Official PSA Triax Thread - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 79Likes
Old 11-01-2013, 03:07 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
Originally Posted by ellisr63 View Post
Will this one be ok... Dayton Audio UMM-6 USB Measurement Microphone ?
Yes that will be fine, it comes from Cross Spectrum Labs...mine says it right on the box.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 11-01-2013, 03:42 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
The ones from CSL come with a 90-degree response, but it's possible to get Dayton UMM-6 mics from elsewhere, where they only come with the generic 0-degree response. Until he replies, who knows where he got his mic from?
Although the mic orientation won't make as much difference in the bass region when measuring subwoofers, if someone's going to go through the process of buying a mic and using REW, they might as well get the calibrated mic for not much more so they can use REW to measure and optimize the entire system/room, and for that, the 90-degree response is invaluable.
Max
djbluemax1 is offline
Old 11-01-2013, 05:34 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
I picked up a Omni mic in the AVS classifieds last week. I gotta get some time so I can run some graphs.
ellisr63 likes this.
Reefdvr27 is offline
Old 11-01-2013, 05:38 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Originally Posted by djbluemax1 View Post
Did you buy a calibrated UMM-6 from Cross Spectrum Labs? If so, you don't need to return it for a UMIK-1. Just pop over to the "REW with USB mics" thread and we'll get you started.
If you HAVEN'T bought a CSL calibrated mic yet, most of us prefer the CSL UMM-6 for USB mics. The UMIK-1 has 1 advantage over the UMM-6 though, and that's the fact that the REW programmer built-in UMIK-1 support into REW. With the UMM-6, you'll have one additional step of using the SPL meter to calibrate your measurement setup.
I'd really like to hear these Triaxs some day. Curious as to how they compare in all areas to Submersive HPs. I'm sure there'll be a sub GTG/Shootout in the future with all the heavy hitters (literally).
Max
No, this is the one I got... http://www.amazon.com/gp/product/B00ADR2E68/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1 . I haven't even opened it up. I told them I want to return it. The Cross Spectrum UMIK-1 is $95, but they have some for $55 too. I asked them what the difference was and this is what they said... "The discount mics usually have a very abnormal frequency response (typically in the low frequencies) compared to the normal mics. You can view the data sheet of a particular discount mic and compare them to the sample frequency response curves under the '"Description" tabs to see the difference (and to know what you're getting). They work otherwise and the calibration curve should correct for the abnormal response..". So should I get the discounted one or the regular priced one?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Old 11-01-2013, 08:51 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Max
Is it worth saving the $40 to calibrate your $3000 subwoofer and who knows how many $XXXX sound system?
While the mics are calibrated with a correction file against a Reference mic, you can't be sure what might have caused the skewed response and how the mic might hold up/retain it's response over time.
Max
Old 11-01-2013, 09:15 PM
raynist's Avatar
Quoted: 1285 Post(s)
Liked: 1213
Anyone know if these two mini dsp units function the same?
http://www.minidsp.com/products/minidsp-in-a-box/minidsp-2x4
Seems there would be no splicing of cables with the one above verses the one below - it is cheaper too
http://www.minidsp.com/products/minidsp-in-a-box/minidsp-balanced-2x4
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
Old 11-01-2013, 09:34 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
yes one is unbalanced or rca connection(which is what I have), the other is balanced and needs to be wired. The unbalanced revision b. should work well for your setup. The balanced works well for diy setups using pro amps that need alot more input voltage.
Old 11-02-2013, 12:39 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
The balanced 2x4 is the way to go. Because it can output higher voltages, it'll guarantee you have no need for a line booster between it and your amp. There's no splicing of cables necessary, anyway - just cut and strip, which is super easy.
Don't shortcut just because you are scared of cutting wires - it may cost you $125 if the rca version doesn't output enough voltage.
nube is offline
Old 11-02-2013, 12:43 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I ordered the balanced 2x4.
ellisr63 is offline
Old 11-02-2013, 05:33 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
http://www.powersoundaudio.com/collections/prism/products/triax
Scroll to bottom
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
Old 11-02-2013, 05:38 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
The unbalanced revision b. outputs plenty of voltage for a plate amp subwoofer. I have not herd any issues at all, with a external pro amp powering passive subs yes it can be a problem.
Old 11-02-2013, 06:59 PM
Ozzie Isaac's Avatar
Liked: 102
If a person is reading this thread they probably already have AVSitis, 7 out of 10 cases lead to DIY. Cheaper to buy the right tool on the first go-around :-P
Ozzie Isaac is offline
Old 11-02-2013, 07:02 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
Originally Posted by Ozzie Isaac View Post
If a person is reading this thread they probably already have AVSitis. The eventual cure is DIY. Cheaper to buy the right tool on the first go-around :-P
I doubt it....DIY is not going to get you more output then this sub all things equal. Doller per displacement DIY can offer more. So most likely anybody in this thread has the money and is not looking to go DIY.
Old 11-02-2013, 07:05 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
Old 11-02-2013, 07:16 PM
Liked: 102
Probably right .... I forgot this was the Triax thread!
Old 11-02-2013, 07:17 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
So what does this mean in plain language? Should I have not ordered the minidsp balanced version?
ellisr63 is offline
Old 11-02-2013, 07:38 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
I think what it means is you can have too much output voltage depending on your AVR. The balanced mini has 4.8 volts combined with 4+ volts from a Pioneer avr could cause a issue where you can not turn the sub trim low enough to keep from cliping the signal at reference.
Old 11-02-2013, 08:12 PM
Liked: 102
I don't own either, however, I did read through the manuals briefly. It read that you could set the output voltage on the lanced to the same level as the unbalanced one. You can also set the balanced one higher if need be.
Old 11-02-2013, 08:23 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Will I have a problem with the Denon 4520ci and the Triax with a minidsp?
ellisr63 is offline
Old 11-02-2013, 09:01 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
No, you won't have a problem with the Balanced 2x4. Just as Ozzie said, you can set it for 0.9V or 2.0V output with a jumper. Not sure why the guy worried about clipping the signal in the link above didn't just set it on the lower output...
nube is offline
Old 11-02-2013, 09:14 PM
Blackmambakila's Avatar
Quoted: 53 Post(s)
Liked: 826
Scroll to bottom
Dude thats awesome! Look at those numbers, holy crap!
80 in Sharp Aquos Quattron led 3d tv
Denon AVR-4520CI receiver DBT-3313UDCI blu ray player
Klipsch RF-82 II, RC-62 II, RS-62 II
Dual PSA Triaxes!
Xbox one, xbox 360 My Videos! >
Christmas Surprise! http://www.youtube.com/watch?v=GJcmWTpBcm0
Triax! http://www.youtube.com/watch?v=rhoKuxirdIg
http://...
Blackmambakila is offline
Old 11-02-2013, 09:46 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
Tom changed the numbers to 1m cea2010. Subtract 9db for 2m rms which is what was initially posted when the Triax was released. 2m rms is more in line with what you will see at the LP.
Old 11-02-2013, 09:50 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
I dont get why they changed them, very odd.
HT~
2.1CH~
Joshjp is offline
Quoted: 53 Post(s)
Liked: 826
Ok so basically he posted what they output close by, man that sounds like some good numbers. Seems like the low end is plenty strong, I can't wait to check this out!
Dual PSA Triaxes!
http://...
Old 11-02-2013, 09:52 PM
Quoted: 53 Post(s)
Liked: 826
Maybe it was just to show comparison to the other speakers and because people place them at so many positions anyways so it's like why not just put the numbers that they actually produce just to show how powerful they are. Not really sure why else but it seems to make sense
Dual PSA Triaxes!
http://...
Old 11-02-2013, 10:06 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
those would be the numbers if you sat on top of the sub or have it right next to the LP.
Old 11-02-2013, 10:10 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
1 meter away just like the standard measurement for all home speakers.
ellisr63 is offline
Old 11-02-2013, 10:12 PM
Quoted: 53 Post(s)
Liked: 826
Haha so I'll sit on my Triax then so I can experience optimal performance! Not sure what my family will think if they walk in and see me! eek.gif
Dual PSA Triaxes!
http://...
Old 11-02-2013, 10:20 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5293
1 meter away just like the standard measurement for all home2-3akers.
Yes 1m peak is cea2010 standard...however ricci @ data bass has been using 2m rms because thats more in line with what one will see at the LP. I would assume Not to many sit 2-3ft away from there speakers. I dont blame Tom for using them since everybody else does. It makes things easier to compare and probably save some rehetorical questions from being asked.
Old 11-02-2013, 10:34 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Klipsch Heresy Industrial HIP speakers are the only one I know that deviates from the standard measurement as they do 92db with 1 watt @3m.... Which equates to 101db @1 meter with 1 watt.
ellisr63 is offline
Power Sound Audio Triax
