Choosing between SVS, MK, Paradigm subwoofers for condo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-10-2013, 01:41 PM - Thread Starter
Coolnewbie's Avatar
I have a 3-bedroom condo where the living room is about 3 x 3.5 meters but is part of a larger space with the dining and kitchen areas attached.
The living room has a TV, a Denon 1713 receiver, and B&W 685 speakers. I plan to use this for movies and music, and try to set up a listening nook in ano
Which is a better sub for this?
- SVS PB12
- Velodyne EQ12
- Paradigm Monitor Sub12
- Miller & Kreisel SB1250
Or is there a better model subwoofer for the space I describe and this rough price range?
Coolnewbie is offline
post #2 of 13 Old 11-10-2013, 03:44 PM
Kini62's Avatar
Quoted: 1743 Post(s)
Liked: 1557
SVS without question.
dctrombly likes this.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 13 Old 11-10-2013, 04:02 PM
raynist's Avatar
Quoted: 1574 Post(s)
Liked: 1550
SVS between those choices.
A PowerSound Audio XV15 would be great too.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is offline
post #4 of 13 Old 11-10-2013, 04:25 PM
LowerFE's Avatar
Liked: 41
Out of the 3 the SVS will sound lower, louder, tighter, while being cheaper than the Paradigm or Velodyne. I've heard of the Paradigm Monitor SUB 12, and it is anemic.
LowerFE is offline
post #5 of 13 Old 11-10-2013, 04:34 PM
rwheelwright's Avatar
Quoted: 117 Post(s)
Liked: 34
While not having heard the other 2 I can tell you that the paradigm was good in my room. My ht place let me borrow a sub 12 while waiting for my sub 2. It filled my room, granted I don't have the biggest room but it is open at the back to the rest of the house
rwheelwright is offline
post #6 of 13 Old 11-10-2013, 06:13 PM - Thread Starter
Coolnewbie's Avatar
Lots of people swear by SVS even though they also say it is no longer the great value it was 5 years ago. Why do you recommend SVS over MK?
post #7 of 13 Old 11-10-2013, 08:59 PM
LowerFE's Avatar
Liked: 41
It is not true that SVS is no longer the great value it was 5 years ago. If you compare performance per dollar, the current SVS subs are quite a bit better performing than their older models. For example, the current $769 entry level PB12-NSD is a better performer than the old $1299 PB12-Ultra (around the same max output, but better sound quality). SVS doesn't seem as good as a value before because there is much more competition with ID subwoofers now from Rythmik, PSA, JTR to name a few.
Therefore, compared to brick and mortar subwoofers, the SVS is still a way better value, and probably even more so considering the performance increases.
steve nn likes this.
LowerFE is offline
post #8 of 13 Old 11-11-2013, 02:00 AM - Thread Starter
Coolnewbie's Avatar
Anyone have an SVS and MK comparison?
post #9 of 13 Old 11-11-2013, 05:51 AM
steve nn's Avatar
Liked: 433
Are you referring to the Dayton MK 4? http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-765
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-764 kit
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #10 of 13 Old 11-11-2013, 03:38 PM - Thread Starter
Coolnewbie's Avatar
post #11 of 13 Old 11-11-2013, 05:53 PM
datranz's Avatar
Quoted: 58 Post(s)
Liked: 43
Small 12 inch seal sub with 250w is not a recipe for high output at low ulf. Large ported, than maybe.
datranz is offline
post #12 of 13 Old 11-12-2013, 07:14 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
No, the MK SB 1250
http://mkloudspeakers.com/products-info.asp?id=179&type=Product
The MK is not in the same category as the PB12. If you wanted that MK, you should compare it to the SVS SB12NSD or the Power Sound Audio XS15...and my preference would still be the SVS or PSA, either of which would probably outperform the MK
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #13 of 13 Old 11-12-2013, 07:36 AM
steve nn's Avatar
Liked: 433
+1 I like the words they use in their description. Check out No. 3 OP at both sites if interested? cool.gif
http://www.data-bass.com/myths ...... http://web.archive.org/web/20080416034852/http://www.audiopulse.com/know-how/subwoofer-driver-guide/myths-about-subwoofers/
Powered subwoofer that uses a special high-performance 12" Super Fast Deep Bass long-throw,
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Denon Avr 1713 Receiver , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Velodyne Eq Max 12 12 Subwoofer
