Reseating Sub - AVS Forum | Home Theater Discussions And Reviews
Old 11-07-2013, 01:02 PM - Thread Starter
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
I think I have an air leak on my eD A7-450. Seems like one (or more) of the screws might be loosening. Should I remove all the screws, turn the sub then predrill new holes? If so, what type of screws should I use to reseat the sub to the box?
Current setup: JVC RS55 - Marantz 7008 - Dune Solo 4K - Kodi/Chromebox - Cinema 10's LCR - Volt 10 Surrounds - Polk in wall rear & ceiling - eD A7-450
the_abbot is offline
Old 11-07-2013, 07:28 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
Might be a good idea to cover the screw holes with drywall Spackle, epoxy, or a glue/saw dust mixture. Also wouldn't hurt to put a new gasket on the enclosure.
Pan head screws.
Mrkazador is offline
