Rythmik FV15HP or PC-13 Ultra - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #181 of 249 Old 01-23-2014, 11:15 PM
Goat1's Avatar
Lmao... I knew it! I was going to suggest you try a new receiver, until I got to this post. Get a new receiver like an onkyo 818 with xt32 on it. It will tame that sub and it will sound nice and tight...
Goat1 is offline
post #182 of 249 Old 01-24-2014, 12:17 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
You don't think his Onkyo 5010 has XT32?
So much for the vaunted CA 751R.....commysysman is going to be very unhappy wink.gif
Kini62 likes this.
lovinthehd is offline
post #183 of 249 Old 01-24-2014, 03:37 AM
tanbyte's Avatar
Quoted: 29 Post(s)
Originally Posted by eljaycanuck View Post
2. Props to you for offering to pay Brian for the replacement amp + shipping. cool.gif
+1
tanbyte is offline
post #184 of 249 Old 01-24-2014, 04:23 AM - Thread Starter
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
CA is a big joke in AV industry. I think they should be banned or at least educated what bass management is. Anyway, I don't use XT32 and SubEQ HT. I only use DynamicEQ function. For bass duties, I prefer keeping things in my hand.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #185 of 249 Old 01-24-2014, 08:41 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 235 Post(s)
Liked: 319
Brave, try 1 port mode. I know you have been insistent on using the max output 2 port mode. The max output mode has a lot more ringing than the 1 port mode. Two port mode is designed for customers wanting very "full-body" bass (the opposite of sealed subs). If you want to get FV15HP sound close to a sealed sub, 1 port mode high damping is what I benchmarked against our F15HP. From all of your posts, I figure you like clear and articulate sound, and part of that is related to the ringing in the impulse response. In addition, the lower you play, the more complete sound stage you can hear. We have this extension mode switch for over 10 years now. What the switch does for us is to increase the sound stage depth and height. Some customers can hear that and I am pretty sure you are one of them.
Rythmik is offline
post #186 of 249 Old 01-24-2014, 11:10 AM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
Hi Brian, thanks for your help. Rythmik has that IT factor that I was looking for. As I told you before, the problem was with my AVR. With the new AVR, the sub is performing as I wanted it to. I know Low Damping engages the steepest HPF slope, which jacks up GD thus causing ringing. But even with all this, your engineering is spot on. Bravo!!!
I will try all the options. I'm just caught up so much in work that um hardly finding time to run it through paces.
post #187 of 249 Old 01-24-2014, 07:46 PM
Goat1's Avatar
No the Cambridge.
Goat1 is offline
post #188 of 249 Old 02-02-2014, 10:37 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
Now that it's been quite some time I've spent with Rythmik; here are my thoughts. I'll keep it brief and to the point.
THE GOOD
- It is a fantastic sub FOR THE MONEY.
- Staggering amount of power.
- Tons of intuitive configurations.
- Good sized box, not too big to be branded as eye sore even in my tiny room (1700 cu ft)
- 5 star for fantastic high gloss paint job.
- ZERO box resonance.
THE BAD
- Now this is purely subjective as my main preference is high output in the audible frequency range BUT with accuracy. My use is purely movies. While this sub belts out some serious energy (2 ports / 14Hz / Rumble Filter On / Low Damping / LFE Input / Limiter Off), the steep slope associated with low damping jacks up Group Delay way too much for my liking and gives away accuracy. GD jumps North of 70 ms at around 20Hz, which is a bit too much for my taste. I found it a bit mushy and muddled with those settings. While High and Mid damping make up for this shortcoming, but they also reduce the output in the ULF region.
- All other settings are useless for me. Although, I have great depth down to 12Hz with (1 port plugged / 14Hz / Rumble Filter Off / (High/Mid) Damping / Limiter Off), but that was never my requirement.
The Ugly
- None
My Final Thoughts
If were to do it all over again, I'd go for JTR OS LFU if size was no constraint. Alternatively, PSB SubSeries 500 would be my top choice. That is the most accurate sub in audible frequency range I've ever heard, deceptively loud for its size, and deadly accurate. While Rythmik is a great sub, it just didn't cut it for me.
post #189 of 249 Old 02-03-2014, 02:46 AM
steve nn's Avatar
Liked: 433
^^ Regardless of the sub, that’s some real honesty I can respect. I notice on a daily bases when the tune goes down, GD rises in most cases and wants to rise. Add a filter, higher yet.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #190 of 249 Old 02-03-2014, 07:11 AM
tcramer's Avatar
Quoted: 274 Post(s)
Liked: 119
Indeed, thanks for the great and honest review.
While there is a good chance I will still end up getting a pair of the Rythmik's, it's good to know there may be a downfall or 2.
JVC DLA-RS600, 110" Stewart Cima Neve, Oppo UDP-203, TiVo Bolt, Denon X4300H
Dual Rythmik FV15HP, Energy Veritas Fronts and Surrounds, 4x RSL C34E for Atmos
tcramer is offline
post #191 of 249 Old 02-03-2014, 08:11 AM
dominguez1's Avatar
Quoted: 918 Post(s)
Liked: 640
Braveheart, sorry if I missed, but do you have group delay graphs of your room with the Rythmik and PSB? It would be interesting to understand your preference through the lens of that data.
It will also let other have some more insight to potentially help improve your situation.
dominguez1 is offline
post #192 of 249 Old 02-03-2014, 11:20 AM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
Here is GD measured at 6" from cone center with 2 ports open / 14Hz / Low damping / LFE Input / Limiter Off / Rumble Filter On
It's even higher at MLP
post #193 of 249 Old 02-03-2014, 11:35 AM
nirvana_av's Avatar
All ported subs will result in group delay. It's the nature of the beast.
nirvana_av is offline
post #194 of 249 Old 02-03-2014, 12:49 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
I know that, but anything above 50 ms @ 20Hz is a lot for me. And, at the same time, anything below 35 ms @ 20H is way too tight for me. It is the steep slope associated with Low Damping (HPF Slope) in this sub, which jacks up GD way too much. I build mine with GD not exceeding 50 ms. For me ideal is between 40-45 ms max, which doesn't give away accuracy while still ensuring high output.
post #195 of 249 Old 02-03-2014, 01:03 PM
BeeMan458's Avatar
Liked: 813
I know nothing about GD. What's GD and how am I being hosed by it and what is it trying to tell me?
MLP: 200ms at 11Hz. 55ms at 20Hz. 477ms on the peak at 50Hz.
Group Delay, No Smoothing
Spectrogram
Graph, No Smoothing
Regarding GD, what is my takeaway suppose to be?
BeeMan458 is offline
post #196 of 249 Old 02-03-2014, 01:06 PM
steve nn's Avatar
Liked: 433
This in no way is intended to come across as snarky. I could just about take any driver and sim it up showing you what happens regarding my prior post. Of course there is no doubt that ID takes this into account and battles against it the best they can.. but like with all design's, it’s all about compromises to one degree or another. It’s a ardent fact.. The bummer is in choosing a driver coupled with the design might be good in one area, but then it brings up another problem in another area all to often. Coming up with the perfect combination is a impossibility because it can’t be so. A guy/Co. can only do the best they can can taking everything into account.
EDIT> Bee you just posted, this is not a arrow directed towards you.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #197 of 249 Old 02-03-2014, 01:08 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
+1
post #198 of 249 Old 02-03-2014, 01:17 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
Spectrogram
Graph, No Smoothing
GD in your case is low at 20Hz for the very reason that you are using your subs in 1 port / 14Hz / High damping. It is most discernible 30Hz and below. At 30Hz it is still below 25 ms. In my case (2 ports open / 14Hz / Low damping / Rumble Filter On), it is around 45 ms even at 30Hz, which is high. Hence the reason for less accurate response in 20Hz-31.5Hz region, though it does offer high output.
post #199 of 249 Old 02-03-2014, 01:36 PM
BeeMan458's Avatar
Liked: 813
And what is an ignorant like me to takeaway from the above information?
(the above information is based on two FV15HPs banging away in the room)
And is that 50Hz peak suppose to concern me or is that just part of life?
post #200 of 249 Old 02-03-2014, 01:49 PM
steve nn's Avatar
Liked: 433
(the above information is based on two FV15HPs banging away in the room) And is that 50Hz peak suppose to concern me or is that just part of life?
This is directed at you Bee.. Like in many of your posts you have a knack of making blanket statements that supposedly is supposed to translate out to be the experience of all the rest of the members.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #201 of 249 Old 02-03-2014, 01:51 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
We all are ignorant one way or the other biggrin.gif Anyway, GD is related to accuracy. It is most noticeable in the 20-31.5hz region and is directly proportional to output and inversely proportional to accuracy.
post #202 of 249 Old 02-03-2014, 01:52 PM
BeeMan458's Avatar
Liked: 813
I have no idea what you're reading but that's not what the above quote is communicating. Nothing in it refers to anybody else. confused.gif Everything in my above refers only to my personal experiences and nobody else's.
If I might suggest, read the quote, with my above comment in mind.
post #203 of 249 Old 02-03-2014, 01:56 PM
BeeMan458's Avatar
Liked: 813
I'm okay with being ignorant. I was born ignorant and the more I learn, the more ignorant I become. I really do hate that point. tongue.gif
Without killing yourself, could you elaborate a bit more on GD and what it is.
I got the accuracy part and as the volume goes up, GD is increased but what am I suppose to notice?
post #204 of 249 Old 02-03-2014, 01:59 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
This is for Bee;
This is single FV in my room with 1 port plugged / 14Hz / Rumble FIlter and Limiter Off / High Damping. On paper this looks amazing but GD is 23 ms at 20Hz, which means it is way too tight for my taste and I have to sacrifice full bodied sound. That I can't wink.gif
post #205 of 249 Old 02-03-2014, 02:02 PM
steve nn's Avatar
Liked: 433
A suggestion, try reading the quote, without your bias' in mind.
Your wrong there also. I just try to look at things from all angles. I run a low tuned sub now (although dual PR) and many in the past. Do you think my Avatar sub came in at a 25hz tune? (The room has a effect amongst other things) What I’m trying to get at is it comes down to choices and what you consider or experience doesn’t have any bearing what-so-ever on the general facts of the matter. I can beat my sub up just as easily as yours if your taking things that way.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #206 of 249 Old 02-03-2014, 02:05 PM
BeeMan458's Avatar
Liked: 813
Let's start over. I am totally clueless what you're referring to as the comment you quoted was in response to a comment made by braveheart123 and at no time was it in response to any of your comments.
All of my comments were directed toward the measurements of mine that I posted so braveheart123 could see what I was working with.
Who's beating up their subs? I wasn't beating up my subs. I don't know anybody who's beating up their subs.
All I did was ask a question of another forum member and all of a sudden I'm in an argument and don't know why?
post #207 of 249 Old 02-03-2014, 02:08 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
GD is all about how tight or loose the bass response is. It is not the function of volume or loudness.
A useful write up on GD;
http://www.audiodesignguide.com/Sub/SIGroupDelay.pdf
post #208 of 249 Old 02-03-2014, 02:11 PM
BeeMan458's Avatar
Liked: 813
(oh boy. more homework)
post #209 of 249 Old 02-03-2014, 02:24 PM
steve nn's Avatar
Liked: 433
I see you edited your post, but I copied prior. I’m not going to get into bias because I already addressed it. Lets just move on if that’s Ok with you? I don’t want to derail Braves thread..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #210 of 249 Old 02-03-2014, 02:26 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 273
Come on guys.......cheer up. I should be the one pulling my hair biggrin.gif
Fv15hp Subwoofer , Svs Pc12 Ultra , Svs Pb13 Ultra , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs , Rythmik Audio , Rythmik
