Looking for sub ideas for $200-300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-10-2013, 06:06 PM - Thread Starter
hokiebird2008's Avatar
Pretty simple, looking for a subwoofer for around $300 for new satellite speaker system. Only requirement that I know of is for sub to get up to 200hz. Speaker set is CA Minx 21s and room is roughly 20x16 ft, if that helps. Thanks for your attention and help.
hokiebird2008 is offline
post #2 of 15 Old 10-10-2013, 07:02 PM
Audiophile2k's Avatar
Liked: 46
This thread is dedicated to exactly that. http://www.avsforum.com/t/1396482/budget-subwoofers-discussions-opinions-and-questions-thread ...you might want to work your way backwards since many of the subs discussed at the beginning are no longer available.
Audiophile2k is offline
post #3 of 15 Old 10-10-2013, 07:19 PM - Thread Starter
Hey thanks. I found that already and have been looking through it but wasn't sure if the 200hz requirement is hard to come by or pretty standard. I was hoping for some suggestions rather than searching through tech specs of hundreds of subs.
post #4 of 15 Old 10-10-2013, 07:29 PM
Liked: 46
Well, if you are going to be lazy, lol...this is probably the best you can do within your requirements. http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
post #5 of 15 Old 10-10-2013, 07:45 PM
Brad Sutliff's Avatar
F12 is an awesome sub. I'd buy it from acousticsounddesign. $199. Free shipping no tax
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #6 of 15 Old 10-10-2013, 07:59 PM - Thread Starter
Thanks to both of you for the suggestion. You call it lazy, I call it efficient smile.gif
post #7 of 15 Old 10-10-2013, 08:46 PM
Urmomdotcom's Avatar
I've heard a lot of people liking the nxg bas-500. Not sure how much in the 100hz-200hz range is. But from what I gather it's the best under $300 sub right now.
http://www.amazon.com/NXG-Technology-NX-BAS-500-500-watt-Subwoofer/dp/B008FSTU4G/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=17OV49U2EBW8P&coliid=I130MC2OEHIHFL
Urmomdotcom is offline
post #8 of 15 Old 10-10-2013, 08:54 PM
Liked: 46
upper limit of 120hz on that one...not a lot of good budget options other than the F12 will both go below 30hz and up to 200hz.
post #9 of 15 Old 10-10-2013, 09:10 PM
Bond 007's Avatar
Quoted: 2373 Post(s)
Liked: 1909
If youre happy with that Minx 2.1 system youll be happy with an F12. What happened to the sub that came with it?
Licence to Kill
Bond 007 is online now
post #10 of 15 Old 10-10-2013, 09:16 PM - Thread Starter
I'm buying the entire set piece-meal. Didn't want the Minx setup because I felt like I could get better sub and receiver on my own instead of sticking with CA products. Any thoughts on the PL-200. Everything I find says it out performs the F12 for a nominal increase in price. Thoughts?
post #11 of 15 Old 10-10-2013, 09:23 PM
Bond 007's Avatar
Liked: 1909
The PL will outperform the F12.
Licence to Kill
post #12 of 15 Old 10-10-2013, 09:31 PM
Liked: 46
The PL-200 is almost $100 more and while it play about 5hz lower than the F12, its main advantage is that it has higher output, but matching with those speakers the extra output would be wasted...that is why I suggested you save $100 and get the F12
post #13 of 15 Old 10-10-2013, 09:41 PM - Thread Starter
Very good guys. I truly appreciate the candid responses. Think I'm going to give the 200 a try even though it's more expensive, it's higher output will put less stress on the unit to fill the room which leads me to believe the sound would be more pure. Also allows for a bit more flexibility for future HT upgrades.
post #14 of 15 Old 10-10-2013, 11:43 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2991
I think that's a good strategy. I have seen people that have heard both the BIC PL-200 and the BIC F12 describe the PL-200 as having better SQ.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #15 of 15 Old 10-11-2013, 09:45 AM
The pl200 and h100 had a little help from hsu, thus better sq.
Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
