Klipsch Subwoofer 6? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-10-2013, 01:29 PM - Thread Starter
Ghawdex's Avatar
Hello,
I was just given a Klipsch "Sub 6". I have tried looking this up, but can't find much about it. I don't have an amp to power it but am looking for one. Is this a good woofer? I'm thinking about on getting the Denon AVR X1000. Would this be a good buy?
Ghawdex is offline
post #2 of 9 Old 11-10-2013, 01:35 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
A quick Google for "Klipsch sub 6" says it has a 6.5" driver and an 80W (RMS?) amp. It might be a good woofer, but IMO it's not much of a subwoofer.
If it has the features you want/need and it fits your budget, yes.
eljaycanuck is offline
post #3 of 9 Old 11-10-2013, 01:52 PM - Thread Starter
Ghawdex's Avatar
What do you mean by this? do you not think it would be a good movie woofer?
Ghawdex is offline
post #4 of 9 Old 11-10-2013, 02:03 PM
Bill Fitzmaurice's Avatar
Liked: 5687
Good subs for HT go down to at least 30Hz. Six inch drivers don't, at least not with enough output to be heard more a few feet away. Real HT subs are loaded with at least ten inch drivers.
Bill Fitzmaurice is offline
post #5 of 9 Old 11-10-2013, 02:17 PM - Thread Starter
Ghawdex's Avatar
Thanks for the info, understanding now. So, would this thing not sound good at all? I was going to buy a receiver for this thing but I guess not no more... or should I buy it anyways and just use it for the time being? My bedroom is quite small 12x12.
Ghawdex is offline
post #6 of 9 Old 11-10-2013, 02:37 PM
Liked: 5687
So, would this thing not sound good at all?.
It won't go very low or very loud, so I wouldn't bother with it. It's intent isn't as a real HT sub, it's made to add a measure of bass to very small mains that only go down to 160Hz or so.
Are you aware that you'll need main speakers as well? And, AFAIK, the Sub 6 is powered.
post #7 of 9 Old 11-12-2013, 02:03 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
bad1550 is offline
post #8 of 9 Old 11-13-2013, 05:06 AM - Thread Starter
Ghawdex's Avatar
They came with speakers as well... It looks like it was the whole package from the HD300 they used to offer.
Originally Posted by bad1550 View Post
Selling my RW-12D
See below
http://newyork.craigslist.org/wch/ele/4186717258.html
Appreciate it, however, I'm saving up for the HSU
Ghawdex is offline
post #9 of 9 Old 11-13-2013, 05:20 AM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Yes, I just picked up HSU VTF-15 and love it!
Now need to sell Klipsch to offset huge cost
bad1550 is offline
Klipsch Rw 12d 12 Subwoofer Each
