound Audio Triaxes
Sony KDL60W630B
jarretc is offline
post #116 of 3565 Old 10-11-2013, 10:06 AM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
I am more curious to hear what the owners think these days. Too many benchmark subs out there without 3rd party testing. I don't think it is in Tom's interest to worry about this.
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
post #117 of 3565 Old 10-11-2013, 10:17 AM
Liked: 5980
I think we'll get through most of the pre-orders (120 volt) for May and June today. 208-240v orders will take up much of next week. I'm hoping all orders through end of July will be taken care of in this production run(by mid next week). Second production run is scheduled in about 10-12 days. That will be a much larger "run" and should fulfill all current orders.
As much as we would love it----we just can't assemble and test 25 Triax a day. I am estimating 8-12 a day when we can completely focus on them(like today).
If you ordered in May or June you should see tracking info in your inbox late this afternoon. A few toward the end of June may slide until early next week though. We'll do our best!
Tom V.
Power Sound Audio
post #118 of 3565 Old 10-11-2013, 11:18 AM
NWCgrad's Avatar
Quoted: 1269 Post(s)
Liked: 1310
I am getting excited for those who ordered these beasts. Seem to be a great value.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #119 of 3565 Old 10-11-2013, 11:18 AM
Blackmambakila's Avatar
Quoted: 53 Post(s)
Liked: 826
So if im part of the first batch, i wonder where that puts me as far as a time frame?
80 in Sharp Aquos Quattron led 3d tv
Denon AVR-4520CI receiver DBT-3313UDCI blu ray player
Klipsch RF-82 II, RC-62 II, RS-62 II
Dual PSA Triaxes!
Xbox one, xbox 360 My Videos! >
Christmas Surprise! http://www.youtube.com/watch?v=GJcmWTpBcm0
Triax! http://www.youtube.com/watch?v=rhoKuxirdIg
http://...
Blackmambakila is offline
post #120 of 3565 Old 10-11-2013, 11:20 AM
jarretc's Avatar
Quoted: 20 Post(s)
Liked: 163
When did you order the Triax? I ordered my first in August so it looks like I won't be seeing a shipping notice until mid-late next week.
Denon X4000
Oppo BDP-103
Sony KDL60W630B
jarretc is offline
