How to connect sub OmniS8 Mirange to receiver Piooner VSA D10TX - AVS Forum | Home Theater Discussions And Reviews
Old 10-29-2013, 12:42 AM - Thread Starter
vuthanhtung3010's Avatar
I need help  sub mirange with only one input kết nối đến receiver Piooner VSA D10TX
vuthanhtung3010 is offline
Old 10-29-2013, 05:41 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
Run a connection:
- from the "SW" (subwoofer) pre-output on the Pioneer receiver (see the image on pg. 1 of this set-up sheet (PDF));
- to the "SUB INPUT" on the Mirage subwoofer.
eljaycanuck is offline
Old 11-02-2013, 01:42 AM - Thread Starter
I did with your show but sub not signal ,
Old 11-02-2013, 06:07 AM
Liked: 1798
Have you confirmed that, according to your owner's manual, the settings in the receiver's speaker set-up menu are correct (for example, subwoofer is set to "on" or "yes", etc.)?
Is your sub plugged in and powered on? Is the "FILTER" switch set to "off"? (This disables the sub's internal low-pass filter (a.k.a. "crossover"), which is what you want given that the receiver is handling all crossover functionality.) Set the level of the sub to "noon" position to start.
vuthanhtung3010 likes this.
Mirage Omni S8 8 Inch 400 Watt High Performance Subwoofer
