Connecting Velodyne DD10+ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-30-2013, 08:30 PM - Thread Starter
gianco's Avatar
Hello, Does anyone know how to connect a DD10+ with an old-style tube preamplifier that only has one set of RCA output connections (those the feed the amplifier)? Thanks, G.
gianco is offline
post #2 of 2 Old 10-03-2013, 08:41 AM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
There are a couple options:
Option 1 will allow you the benefit of the subwoofers crossover controls - Connect the pre-amplifiers outputs to the subwoofer's inputs, then connect the subwoofer's outputs to the power amplifier. You can now utilize the subwoofer's set up menu to set the low pass crossover and slope you desire. The subwoofer's output jacks incorporate a selectable high pass filter of 80 or 100Hz at 6dB per octave.
Option 2 will not utilize a high pass crossover filter - using y-splitters connect the power amplifier and the subwoofer to the pre-amplifier's outputs.
Option 3 will not utilize a high pass crossover filter - Connect the pre-amplifier to your power amplifier, then connect the subwoofer to the power amplifier using speaker wire connected to the subwoofer's high level inputs.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
