Sub won't hook up to AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 10-04-2013, 06:47 AM - Thread Starter
coldsteel333's Avatar
So I have a denon x1000, Andrew jones L/C/R and will be using an m-audio sp 8 sub until I can afford a 12-15 inch sub. The sub was from a studio setup I had and I can't for the life of my figure out how to set it up. The sub has two phono cable input. I had a RCA to phone cable (cable) and tried to go from the zone 2 to hook ups and that didn't work. And the dedicated sub output on the denon only has 1 spot. I will take a picture of the back of the sub and post as well
coldsteel333 is offline
post #2 of 19 Old 10-04-2013, 06:53 AM - Thread Starter
[IMG][IMG]
post #3 of 19 Old 10-04-2013, 06:55 AM - Thread Starter
Also if I could get some advice on how to set the sub crossover and hpf bypasss.
post #4 of 19 Old 10-05-2013, 10:47 AM - Thread Starter
Bump. Please help.
post #5 of 19 Old 10-05-2013, 10:50 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
I don't know enough about balanced inputs, but I would imagine that there is some adapter you could get to convert from RCA to your balanced plugs (not sure).
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #6 of 19 Old 10-05-2013, 10:54 AM - Thread Starter
I have a 2 RCA to 2 phone. But the sub out on the denon only has one spot.
post #7 of 19 Old 10-05-2013, 11:26 AM
LastButNotLeast's Avatar
Quoted: 1487 Post(s)
Liked: 1085
Could try this:
http://www.radioshack.com/product/index.jsp?productId=2103850
Sub out is mono, so it shouldn't matter which input you use.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #8 of 19 Old 10-06-2013, 07:10 AM - Thread Starter
Tried going single RCA to single phono. Didn't work.
post #9 of 19 Old 10-06-2013, 07:31 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
Try the RCA SUB OUT on the Denon and use an RCA to XLR adapter.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #10 of 19 Old 10-06-2013, 09:42 AM
Liked: 1085
I see you had the cable.
Have you checked the Denon's subwoofer level (see manual, page 120)?
I remember my behringer dsp1124p had a switch for (IIRC) voltage output. It's possible your "monitor" sub requires more input that a "home" system can provide without an adapter of some kind, like the DSP.
post #11 of 19 Old 10-06-2013, 12:13 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi coldsteel333, a simple rca y cable should work. Connect the male end of the Y to X1000 subwoofer out and female ends to the two rca to phone cables. Power Switch to on and may sure the LED indicator lights up. For now set Auto Power to off, HPF Bypass to on, Level to half, Phase to 0 and Subwoofer to highest setting.,
JChin is offline
post #12 of 19 Old 10-06-2013, 07:56 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Seem to remember there's more than one way to wire a 1/4" plug. I note the pic shows TRS or XLR inputs; is your current RCA to 1/4" plug TRS or TS? I went looking and found this and wonder if could be your issue....http://www.livewire-usa.com/knowledge/faq.cfm
lovinthehd is offline
post #13 of 19 Old 10-06-2013, 09:29 PM
Liked: 1085
This is what I was talking about:
post #14 of 19 Old 10-06-2013, 10:13 PM - Thread Starter
I appreciate everyone's responses. I tried again to hook it up with the single RCA to single mono cable, double checked the sub level + 12 decibels. Denon also set to (LFE+main), no luck. I'm going to try the single to double RCA ~~~~> to the dual RCA to dual phone. Verified the phono cables are trs. I wish I had money to just get a regular sub at this point. This is a week now with no sub.
post #15 of 19 Old 10-06-2013, 10:42 PM
lovinthehd's Avatar
Liked: 4775
Going on the photos.....You did turn the gain up on the sub unlike in the photos, right? Also turn the crossover to max on the sub? Also turn the power on? smile.gif
post #16 of 19 Old 10-06-2013, 10:58 PM - Thread Starter
Yes thanks. The picture is just to show the hookups. I tried the knobs and switches in every possible scenario.
post #17 of 19 Old 10-06-2013, 11:06 PM
lovinthehd's Avatar
Liked: 4775
You going to try an XLR connection (and again you have to get the connector wiring as shown on the sub)?
You know that it worked last used in the studio? How was it set up there?
ps Just what sub make/model is it?
post #18 of 19 Old 10-06-2013, 11:22 PM - Thread Starter
Yes it work last time it was hooked up I had it hooked up to a Yamaha motif7 with two powered event monitors. It is an m-audio sp-8
post #19 of 19 Old 10-10-2013, 01:11 PM - Thread Starter
Thanks jchin, your advice worked. Now for setting this up for optimal sound with audessy do you recommend the same settings you listed before. Should I make any adjustments now that it's verified working. For reference I have Andrew jones towers and center.
