Best Sub: $1500 budget, ONE sub, small footprint. GO! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 10-20-2013, 07:02 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
Room size is 18' x 29'(only half the length of the room is the TV area), 9' and 10' ceilings. I know everyone will say to get 2 subs but I only want one so what's my best bet.
lees23 is offline
post #2 of 32 Old 10-20-2013, 07:16 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
What's the for print size you can work with? 2'x2'? One great sub with a small footprint is the SVS PC12-Plus. It may still be an aesthetic clash in your room though.
steve nn likes this.
shadyJ is offline
post #3 of 32 Old 10-20-2013, 07:17 PM
steve nn's Avatar
Liked: 433
+1
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 32 Old 10-20-2013, 07:27 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
Thats exactly what I am thinking of buying, just seeing if anyone has other ideas. I have gone through the gamut here, Rhythmik FV15HP (decided footprint is too big), SVS SB 13 Ultra(not enough output), 2 smaller SVS subs(don't want 2 subs) so I think I have decided on the SVS cylinder. Is the PC 13 Ultra worth the extra expense over the PC 12 Plus?
lees23 is offline
post #5 of 32 Old 10-20-2013, 07:31 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
How do the PC's compare with the PB subs from SVS? I know the footprint is much bigger for PB but just curious how the sound and output differ?
lees23 is offline
post #6 of 32 Old 10-20-2013, 07:33 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
Its worth it if you listen loud for sure, I have the pc12 plus and it does very well in my 13x25 room but it shows its limits when pushed
current setup: Integra 50.4 avr, PSA 210t L/R, PSA 210, 4 volt 10's in slant box style, 3 svs pc13 ultras, epson 5030ub with 92" AT screen diy spandex cloth
jwtallguy is offline
post #7 of 32 Old 10-20-2013, 07:39 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
Is your sub "corner loaded"?
lees23 is offline
post #8 of 32 Old 10-20-2013, 07:41 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
Up untill the pc 13 ultra they are the same the pb13ultra digs a bit deeper but its not anything you'd notice without measuring from what ed from svs told me
post #9 of 32 Old 10-20-2013, 07:43 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
It is 6" off the wall and 2 feet from the corner
post #10 of 32 Old 10-20-2013, 07:44 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
I plan to upgrade next year to the ultra myself
post #11 of 32 Old 10-20-2013, 07:46 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
I figured that they would be very similar. Thanks
lees23 is offline
post #12 of 32 Old 10-20-2013, 07:48 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
You do that for aesthetics or smooth response?
lees23 is offline
post #13 of 32 Old 10-20-2013, 08:00 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
Both I only had one area to put it and it was smoother away from the corner but its only 2ft from the couch
post #14 of 32 Old 10-20-2013, 09:52 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5213
The PC13Ultra will have another 3db across the board...so basically more headroom. Here is a PC13Ultra B-stock for 1549.00 and still has the full 5yr warranty.
http://www.svsound.com/outlet-specials?page=shop.product_details&flypage=flypage.tpl&product_id=179&category_id=5
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #15 of 32 Old 10-21-2013, 05:12 AM
BeeMan458's Avatar
Liked: 813
Out of curiosity, how can one be expected to give a rational reply when one is given specifications that are not rational? confused.gif
Hypothetically, one buys a single sub and sets it up in listening space. Due to room acoustics and how subwoofer sound waves interact in a room, expectedly they will have terrible results. And then the individual will want to know, why in their large room is their single subwoofer giving such such terrible results? The simple reply, because they haven't taken the time to deal with their room's acoustics and because of this the subwoofer's output is being messed up.
In response to your question, there is no reasonable response because within your budget, due to your specifications, you've set yourself up for fail. Why would anybody do that? confused.gif
If you just want a subwoofer, pretty much anything vented in your price range (SVS, Rythmik or PSA), will give quality sound reproduction but before shooting yourself in the foot, may I suggest you reconsider your specifications?
BeeMan458 is offline
post #16 of 32 Old 10-21-2013, 05:33 AM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
No
oneeyeblind likes this.
lees23 is offline
post #17 of 32 Old 10-21-2013, 05:57 AM
BeeMan458's Avatar
Liked: 813
Then I can't help you but the best in your quest.
post #18 of 32 Old 10-21-2013, 03:30 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
This is the most sub per square inch of floor space you're going to find. I have the PC12+ version in a small(ish) room and it's incredible.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #19 of 32 Old 10-21-2013, 04:06 PM
Quoted: 73 Post(s)
Liked: 112
Another vote for the SVS cylinder.
rnatalli is offline
post #20 of 32 Old 10-21-2013, 05:53 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
I respect what you are saying, but If you are looking at the cylinder, I would consider the PSA XV-30f another would be the PSA XS-30. Both on the money. I would get as much sub as you can, because you are going to want more in a year. Trust me.
Reefdvr27 is offline
post #21 of 32 Old 10-21-2013, 06:39 PM
BeeMan458's Avatar
Liked: 813
Originally Posted by Reefdvr27 View Post
I would get as much sub as you can, because you are going to want more in a year. Trust me.--
And that's a check you can take to the bank and cash every working day the bank is open. tongue.gif
post #22 of 32 Old 10-21-2013, 06:53 PM
Ozzie Isaac's Avatar
Liked: 101
Lees23 -
Let me translate Beeman for you. You want good output/extension in 6000ft^3 for $1500. Pretty much any of the ID companies will give similiar results in your space (I would got ported, not much room gain in your space for sealed). Notice I said similiar, not great (by AVS standards). Pick one that fits your aesthetics and begin saving for another one.
Ozzie Isaac is offline
post #23 of 32 Old 10-21-2013, 07:07 PM
steve nn's Avatar
Liked: 433
Originally Posted by Ozzie Isaac View Post
Lees23 -
+1 That works for me. You really ought to go the PR.. no we won’t get into that. just playin rolleyes.gifbiggrin.gif
oneeyeblind and Ozzie Isaac like this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #24 of 32 Old 10-21-2013, 07:23 PM
Oledurt's Avatar
Quoted: 197 Post(s)
Liked: 287
The Rythmik F25. small footprint. Accurate bass. Great price $1399. I love my Rythmik f15hp.biggrin.gif
http://www.rythmikaudio.com/F25.html
Oledurt is online now
post #25 of 32 Old 10-21-2013, 07:31 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
How long have u had ur fv15hp? I just ordered 2
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
post #26 of 32 Old 10-21-2013, 07:54 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5213
He said a F15HP, that model is sealed.
post #27 of 32 Old 10-21-2013, 08:31 PM
Oledurt's Avatar
Quoted: 197 Post(s)
Liked: 287
I have a Rythmik F15HP not the FV15HP. I also use the HSU MBM 12 MK 2 for midbass. I love the rythmik sub it is the cleanest most accurate sub I have ever owned by far. Can't go wrong with rythmiks.
post #28 of 32 Old 10-27-2013, 06:17 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
HSU ULS-15 is a FANTASTIC sub.
Lumenlab "Community driven video lab".
blake18 is offline
post #29 of 32 Old 10-27-2013, 01:18 PM - Thread Starter
lees23's Avatar
Quoted: 20 Post(s)
A little concerned about a sealed sub in such a big room.
lees23 is offline
post #30 of 32 Old 10-27-2013, 03:11 PM
GunmetalR56's Avatar
Quoted: 162 Post(s)
Liked: 215
I'd go FV15HP or XV30f based on your criteria. I have a 30f in a similar scenario where tv room is half the total room size but with 22' ceilings.. around 8k^3. The 30f gets plenty loud...I'm not stressing it.. but the room really saps the output under 30Hz.
One of those subs in your room shouldn't sound bad at all. You might run into a desire to get a 2nd sub for more even coverage down the road but then again you may not. I doubt you'd find the output of the 1 sub lacking unless you turn out to be an uber bass head. wink.gif
Ascend Sierra Towers w/RAAL, Ascend Horizon Center w/RAAL, Ascend CBM-170 SE surrounds, PSB Imagine XA Atmos modules (x4)
SVS PB12 Plus (x2) PSA XV15SE (x2)
Denon X4200w / Emotiva Mini-X a-100
Samsung UHD BD K8500 / PS4 Pro
Sony XBR75X940C
GunmetalR56 is offline
Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Fv15hp Subwoofer , Xs30
