I know this isn't recommend, but I tried it anyway. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-30-2013, 10:21 PM - Thread Starter
hpman247's Avatar
I've been using my BIC F12 and I love it, but I bought two HTIB in the past that came with Onkyo branded subs. So I have had two of those just lying around serving no purpose because people told me not to mix subs of different brands.
Well, I got really bored last weekend, so I found some y adapters and plugged them all up. I turned the Onkyo subs to about 1/2 volume on the back and they're crossed over at 120hz. The room sounds SO MUCH BETTER. I was kinda shocked, but I had the most amazing movie experience of my life after adding those, what I thought to be lackluster subs with a pretty good sub. I just thought for anyone who has some old subs lying around that took the advice of others without trying it for yourself, that it might be a good idea to give it a shot. You might be pleasantly surprised like myself
My room looks kinda like this
. onkyo sub polk m60 polk cs2 polk m60 bic f12
. onkyo sub
. polk m50 surrounds
"Knowledge is Power... But...Wisdom is the effective application of knowledge."
Onkyo TX-SR705
Polk M60 - Front
Polk CS2
Polk M50 - Surrounds
BIC F12 Sub
2X Onkyo SKW204 Subs
hpman247 is offline
post #2 of 16 Old 10-30-2013, 11:29 PM
Brad Sutliff's Avatar
I use the f12 and then my htib klipsch sub I got awhile back. Not ideal, but it definitely helps even out the sound from the f12. I'll eventually buy another f12 or similar 12 inch to replace the klipsch though
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #3 of 16 Old 10-31-2013, 09:35 AM
Bill Fitzmaurice's Avatar
Liked: 4628
They were wrong to do so. Almost any two or more subs together will sound better than either alone, between adding output capacity and smoothing room modes. They just probably won't sound as good as matched subs.
Bill Fitzmaurice is online now
post #4 of 16 Old 10-31-2013, 09:41 AM
steve nn's Avatar
Liked: 433
I would also suggest not mixing a totally crapy sub with a better sub.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #5 of 16 Old 10-31-2013, 09:43 AM
I agree you shoulsnt mix bad and good subs, different driver sizes etc. But as long as it sounds better than a single sub its worth jt
post #6 of 16 Old 10-31-2013, 12:57 PM
GoCaboNow's Avatar
Quoted: 862 Post(s)
Liked: 757
Or, if you do, set the crappy sub to only output in the frequency range where it is not so crappy. smile.gif
My two 12" Athena subs are crappy compared to most subs spoken about here, and certainly compared to my 4x18" IB setup. But, hi-passed at 30 hz and not turned way up, they add some extra mid bass and kick to the room. So if you don't stress them, and keep distortion low - even a crappy sub can be beneficial.
My Dedicated Home Theater Room
GoCaboNow is offline
post #7 of 16 Old 10-31-2013, 01:22 PM
How can you do this?I have two sub outputs but I can only set it up as one single sub. How can I cut off the scrappy sub from playing lower than it should?
post #8 of 16 Old 10-31-2013, 02:23 PM
Hopinater's Avatar
Quoted: 1774 Post(s)
Liked: 4376
How can you do this?I have two sub outputs but I can only set it up as one singlesub. How can I cut off the scrappy sub from playing lower than it should?
Ditto this question, I was wondering the same thing.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is online now
post #9 of 16 Old 10-31-2013, 02:27 PM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
You need an external DSP device or an active sub with HPF.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #10 of 16 Old 10-31-2013, 05:58 PM
GoCaboNow's Avatar
Quoted: 862 Post(s)
Liked: 757
Or a high pass filter that just fits on your coax cable. Parts Express sells them, or used to, for $20ish - IIRC?
post #11 of 16 Old 10-31-2013, 06:04 PM
How good are the hpf on the coax cables?
post #12 of 16 Old 10-31-2013, 10:19 PM - Thread Starter
hpman247's Avatar
I'd also like to know how to use a HPF for the two lesser quality subs. I just have them all daisy chaines with y-adapters to the single sub output at 120hz. I'd love to be able to limit the two Onkyos from producing anything below 35ish
Onkyo TX-SR705
Polk M60 - Front
Polk CS2
BIC F12 Sub
hpman247 is offline
post #13 of 16 Old 10-31-2013, 11:31 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Mrkazador is offline
post #14 of 16 Old 11-01-2013, 12:18 AM - Thread Starter
hpman247's Avatar
Since I have 3 subs hooked into the same pre out, if I plug one of these directly into the back of the Onkyo Sub, and another into the back on the Onkyo sub, and connect them daisy-chained as they are now, it won't affect my current F12 that can handle lower than 30hz, right?
Onkyo TX-SR705
Polk M60 - Front
Polk CS2
BIC F12 Sub
hpman247 is offline
post #15 of 16 Old 11-01-2013, 06:53 AM
Liked: 4628
It won't affect the F12 other than that you must be sure that they aren't run at a high enough level to distort before the F12 does.
post #16 of 16 Old 11-01-2013, 07:12 AM
steve nn's Avatar
Liked: 433
Lol.. Not sure how crappy your talking about, but I’m talking pretty crappy. That being that, I’m sure we have different approaches and that’s cool, it’s all good. cool.gif
GoCaboNow likes this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
