I'm BACK!!!! But with a dilemma...SVS-PB-13 related. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-24-2013, 10:58 AM - Thread Starter
bgillyjcu's Avatar
Quoted: 30 Post(s)
Hope everyone is doing well! I just moved into my new house and the basement is a man cave dream come true.
800-900sqft of open space and I have the theater already set up!
Mitsubishi HC4900 paired with a 100inch screen. SVS-SCS-01's across the front with SBS-01s as surrounds, and a PB-13Ultra as my boom box. All dialed in to a nice 75db.
Last night I watched IRONMAN 3 as my first movie in the new space and wow did it sound amazing....except one aspect....the bass. It was there, but my rumbling boom was sort of gone.
The room is large and open, volume probably pushing 4500cu ft, and my subwoofer placement is along the wall where the screen is, but unfortunately I have no real corner near. Also, my seating is 10.5ft from the screen, but the couch is no where near the back wall, thus we are kind of sitting in the middle of the room...
I plan to get home and get out Room EQ Wizard and try to figure out what is going on....but I fear the problem might be the sheer volume of the room, and what my expectations are for the sub.
Right now it is dialed in at 75db, gain is at about 1/4 of the way up, phase at 0.
We'll see...I'll report back....but in the meantime...does anyone else have this sub in a room this size and shape? Thoughts, Comments, Suggestions
Twitter @ Clefoodandbrews
bgillyjcu is offline
post #2 of 10 Old 10-24-2013, 12:58 PM
PoppaC's Avatar
Quoted: 29 Post(s)
Liked: 40
If I am looking at this correctly, your seating position is pretty much in the middle of the room?
PoppaC is offline
post #3 of 10 Old 10-24-2013, 01:37 PM
Kini62's Avatar
Quoted: 1740 Post(s)
Liked: 1554
Is this a bash amp PB?
The PB13 should have no problems in that size room (unless you're a real bass head smile.gif )
You might have to do a sub crawl as well as the REW.
One other factor is Ironman 3 doesn't have much output below 30hz, so you can't expect a lot of low frequency rumbling.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #4 of 10 Old 10-24-2013, 02:57 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
I see that too, looks to be at or close to the center of the room and that would be problematic....
bjillyjcu,
Are you able to move that sofa to see if it improves your boom?
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #5 of 10 Old 10-24-2013, 03:29 PM
PoppaC's Avatar
Quoted: 29 Post(s)
Liked: 40
I did a quick search for "null in middle of room"
This is one thread I found, but there are others:
http://www.avsforum.com/t/1164907/sub-is-void-in-middle-of-the-room.
Unfortunately, the better seating position would probably be about where the pool table is.
If you have no other options, you may want to go with a wireless adapter and put the sub near field (like an end table of one side of the sofa).
PoppaC is offline
post #6 of 10 Old 10-24-2013, 04:25 PM - Thread Starter
bgillyjcu's Avatar
Quoted: 30 Post(s)
Unfortunately I can move the seating position. REW helped a lot, and I moved the sub a bit and used my 1124 and things are much improved. I am a bass head, coming from a theater 1/5 the size. I will enjoy what I have for now and get another pb13 hopefully in the next year.
post #7 of 10 Old 10-24-2013, 04:32 PM
derrickdj1's Avatar
Quoted: 992 Post(s)
Liked: 731
Now that is the real solution!
derrickdj1 is offline
post #8 of 10 Old 10-24-2013, 07:19 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
I have 2 pb13-ultras on the way.... so I would agree with you eventually getting a 2nd one. smile.gif
Luis5150 is offline
post #9 of 10 Old 10-25-2013, 06:52 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Hey Brad, been a long time. I don't get here as much as I used to now that I have my own business. Well, you know my recommendation to solve large-space sub issues. Near field placement. You called the room a man cave, so function over form should rule.smile.gif
oneeyeblind likes this.
Randy
ransac is offline
post #10 of 10 Old 10-26-2013, 01:13 AM
DrPainMD's Avatar
Liked: 27
welcome back biily and ransac
ive been away for awhile also
super dirty , super clean , pow
DrPainMD is offline
Svs Pb13 Ultra
