Subwoofer Volume - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-28-2013, 05:04 PM - Thread Starter
metallifan24's Avatar
Hey everyone! I have a question about subwoofer volume. When i connect my pioneer s-dw1-k to my amp yamaha rx-v850 via LFE i have to turn the volume all the way to max but when i connect with the high level inputs via speaker wire i only have to turn it to about half or so...i'm just wondering why this is and if something isn't connected right...Thanks!
metallifan24 is offline
post #2 of 7 Old 10-28-2013, 06:23 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Google 'gain structure'. There's more gain using the second option. Turn up the LFE output volume. There's also no filtering of the above bandwidth content using the speaker level inputs, and that added content will make it louder.
Bill Fitzmaurice is offline
post #3 of 7 Old 10-28-2013, 10:26 PM - Thread Starter
Thanks for the reply! well my receiver doesn't have gain control for the subwoofer...I've had the subwoofer hooked up to a couple other receivers and didn't have a problem like this, Is their another way to hook it up or am i just missing something here? On the back of the receiver it says low pass 200hz
post #4 of 7 Old 10-29-2013, 06:17 AM
Liked: 5687
well my receiver doesn't have gain control for the subwoofer...On the back of the receiver it says low pass 200hz
Ouch. Get a new receiver. Yours is not an x.1.
post #5 of 7 Old 10-29-2013, 06:56 AM - Thread Starter
Darn it...I have dolby surround on it and have it connected with the front mains,center and rears also on the manual it says i can hook up a subwoofer to it but it doesn't go into great detail about it. Sucks cause i really like the receiver its solid!
post #6 of 7 Old 10-29-2013, 08:14 AM
Liked: 5687
Surround, yes, but with no LFE decoding and output you'll never get the results you want.
post #7 of 7 Old 10-29-2013, 08:30 AM - Thread Starter
Ah i see ok thank you very much
