New SVS Isolation feet - Page 6 - AVS Forum
 8Likes
post #151 of 165 Old 05-09-2014, 03:58 PM
dsrussell's Avatar
Quoted: 639 Post(s)
Liked: 606
^^ No need to defend. Isolators worked for you. Anytime I hear a blanket statement that it's nothing but snakeoil, my eyebrow raises a bit, even though this statement may be true for the majority of people and their situations. Each person may have unique problems that can't easily be resolved by conventional methods, which is often related to home construction problems and/or age.
I did have to chuckle a bit, however. You realize that people pay good money to have their seats vibrate like crazy, don't you? And you had it free of charge wink.gif.
BTW, you seem to have a terrific setup going on. Congratulations.
Music area: Magnepan 3.6, McIntosh MC2205 & C48, SVS SB13-Ultra, Oppo BDP 95 and assorted equipment.
Movie area: EMP Tek R5Bi, PSA XS30, Denon X2000, Oppo BDP 83.
dsrussell is online now
post #152 of 165 Old 05-09-2014, 04:10 PM
BDP24's Avatar
Quoted: 25 Post(s)
Liked: 59
Originally Posted by RapalloAV View Post
I want to defend the isolation feet in my case.....
I have four SB13-ULTRAS up front in my home cinema (no isolation feet)
Floor construction is concrete slab with floating timber flooring overtop.
In the rear I have four Velodyne subs that sit over timber risers where 12 seats are screwed to three rows.
The four Velodynes used to constantly vibrate through the seats via the raised timber floor.
The Ultras up front didn't vibrate through the risers since that timber floor was really in direct contact with the concrete.
I tried everything to stop the transfer of the Velodynes through the timber to the seats. The rubber feet they came with didn't work, I bought spikes, that was a little better but still the subs vibrated through the risers to the seats.
When the isolation feet arrived on the market I thought I would give them a go since nothing else I tried had worked.
Bingo after adding the feet, doing a new XT32 calibration and running the same problem discs the problem went!
I couldn't believe my problem of "bass in my butt" was gone!
Finally I had nice clean bass without all the floor moving, plus the integration with the front subs finally became seamless.
Something so simple had solved my issue.
Now I can get on with watching movies without all the annoying added vibrations. The only vibrations I now feel is when the bass goes really low the sound is deep in my chest.
The feet may not be for everyone, but in my case they certainly did the job. They worked for me and way better than my expectations....smile.gif
Heretic! Except in this case the "non-believers" will burn YOU at the stake.
BDP24 is offline
post #153 of 165 Old 05-09-2014, 04:32 PM
Alan P's Avatar
Quoted: 1144 Post(s)
Liked: 581
Funny....I've actually been considering adding a floating floor over my concrete slab to exaggerate the seat shaking effect. Different strokes I guess. smile.gif
AVR: Denon 4520ci, FL/R: Klipschorn, CC: Klipsch RC64ii, SUR: Polk LS F/X x 4, SUB: PSA T-18 x 2, DISP: Mitsubishi WD-73740, BluRay: PS3 & BDP-S5100, Remote: URC MX-700
Getting Started with REW
Audyssey 101
Audyssey FAQ
Alan P is online now
post #154 of 165 Old 05-09-2014, 05:02 PM
RapalloAV's Avatar
Quoted: 191 Post(s)
Liked: 58
Clean bass I think is better than seat and wall shaking bass in my mind, once you get a taste of it its hard to go back.
I have two very expensive tactile transducers under the raised section of floor, I've had them turned off for over a year. I much prefer the bass from my eight subs than the artificial feel of my butt being kicked constantly through the transducer! cool.gif
RapalloAV is online now
post #155 of 165 Old 05-09-2014, 05:10 PM
dsrussell's Avatar
Quoted: 639 Post(s)
Liked: 606
^^ For music, I don't like anything that makes noise from the walls or floors shaking. I couldn't understand why so many people like transducers. Then again, for movies, I don't mind things around me rattling and banging. Sort of adds to the reality of movie explosions, concrete buckling, etc. I can now understand why people add transducers (although I won't bother … I get enough of that without them).
BDP24 likes this.
post #156 of 165 Old 05-09-2014, 08:57 PM
Alan P's Avatar
Liked: 581
Audyssey 101
Audyssey FAQ
post #157 of 165 Old 05-09-2014, 09:18 PM
RapalloAV's Avatar
Quoted: 191 Post(s)
Liked: 58
Sorry too late and too hard to remove them.....
They are under the risers, that's then carpeted and the seats screwed through the carpet to the timber floor.
To remove the transducers I would have to remove all the 12 seats, then lift the carpet and cut into the floor to remove the transducers.
A rotten job!
post #158 of 165 Old 05-14-2014, 10:45 PM
juajar's Avatar
HI Everyone, just read this thread but couldn't draw any conlcusions, so heres my question:
Regarding Value vs. Improvement and taking into account I have hardwood floors, an SB 1000 and I don't want to piss of my downstairs neighbors which is better:
1- The rubber feet that come with the SB 1000
2- Sorbothane Rubber Bumpers ($ 24.99) http://www.amazon.com/Sorbothane-Hemisphere-Non-Skid-Adhesive-Durometer/dp/B003IMODW8/ref=sr_1_6?ie=UTF8&qid=1400129052&sr=8-6&keywords=subwoofer+isolation
3- Soundpath Isolation System ($ 50)
Thanks for everyones input.
juajar is offline
post #159 of 165 Old 05-15-2014, 06:27 AM
Bill Fitzmaurice's Avatar
Liked: 1770
In the absence of any objective data from any of those sources there is no definitive answer as to how they work, if at all. The only testing I'm aware of is my own. I measured the response of my THT sub and my David full range speaker with the test mic in the room, in the next room, and in the room below, with the cabinet sitting on the carpeted floor, on four inches of high density acoustic foam, on rubber feet and on spikes. I’d post the measured results for each set of comparisons, but there would be no point. In each case the measured responses of the four options were identical.
Note that this was on a carpeted floor. There may be some slight benefits to isolation devices or rubber feet on a bare floor, or on a bare shelf or stand. But you never want a bare floor, it’s an acoustical nightmare. If you only have area rugs in your listening room stick a piece of felt carpet padding, a carpet scrap or rubber feet under your speaker. If you're using bookshelves on a bare shelf or stand small rubber feet or felt pads are all you need to prevent spurious vibrations. Spikes do have one use, that's with carpeted floors. If your speakers move on carpet at high volume spikes will give them better grip, helping to stop movement.
mtbdudex likes this.
Bill Fitzmaurice is offline
post #160 of 165 Old 05-18-2014, 06:54 AM
Mupi's Avatar
Liked: 26
http://www.mcmelectronics.com/product/555-13378
Only issue is S&H. if you get a few people to pool in and buy many of them then you save a lot on S&H
Mupi is offline
post #161 of 165 Old 05-18-2014, 12:09 PM
raynist's Avatar
Quoted: 296 Post(s)
Liked: 387
You could always purchase these😳😳😳
http://www.avsforum.com/t/1532233/eden-sound-tera-stone-footers
3 - JTR 228's LCR (game room)
4 - DIY Sound Group V-8 Coaxials in slanted boxes (game room)
4 - PSA Triax's (game room)
3 - DIY Sound Group V-8 Coaxials in Ported Boxes for LCR's
2 - SVS SB13+'s (living room)
1 - SVS SB12-NSD (bedroom)
raynist is online now
post #162 of 165 Old 11-11-2014, 01:53 PM
mtbdudex's Avatar
Quoted: 77 Post(s)
Liked: 347
Thread bump, as these have come up again in this thread....
SVS owners give me your recommendation please!
My comments there:
For those that have them, do these really work as advertised?
I'm leery they can actually do all the label says:
"cleaner and tighter sounding bass" - how is this accomplished?
"less buzz/rattle" - ok possible if a transmission of LFE hz into the floor is shifted away from some home structure resonant freq
"fewer complaints from house occupants and neighbors in apartments and townhouses" - what magic happens here? LFE energy from the sub still will get transmitted to the structure via air ....
some online reviews, like copy/paste among them:
http://www.pooraudiophile.com/2014/0...works-svs.html
http://hometheaterreview.com/svs-sub...tter-neighbor/
http://www.bigpicturebigsound.com/SV...Hands-On.shtml
However no amazon reviews (as of Nov-11-2014)
http://www.amazon.com/gp/product/B00...1X4SM79YCHNX0E
mtbdudex is offline
post #163 of 165 Old 11-11-2014, 02:28 PM
Liked: 1770
No data = no dice.
These 'reviews' are just as valid as those that you can find for every piece of snake oil that exists. Long on subjective opinion, but not one objective measurement. When anyone claiming to be serious about sound has measurement tools there's no excuse for the lack of any corroborating measurements.
oneeyeblind and shadyJ like this.
post #164 of 165 Old 01-17-2015, 11:04 AM
Saril's Avatar
Quoted: 17 Post(s)
My comments there:
I have a rattle from my metal fireplace enclosure that I can't seem to get rid of. I have hardwood floors on a concrete slab. Although I'm skeptical, if the isolation system has worked for others, I'm willing to give it a try. Nothing to lose with the SVS return policy.
Saril is offline
post #165 of 165 Old 01-17-2015, 12:18 PM
Liked: 1770
That's because you're exposing the enclosure to long wavelength low frequency sound waves. They don't travel through the cabinet to the floor and then through the floor to the enclosure, they travel from the driver cone through the air. What the cabinet is sitting on won't change that. It might be possible to de-rattle the fireplace, but it also might not.
Svs
