should Audyssey be re-ran after sub is broken in? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 10-29-2013, 04:26 PM - Thread Starter
joe801's Avatar
Quoted: 91 Post(s)
Liked: 78
Is it better to re-run audyssey after breaking in the sub? And how would I know if the sub is broken in? Does it sound differently?
These are the question my friend has been wondering. And I myself also. Currently his lv12r is set at 9 o'clock. And his subwoofer level in his avr is set to -2.
joe801 is offline
post #2 of 17 Old 10-29-2013, 04:37 PM
eljaycanuck's Avatar
Quoted: 1229 Post(s)
Liked: 1804
I'd run Audyssey when integrating the sub initially, and again after break-in. And if at some point down the road you want to re-run Audyssey again, it doesn't hurt to run it again. smile.gif
It won't necessarily sound different, but it might. A few hours of use should be enough.
eljaycanuck is online now
post #3 of 17 Old 10-29-2013, 04:51 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
My belief is that subwoofer break-in is nothing more than audiophile mythology. I've never heard or measured a difference with my gear after the passage of time. If there's anyone who has objective data to back up claims that subwoofer break-in changes frequency response or any other measurable characteristic, I'd be interested to know about it...
henrich3 is offline
post #4 of 17 Old 10-29-2013, 05:00 PM
BeeMan458's Avatar
Liked: 813
Yes you should and yes it does. Also, allow your subs amplifier to be on for thirty minutes to allow the amplifier to warm up.
After about forty hours of break in, things are about as loose as they're going be and I doubt you'll notice additional change in timbre. And after thirty minutes of amplifier warm up, I don't see additional changes in my graphs.
(i'm not going get into an argument over if things need breaking in or not. If someone doesn't care about this stuff, then it doesn't matter and after forty hours of play time, it doesn't matter because the subwoofer has been broken in and the point becomes moot)
BeeMan458 is offline
post #5 of 17 Old 10-30-2013, 07:38 AM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
http://www.audioholics.com/loudspeaker-design/speaker-break-in-fact-or-fiction
They tested on smaller drivers, 10" woofer and 4.5" midrange, but I would assume it would translate to all size drivers of similar construction. I'm not an expert and don't know what all the TS parameters mean except they are different before and after break in.
simp1yamazn is offline
post #6 of 17 Old 10-30-2013, 07:47 AM
Bill Fitzmaurice's Avatar
Liked: 4656
This is but one of many. Looking in the wrong places you have been.
http://www.gr-research.com/myths.htm
I break in every driver I use in design prototypes. They always measure differently after break in, that's why I break in every single one.
Bill Fitzmaurice is offline
post #7 of 17 Old 10-30-2013, 08:33 AM - Thread Starter
joe801's Avatar
Quoted: 91 Post(s)
Liked: 78
That's some very informative read up. I'm glad you guys posted some, thank you. I suggested my friend to do a 40 hour break in period. What type of meter can he use to measure the difference?
joe801 is offline
post #8 of 17 Old 10-30-2013, 08:48 AM
Liked: 1804
He doesn't need to measure the difference - he just needs to re-run Audyssey after whatever # of hours he's decided to use for break-in.
post #9 of 17 Old 10-30-2013, 09:20 AM
Liked: 4656
+1, Audyssey measures the response and EQs the system accordingly.
post #10 of 17 Old 10-30-2013, 06:36 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
Thanks for the links, Bill & simp1yamazn. Yes, there are measurable parameters that change with break-in, so claiming that nothing changes during break-in would be incorrect. What I had in mind however was the OP's question about the need to delay taking Audyssey measurements until after a suitable break-in period has occurred. Audyssey sets gains, distances, and EQ's the frequency response. The question that remains in my mind is which of those values would be significantly inaccurate if Audyssey measurements were taken after 1 hour of use versus the 40 hour point?
The Audioholics analysis provided by simp1yamazn seems to corroborate the belief that the OP needn't wait for a break-in period before running the Audyssey setup:
"Clearly, the differences in amplitude response between the pre- & post-break in systems are negligible."
"it's clear the volume of air confined within the sealed cabinet of the enclosed box loudspeaker system moderates any measurable and/or audible changes that might arise as a consequence of driver compliance changes."
"it's reasonable to conclude that suspension compliance changes arising as a consequence of initial driver burn in has little effect on the performance of a loudspeaker system."
The Audioholics test also includes pre & post break-in frequency response charts showing negligible differences, so I remain skeptical of the need to wait...
henrich3 is offline
post #11 of 17 Old 10-30-2013, 07:16 PM
BeeMan458's Avatar
Liked: 813
The good news, after forty hours of break-in, it's all moot anyways. wink.gif
post #12 of 17 Old 10-30-2013, 07:39 PM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
The gr-research article focused on raw driver measurements, whereas the Audioholics tests measured speaker systems. When measuring a speaker system in a room, I suspect that moving the Audyssey mic a few inches in any direction is likely to make a greater difference in the EQ results than waiting 40 hours for break-in.
henrich3 is offline
post #13 of 17 Old 11-18-2013, 11:31 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
Sorry to resurrect an old-ish thread but I gots a question:
Does it matter at what MV setting this "break-in" is done at? I use my subs for everything, with regular TV viewing making up the vast majority of viewing, albeit at relatively low volume levels (-35 to -20)....will this still break-in my subs?
I've probably got 100 hours of TV on my 2 new subs, but only about 8-10 hours of movies at -10 to -5.
Alan P is offline
post #14 of 17 Old 11-18-2013, 11:34 AM
Liked: 1804
You've got plenty of hours on your subs. If you haven't run Audyssey yet, run it. If you have run it, re-run it. If, at some point, you think you should re-run it again, re-run it again. smile.gif
post #15 of 17 Old 11-18-2013, 12:50 PM
Alan P's Avatar
Liked: 3326
Thanks Eljay....oh, I've run Audyssey....'bout a dozen times in the last week or so alone (since I got my Mini DSP)! Getting the best bass response is not an easy task! smile.gif
Alan P is offline
post #16 of 17 Old 11-18-2013, 01:40 PM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
You're right. That's coz Audyssey or any auto eq system is not the definitive point for taming subwoofers; it's more like a starting point wink.gif
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #17 of 17 Old 11-18-2013, 02:30 PM
Alan P's Avatar
Liked: 3326
Finding just the right combination of placement, gain, phase and filters with 4 subs is becoming quite a daunting task though. frown.gif
My wife is growing tired of the "woooooop, woooooop" of my frequency sweeps every night after she goes to bed! redface.gif
Alan P is offline
Audyssey , Rythmik Audio Lv12r
