Question about subwoofer - AVS Forum | Home Theater Discussions And Reviews
Old 10-20-2013, 04:19 PM - Thread Starter
Snoopy10's Avatar
Hello,
I have been thinking about adding a subwoofer to my sound stage and have a question about the placement. I have my TV against a wall that has a dip and was wondering if it would be okay to put my subwoofer behind the tv in the dip. Here is a picture of what I'm talking about.
Snoopy10 is offline
Old 10-20-2013, 05:44 PM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
Originally Posted by Snoopy10 View Post
Hello,
It probably wouldn't be ideal. I would expect highly inconsistent coverage (nodes and nulls), and it would boost whatever frequency the proximity to all those corners favored. It could also cause the whole installation to resonate.
Try it if you want, worst thing that happens is you don't like it, and have to move it somewhere else,
ermghoti is offline
Old 10-21-2013, 02:43 AM
derrickdj1's Avatar
Quoted: 883 Post(s)
Liked: 594
I favor trying it. The sub in the corner will give you the most output. This may or may not give you the cleanest bass. Like the other poster said, give it a try.
derrickdj1 is offline
Old 10-21-2013, 06:47 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I had my SVS out in the main seating area for a while, kind of to the right of your picture, against the right hand wall, and the bass was okayyyy but nothing to write home about.
When I moved it into the alcove it seemed to provide a real boost to the output! smile.gif
As above, it can be a bit peaky across the room but as I only ever sit along one row of seats, I'm not too fussed if it's louder in the opposite corner and quieter halfway down the room, as long as the output is decent at the sitting position!
In my head it is 1/16th space - i.e. sub on a floor is half space, sub on a floor next to a wall is quarter space, sub on a floor in a corner is 1/8th space... so with an additional wall on the other side, it must be effectively 1/16th space, I think?? Therefore it should provide a good boost to output, albeit slightly peaky at points!
I have Audyssey EQ32 and it has helped tame some of the resultant peaks in frequency response smile.gif
MemX is offline
Old 10-21-2013, 07:10 AM
eljaycanuck's Avatar
Quoted: 1234 Post(s)
Liked: 1808
I ... have a question about the placement. I have my TV against a wall that has a dip and was wondering if it would be okay to put my subwoofer behind the tv in the dip.
Give it a try. If it works, leave the sub there; if it doesn't work, move the sub to another location.
eljaycanuck is online now
