Subwoofer options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 62 Old 11-02-2013, 10:43 AM - Thread Starter
Andrew Bush's Avatar
Need to buy a new sub.  I have two subwoofer outputs and would consider doing two.  However, I'd like to stay $1k or less.  Is it better to buy one high powered sub or two lower powered subs.  Room isn't very big.
Andrew Bush is offline
post #2 of 62 Old 11-02-2013, 11:10 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
Depends IMHO although general wisdom would probably be on the side of one better sub. One better sub in a small room would probably do quite well but there are advantages to multiple subs in addressing room modes, to smooth out response for multiple listening positions. Somewhat depends on what you want in the way of extension, too. What are the dimensions of the room and is it sealed off or open to other rooms? What sub have you been using and what do you listen to?
lovinthehd is offline
post #3 of 62 Old 11-02-2013, 11:50 AM
Quoted: 75 Post(s)
Liked: 112
At $1K, I like dual SVS PB-1000s or single Rythmik. How large is your room?
rnatalli is offline
post #4 of 62 Old 11-02-2013, 02:18 PM
spyboy's Avatar
Liked: 48
At $1,022 delivered I like the HSU VTF-15H. In a modest sized room the VTF-15H will knock your socks off.
http://www.hsuresearch.com/products/vtf-15h.html
steve nn likes this.
spyboy is offline
post #5 of 62 Old 11-02-2013, 06:25 PM
Hopinater's Avatar
Quoted: 2285 Post(s)
Liked: 5684
At your price range you have a lot of great options available to you. Since SVS, HSU and Rythmik have already been suggested I will add PSA XV15 to the mix as a very good option at $800. I think any one of these options would make you happy.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is online now
post #6 of 62 Old 11-03-2013, 05:21 AM - Thread Starter
Room is approx. 17'x17'. I recently knocked down the wall between family room and kitchen, so room is open to kitchen and eating area. Kitchen is same size as main room and eating area is 3/4 the size. I plan to be in this house for a while longer. My next purchase, room will be bigger.
Panasonic 65VT50 television
Denon AVR-3311CI
4 Athena AS-F1-1 Audition Series Speakers
1 Athena Center Channel Speaker AS-C1-1
I bought speakers over a decade ago. For now, I'm satisfied with how they sound.
Room is fairly small, but is open to kitchen. Space is also a concern. If I had two subwoofers, I'd place the other sub on the opposite side, as you can see in the pic above. I was looking into the supercubes at first. Thought about two of the 4000 or one 8000. However, I don't know much about subs. As I've been doing research, I've been leaning towards subwoofers with continuous power in the range of 800 watts to 1500 watts. More continuous power, better the sound. Not sure if this makes sense or not. This will hopefully be the last sub or subs I buy for a while, so thank you for any advice.
post #7 of 62 Old 11-03-2013, 05:38 AM
SaviorMachine's Avatar
Liked: 91
Nice looking room, bold color. You may regret knocking down that wall, though. If I read you right, you now have a compound room that's 17x17 + 17x17 + 12.75x12.75... is that so? So assuming an eight foot ceiling, that's about 4600... and about 1300... some almost 6000 cubic feet of uninterrupted open space?
That's a lot of open space. If you want big thrills, you may need to up your budget a touch.
You could consider the SVS PC12-Plus, for $1200 shipped. This is an impeccably designed system built to deliver deep, powerful and accurate bass in large spaces. I have a lot of experience with the step-down model, the PC12-NSD, and can vouch personally for the brand's high quality. The form factor could be a consideration though, in your space, since aesthetics are obviously important to you.
You could try a pair of Rythmik LV12Rs. One LV12R won't approach the output of a PC12-Plus, but two of them strategically located could net a really powerful, high quality response in the seating area. This is currently showing up at the site as $1082 shipped to the lower 47 outside Texas. They seem to be charging $4 for shipping...? I don't know if it's a glitch--try reaching out to them.
Also, nice TV. I got an ST from the same year and it's just amazing smile.gif
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #8 of 62 Old 11-03-2013, 05:54 AM - Thread Starter
What do you all think about Velodyne Optimum Series 10-Inch?
One of my friends thinks he can get me a good deal on the JL Audio E110ASH or the E112ASH.  I'm pretty sure he is going to give me a near cost price.  I don't plan to spend over $1k, so the JLs might be too far out of my range, depending on the deal he can get me.
post #9 of 62 Old 11-03-2013, 06:00 AM - Thread Starter
10 ft ceilings.  I can bump my budget some.
Space I s interrupted.  I didn't knock down entire wall.
post #10 of 62 Old 11-03-2013, 06:02 AM - Thread Starter
I'm going to look into your suggestions.
That SVS PC12-Plus is interesting.  Don't know if I particularly like the look of it.  But that's just at first glance.  Great for saving space.
post #11 of 62 Old 11-03-2013, 08:28 AM
Liked: 91
Yes, it's got a tiny footprint compared to subs with similar output and quality, and it's a lot more lightweight than most of them too. Multiple output modes, powerful amp with digital controls including parametric EQ. It's significantly cheaper than the box version.
On the other hand of course it's much taller, and unusual looking. Run it by the Zoning Committee wink.gif
post #12 of 62 Old 11-03-2013, 08:31 AM
Liked: 91
If you could be convinced to up the budget to about $1400, there's Rythmik's big dog ported sub, the FV15HP. It delivers exceptional output and quality for its price.
post #13 of 62 Old 11-03-2013, 08:53 AM - Thread Starter
The depth on the sub needs to be 19" or less.  In the first picture I posted, the sub is just over 18".  Anything deeper will hang off the fireplace location where I have current subwoofer, which is driving me crazy with the noises it's making.
post #14 of 62 Old 11-03-2013, 09:41 AM
spyboy's Avatar
Liked: 48
The Optimum 10 won't have the output for a space as big as yours.
IIRC the MSRP of the E112 is $1,900. If you can get one for ~$1,000 that would be very tempting! The E110 isn't enough for your space.
cel4145 likes this.
spyboy is offline
post #15 of 62 Old 11-03-2013, 11:27 AM
lovinthehd's Avatar
Liked: 4781
Just what is the sub you have now? Curious more than anything, but if it's making odd noises guess its time for it to go!
The subs being recommended here are not B&M subs like those you've named so if seeing/hearing it first is a necessity for you, you may lose out on the best quality for the $, as the internet direct subs are really the leaders in that regard unless you get a really great deal. You have a lot of space to fill so I'd cross the supercubes off the list now, footprint may be nice but the performance is lacking. While nothing wrong with a high wattage amp, without knowing the sensitivity of the sub, hard to say how much the wattage means.
You handy by any chance? There are some very good values in assemble & finish yourself sub kits from parts-express.com or diysoundgroup.com (who supplies the boxes for parts-express, forum member EricH).
post #16 of 62 Old 11-03-2013, 11:49 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Agreed. SVS Audio, Rythmik, HSU, Power Sound Audio, and Outlaw Audio are the go to companies for subs. Unless you are getting close to 50% off MSRP, the subs from those Internet direct manufacturers are generally a better value than traditional speaker company subs.
As for the Optimum 10, best to avoid thinking about 10" subs. Given the size of your room, minimally you should probably be looking at dual ported 12" subs or a single 15" ported sub from one of those vendors I listed.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #17 of 62 Old 11-03-2013, 12:16 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
With a 19" depth and $1k budget, this B-stock SVS PC12-Plus would be my first choice. I wouldn't wait too long on that, it looks like the only one in stock presently, so get it while you can.
shadyJ is offline
post #18 of 62 Old 11-03-2013, 01:12 PM
Hopinater's Avatar
Liked: 5684
I think cel makes a good point. I think you actually have a pretty good size area based on your measurements and the pics you posted. A lot of open space to try and pressurize.
On another note, have you conducted the sub crawl around your room to find the best placement for your subwoofer? Perhaps another location would be better than where you have it right now. That may affect the size of the sub you buy. I recently crawled my room and found that where I had one of my subs positioned was absolutely the worst place I could have put it (you live and you learn). But I also found out that my other sub was in the right spot and found the the correct location for my second sub.
post #19 of 62 Old 11-03-2013, 03:04 PM - Thread Starter
Do you think this speaker is a better choice than the JL AUdio e112-ASH if I could get around the same price, manybe $100 or $200 more?  I'm starting to lean towards the SVS PC12 Plus.  If my friend can give me a good deal on the JL, would you still go with the SVS PC12 Plus?
post #20 of 62 Old 11-03-2013, 03:58 PM - Thread Starter
My current sub is a sub from a different room when my main sub went out.  It's a JBL sub. 300 watts or so.  Sounds ok at moments.
post #21 of 62 Old 11-03-2013, 03:59 PM - Thread Starter
Wish I could do a subwoofer build.  I just want to plug and play.
post #22 of 62 Old 11-03-2013, 04:00 PM - Thread Starter
post #23 of 62 Old 11-03-2013, 04:27 PM
Hopinater's Avatar
Liked: 5684
My understanding is the JL Audio e112 is a good sub but unless you can get it at the same price as the SVS-PC12 Plus I would go with the SVS. There is another important thing to consider and that's warranty and customer service. SVS has a 5 year unconditional warranty. In fact they have a Customer Bill of Rights, now that's customer service. SVS has a great reputation for taking care of their customers and backing their products.
spyboy likes this.
post #24 of 62 Old 11-04-2013, 10:26 AM
spyboy's Avatar
Liked: 48
The E112 vs. the PC-12 Plus is like comparing apples to oranges. E112 = small and Sealed, while the PC-12 Plus is really tall and ported (in native tuning). Visually speaking its no contest.
I have an SVS 20-39 PCi but my wife isn't troubled by the 39 inch 20-39 PCi.
spyboy is offline
post #25 of 62 Old 11-04-2013, 12:01 PM
Quoted: 75 Post(s)
Liked: 112
A single sub will have to be fairly large in order to get to the needed output for your space. If you can manage two subwoofers, a pair of PC12-NSD would do nicely and because of the form factor, they easily come in at less than 19" depth each. I'm also thinking it may be tricky smoothing out frequency response in that room with only one sub.
rnatalli is offline
post #26 of 62 Old 11-04-2013, 12:13 PM
Hopinater's Avatar
Liked: 5684
Great point. That's why I suggested doing the sub crawl. It really should be done before buying anything so you know where the best places for the sub/subs will be. I learned the hard way, had a sub doing next to nothing for almost two years because it was in the wrong location.  And like I posted earlier, it's a good sized space. If there is one thing I have learned between this forum and emails to PSA and SVS, if you can swing it, dual subs are almost always better than one. If not than a single good powerful sub.
Andrew Bush likes this.
post #27 of 62 Old 11-04-2013, 12:18 PM - Thread Starter
So, you think the dual PC12-NSD is better than just the single PC12 Plus?
post #28 of 62 Old 11-04-2013, 12:18 PM - Thread Starter
you think the dual PC12-NSD is better than just the single PC12 Plus?  It was suggested.  Wanted to see whay you thought.
post #29 of 62 Old 11-04-2013, 12:19 PM - Thread Starter
you think the dual PC12-NSD is better than just the single PC12 Plus?  want to see what you thought
post #30 of 62 Old 11-04-2013, 04:34 PM
steve nn's Avatar
Liked: 433
A PC12+ is very close to two PC12-NSD’s basically.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Rythmik Audio F15 Subwoofer , Hsu Vtf 15h Subwoofer , Svs Pc12 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Velodyne Optimum Series 10 Inch Subwoofer Enclosures Black
