More punch, less boom - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-03-2013, 01:32 PM - Thread Starter
Brad Sutliff's Avatar
I'm looking for more bass punch from my sub. I ave an idea that I might try but it will be some work so I thought I'd ask first. If I placed my bid f12 sub in the corner to add bass but don't want the boom that will come with it could I eq the sub lower in the 25hz range and bump it up in the 60hz range and get punchier bass and reduce the boom from the placement?
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
post #2 of 9 Old 11-03-2013, 01:40 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Why don't you just turn up the 63hz EQ setting (page 72 of your manual) where your sub is right now and see if that helps? If not, you might just need a better sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 9 Old 11-03-2013, 01:42 PM - Thread Starter
I have. It did help but would moving it do more? And my budget won't allow me to upgrade sub's. Eventually I will have this as my nearfield sub and something better for where this is at now
post #4 of 9 Old 11-03-2013, 01:46 PM
cel4145's Avatar
Liked: 2985
I think you just have to try it and see if you've already played with the EQ in its current location.
post #5 of 9 Old 11-03-2013, 01:51 PM - Thread Starter
Alright. Thanks
post #6 of 9 Old 11-03-2013, 02:12 PM
BeeMan458's Avatar
Liked: 813
Booming tells me the gain is turned up to high.
Have you run your AVR's EQ program?
A lack of mid-bass punch tells me your room acoustics are cancelling out your mid-bass.
Have you taken the time to download and get a freeware copy of REW up and running so you can measure your room to see how your room is responding to your subwoofer sound reproduction system. Without room measuring capability, sonically, you're truly running blind.
BeeMan458 is offline
post #7 of 9 Old 11-03-2013, 02:15 PM
BeeMan458's Avatar
Liked: 813
I see from your list, you're using an Onkyo TX-SR607 which has Audyssey 2EQ that lacks the ability to EQ subwoofers.
From the Audyssey website:
2EQ
Our basic resolution room correction solution that uses basic resolution filters for the satellites, but does not apply a filter to the subwoofers.
You would be well served looking into the addition of a miniDSP so you can separately EQ your subwoofer.
post #8 of 9 Old 11-03-2013, 02:34 PM - Thread Starter
Yeah I decided today to eq my setup myself. But keep the audesseys settings for levels and distance. I think it sounds better so far. Better bass and equal highs from what I can tell. I'm going to get a minidsp soon hopefully. Once I have the money to spend
post #9 of 9 Old 11-03-2013, 04:07 PM
BeeMan458's Avatar
Liked: 813
Yes, money, a formidable opponent. Do you have a digital sound meter? You can pick one up from Radio Shack for a reasonable price. If you download a freeware copy of REW, you can use REW to play selective tones and use the phase control to help dial your subwoofer in.
Are you aware of, and if you are, the sub crawl? This will help you find the best position in your room for the subwoofer.
Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
