Need help choosing s sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 10-29-2013, 07:46 AM - Thread Starter
mcarciero's Avatar
Which would you choose?
I like tight clear base
1. Infinity Primus PS410 ($150)
2. Klipsch RPW-10 ($160)
Please dont refer others as these are the only 2 I can choose from right now.
mcarciero is offline
post #2 of 40 Old 10-29-2013, 07:47 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
basshead81 is offline
post #3 of 40 Old 10-29-2013, 07:50 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
Infinity Primus PS410:
- 300W RMS amp
- 10" driver
- 27-150Hz +/-3dB
Klipsch RPW-10:
- 200W continuous amp
- 10" driver
- 35-120Hz +/-3dB
Based on the specs, I'd take the PS410.
eljaycanuck is offline
post #4 of 40 Old 10-29-2013, 07:52 AM
steve nn's Avatar
Liked: 433
+/- ?dB
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #5 of 40 Old 10-29-2013, 07:54 AM
Liked: 1962
-- Edit --
I checked the owner's manual and it does say +/-3dB. So I'll update my previous post.
post #6 of 40 Old 10-29-2013, 07:56 AM
steve nn's Avatar
Liked: 433
Originally Posted by eljaycanuck View Post
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #7 of 40 Old 10-29-2013, 08:04 AM - Thread Starter
mcarciero's Avatar
whats the difference between continuous amp and RMS amp?
post #8 of 40 Old 10-29-2013, 08:08 AM
steve nn's Avatar
Liked: 433
-- Edit --
Good old eljay slaps me down again lol biggrin.gifrolleyes.gif lol
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #9 of 40 Old 10-29-2013, 08:14 AM
Liked: 1962
post #10 of 40 Old 10-29-2013, 08:16 AM
Liked: 1962
I don't know what purely technical difference there is, if any, but the two terms (continuous and RMS) seem to be used interchangeably to indicate an amplifier's steady-state (as opposed to peak) power rating.
post #11 of 40 Old 10-29-2013, 08:17 AM
Bill Fitzmaurice's Avatar
Liked: 5684
- 300W RMS amp
- 10" driver
- 27-150Hz +/-3dB
Klipsch RPW-10:
- 10" driver
- 35-120Hz +/-3dB
Based on the very limited available specs there's no way to make an informed choice. Based on the price I wouldn't have high hopes for either.
Bill Fitzmaurice is offline
post #12 of 40 Old 10-29-2013, 08:22 AM
Liked: 1962
The question was "Which [of the two] would you choose?", not "Are the available specs sufficient to make an informed choice?"
Price favours the Infinity; the specs appear to favour it, too.
post #13 of 40 Old 10-29-2013, 08:28 AM
BeeMan458's Avatar
Liked: 813
Based on your request, the Infinity Primus PS410 but due to your limitations, I suspect you won't get your wish.
BeeMan458 is offline
post #14 of 40 Old 10-29-2013, 08:33 AM
Liked: 5684
Such as they are, but as they leave out all the important details necessary to actually compare what the two are capable of they're of little to no value. That said, for the same driver size, similar cabinet size, less than a 2:1 power differential and a similar suggested retail price there's likely no significant difference between them.
post #15 of 40 Old 10-29-2013, 08:36 AM - Thread Starter
mcarciero's Avatar
Thanks guys.
Looks like the infinity is the one I will go with
post #16 of 40 Old 10-29-2013, 08:39 AM
Liked: 1962
So, what you appear to be saying - in a much more verbose way than basshead81 did - is "flip a coin". Fair enough. smile.gif
SaviorMachine likes this.
post #17 of 40 Old 10-29-2013, 08:49 AM - Thread Starter
mcarciero's Avatar
Came across an Energy EW-100 as well. Any thought?
post #18 of 40 Old 10-29-2013, 08:52 AM
BeeMan458's Avatar
Liked: 813
Downgrade over your original two choices.
post #19 of 40 Old 10-29-2013, 08:53 AM
Liked: 1962
According to the product page:
- 55W continuous amp
- 10" driver
- 29-120Hz +/-3dB
I'd pass on it.
post #20 of 40 Old 10-29-2013, 08:54 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6519
No..I will refrain from referring to any other subs per the request in your OP. wink.gif
eljaycanuck likes this.
post #21 of 40 Old 10-29-2013, 06:02 PM
steve nn's Avatar
Liked: 433
Man I wish I could of been here today. I think all of us was messin with the squatch in this thread. smile.gifbiggrin.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #22 of 40 Old 10-29-2013, 06:23 PM
Hopinater's Avatar
Quoted: 2294 Post(s)
Liked: 5711
I'm not sure you are going to get tight clear bass with either of the choices, not sure it can be had at such prices. But of the two I would take the PS410.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #23 of 40 Old 11-04-2013, 08:53 AM - Thread Starter
mcarciero's Avatar
so you were dead on balls accurate. I got the rpw 10. its got nice bass but its not as tight and loud as I wanted. it does rumble quite abit though.
im gunna resell it. what do you recommend?
post #24 of 40 Old 11-04-2013, 09:13 AM - Thread Starter
mcarciero's Avatar
I can get a subwoofer used Velodyne DPS-12 for $250.
post #25 of 40 Old 11-04-2013, 09:14 AM
Hopinater's Avatar
Liked: 5711
^ what's your budget and how large is your room?
Right off the bat I would say if you can swing it I would look at HSU and SVS. It's a bit more but I think in order to get what you want you have to increase the budget.
post #26 of 40 Old 11-04-2013, 09:34 AM - Thread Starter
mcarciero's Avatar
I had a feeling it was those. Abit pricey for me. Is there are online source that I may find for cheaper? I live in Canada
post #27 of 40 Old 11-04-2013, 10:05 AM
Hopinater's Avatar
Liked: 5711
You might find something on Accessories 4 less.
http://www.accessories4less.com/make-a-store/category/SpeakersStands/Speakers-Stands/1.html
post #28 of 40 Old 11-04-2013, 11:14 AM - Thread Starter
mcarciero's Avatar
I checked and can only find Boston Acoustic, Kef and Mordaunt.
Are all these better options?
post #29 of 40 Old 11-04-2013, 12:02 PM
Hopinater's Avatar
Liked: 5711
I can't really say I have never heard any of them. I have never even heard of Mordaunt. Perhaps this link to the Velodyne site and their refurbished subs. The impact 12 looks pretty good and the impact 10 has a good review over at Audioholics, its an old review but it might give you an idea.
Velodyne site: http://velodyne.com/special-offers/certified-refurbished.html
Audioholics review: http://www.audioholics.com/subwoofer-reviews/velodyne-impact-10-subwoofer-video
post #30 of 40 Old 11-04-2013, 12:06 PM
Quoted: 75 Post(s)
Liked: 112
The HSU STF-1 and Outlaw M8 offer pretty good performance for subs under $300. How large a room you trying to fill?
rnatalli is offline
Velodyne Sms 1 In Room Bass Correction Kit With Included Microphone , Audyssey , Infinity Primus 10 Inch Powered Subwoofer , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Klipsch Reference Series Rpw10 10 Inch Powered Subwoofer Black Ash , Hsu Research Stf 1 Subwoofer 150 Watt , Energy Esw M8 Na 1200 Watt Subwoofer , Outlaw Audio
