As of Nov 2013 - best sub for under 1K ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 72 Old 11-17-2013, 07:34 PM - Thread Starter
lockeed's Avatar
Open to your suggestions. Sub would be used in a large, 48' long X 14" room - 50/50 mix of music and movie/game.
_____________________________________
"When I lied, no one died" Bill Clinton
The north pole theater
lockeed is offline
post #2 of 72 Old 11-17-2013, 08:17 PM
Hopinater's Avatar
Quoted: 1781 Post(s)
Liked: 4390
I'll be the first to take the bait on this. IMO the XV15 is the most bang for your buck at $800 shipped followed by the SVS PB12-NSD at $769 shipped and the Hsu VTF 15 or the VTF3-MK 4 but by the time you add in shipping the VTF 15H is reaching the limits of the $1000 ceiling.
But I don't think any one of them can handle your room by themselves. Assuming the ceilings are 8 ft your room measures well over 5000 cu ft. That's very large. I think you will need at least two of any those subs to really do justice to the bass in that size of a room. Plus dual subs smooths out the bass across the LPs.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #3 of 72 Old 11-17-2013, 08:27 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5212
+1 thats alot of room to fill. Imo a room that size is going to need a minimum 1500.00 worth of subwoofage to get adequate output. I would look at Dual PC12NSD's, Dual XV15's, or if you can only do a single, then a Rythmik FV15HP would be a must.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #4 of 72 Old 11-17-2013, 08:39 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Huge room, in that sized room I would go for two Premier Acoustics PA-150 subs. It ain't much below 40 Hz, but above 50 hz it is a beast. If you can only have one $1k sub, I would go for the Dayton T1504A. It won't do much damage below 30 hz, but it ought to do very well above that point. I don't know how shipping to Canada will add to its price though. You might give live sound subs a look as well. They don't tend to dig real deep but they have huge output. The are designed for large venues. Here are a couple examples: the Mackie HD1801 and Yamaha DSR118W. Both are 130+ dB capable at 1 m, which is not something any home audio subwoofer is going to give you anywhere near $1k.
shadyJ is offline
post #5 of 72 Old 11-18-2013, 10:34 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
I don't know why the previous posters think the room is all that big - it's only 14 inches wide! I mean come on, a cheap HTIB sub could fill that space...and heck, most of the recommended subs wouldn't even physically fit in there...
Anyway...yes, at least two subs to fill that room, especially since it is so elongated (even at 14 feet wide).
Perhaps your best choice right now would be to max out the $1000 on a single sub (like the HSU), then build up a little more funds over the next year in anticipation of procuring a second identical sub. That way you'll satisfy your immediate needs, but have the opportunity to build on it to really get some good sound.
IMHO, YMMV,
shinksma
eljaycanuck likes this.
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #6 of 72 Old 11-18-2013, 10:52 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
Assuming 8' ceilings, that's almost 5,400 cu.ft. That's a BIG room! Dual subs would be ideal.
If you have a one-time budget of ~$1,000, dual SVS PB-1000s might work. In Canada, they're available through sonicboomaudio.com (SBA), SVS' official and only Canadian distributor. They're priced the same as in the U.S. ($499), but we have to pay taxes and shipping. IIRC, SBA offers a 5% discount on the second sub (and on subsequent purchases).
If buying from the U.S., the XV15 ($799, shipped within the continental U.S.) would be a great option. Get it delivered to a U.S. depot and drive down to pick it up.
If you can buy one now and add another one later on, definitely go with the XV15. Unless you intend to stick to buying within Canada, in which case go with dual SVS PB12-NSDs.
eljaycanuck is offline
post #7 of 72 Old 11-18-2013, 11:07 AM
Liked: 1800
post #8 of 72 Old 11-18-2013, 11:35 AM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
It's not your job to be as confused as him.
ermghoti is offline
post #9 of 72 Old 11-18-2013, 02:04 PM
Hopinater's Avatar
Liked: 4390
I agree with all of this but I am a little concerned that dual PB 1000s may still not be enough. I guess with the SVS 45 day free trial it's safe to buy them and see. But I like the other two choices better.
Good catch, that's funny. :p
post #10 of 72 Old 11-18-2013, 05:53 PM - Thread Starter
lockeed's Avatar
Some great suggestions, as always. I've been out of the game for about 2 years so I'm not really up to date right now with these new subs! I have two MFW-15 in my theater, how would you guys compare the XV15 or PB12 to mine?
BTW, I just got the final measurements for the room and it turns out it's actually 43' X 15' with two large dormers that are 10' wide. Room is located on a second floor.
I'm helping out a friend setup his room properly... He wants to go with a single sub because, A, he's not an audiophile and B, one good sub will do just fine, he's not looking for power in particular, just a good low end presence.
lockeed is offline
post #11 of 72 Old 11-18-2013, 06:04 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
Well, they go hand in hand, not going to have one without the other etc.....
In a place that big the subwoofer will be trying to fill the whole space at the same time, not just the listening area. Even with the sub right next to the listening position it will still lose a lot punch/power to the room.
Get the biggest or most sub you/he can afford.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #12 of 72 Old 11-18-2013, 07:33 PM
Hopinater's Avatar
Liked: 4390
Agreed, time to up the budget and follow basehead's earlier advice and get the Rythmik FV15HP.
post #13 of 72 Old 11-18-2013, 08:02 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
I also have a large room similar to the OP. I went with passive subs. An amp and sub can be done for around a grand. This way the cost is a lot less for the second sub since an amp can run 2-4 subs. I used Chase subs and DYI sub kit are also an alternative. For large rooms, max spl is a strong consideration. I had the Premiere Acoustic PA 150 and it was a great sub for a large room but, lacks in the low end. It is still one of my favorite subs.
derrickdj1 is offline
post #14 of 72 Old 11-21-2013, 10:52 AM
shinksma's Avatar
Quoted: 80 Post(s)
Liked: 54
This might sound a bit naff, but does your friend really need the whole room as one large open space? If a part-wall was added 60%/40% of the way along the long side at the same spot as the wall of one of the dormers (for example), the room would be 24' x 15', with one dormer in the middle of the side wall of that room "portion". That would make for an effectively smaller room, even if the new wall was not all the way across the opening, it would make the area easier to pressurize. See graphic attached, where I marked up your plan-view. Red is partial wall, blue is a possible Subwoofer location - will maximize "boom loudness" but not the ideal position for flat response, more than likely.
Just a possible suggestion, I might be completely bonkers, YMMV,
shinksma
shinksma is offline
post #15 of 72 Old 11-21-2013, 06:52 PM - Thread Starter
lockeed's Avatar
A always, thx for all your suggestions. We went with the PB12 form SVS. The fact that they have a Canadian distributor gave it the edge over the others. Saved a lot of shipping and import/brokerage fees...
Let's see how it goes and if it performs well, we might bring another one in!
Cheers
lockeed is offline
post #16 of 72 Old 11-21-2013, 06:54 PM - Thread Starter
lockeed's Avatar
shinksma
Unfortunately, your wall would mean we'd have to cut the pool table in half smile.gif But I get why you suggested it, I'm afraid we'll have to fill the whole room as it was designed as an open space from the start, there's gona be 4 TVs, a bar section, pool table, 3 couches....etc...
lockeed is offline
post #17 of 72 Old 11-21-2013, 07:01 PM
shadyJ's Avatar
Liked: 1350
A PB12 NSD for a 5k+ cubic ft room... would not have been my first choice, but let us know how it works out.
shadyJ is offline
post #18 of 72 Old 11-21-2013, 07:09 PM
Hopinater's Avatar
Liked: 4390
I don't know how it's going to sound but it's sure to look great.
post #19 of 72 Old 11-21-2013, 07:15 PM
Liked: 1800
We went with the PB12 form SVS. ... Let's see how it goes and if it performs well, we might bring another one in!
The PB12-NSD is a good sub, but I think you'll be wanting another one at some point. smile.gif
I had previous-gen, BASH-powered PB12-NSD in my ~3,400 cu.ft. HT space and I liked it a lot. But after a while, I was considering adding a second one...and I would have, had I not chosen to go a different route.
post #20 of 72 Old 11-21-2013, 11:36 PM
eagle98's Avatar
I was looking at this thread for some similar advice.
I'm looking for a subwoofer around $1k.
My room is 16' x 14' x 9' ceiling. 5.1 setup, perhaps will be 5.2 if I add a new sub.
My setup: Denon 3313 receiver.
Original Klipsch RF-83 towers
Original Klipsch RC-64 Center
Klipsch RS-42-II Surrounds (I liked the round look better than the triangle look on the old school ones)
Right now I'm running a Klipsch RT-12D subwoofer with the setup, which is the triangular look and I'm actually happy with the sound and bass for the most part. I guess this was the original sub intended for this setup.
It's okay (not capitalized on purpose).
I got a really good deal on the RT-12d about a year ago for about $150, so it was good as a filler.
Now I want MOAR!
After about 6 months after the Epik Christmas 2012 "sellout" I was convinced I was going to get DUAL EPIK empires to replace the RT-12D, but they were never for sale.
A year later, their website hasn't changed except a small blurb in June about a new product that still doesn't exist in time for Christmas this year and still no Empires for sale.
I had heard such good reviews on their subs a year ago, and they've been "sold out" for over a year.
I'm guessing the problems are deeper and maybe they went out of business since I don't think their website has had an available sub since last Christmas. WTFO??
Anyway, I'm looking for either an additional subwoofer for roughly $1k or advice if I should sell my RT-12D and get dual subs of another type. (Maybe I'll keep the RT-12D anyway since it compliments the other Klipsch if I ever want to sell).
I don't really do music right now too much in this room since this is my theater room with projector and 100" screen. My current sub has "good" bass, but I want something that "CRUSHES" this size room.
Can I feel adequate for around $1000 given the room size above? What suggestions do you have?
Any good sub companies expected to have a BF or Cyber Monday sale?
eagle98 is offline
post #21 of 72 Old 11-22-2013, 05:30 AM
Liked: 1800
Room size = 2,016 cu.ft.
For ~$1,000:
- PSA XS30 ($1,149, shipped)
- HSU VTF-15H ($879 + $143 shipping)
- PSA XV15 ($799, shipped)
post #22 of 72 Old 11-22-2013, 07:11 AM
BeeMan458's Avatar
Liked: 813
Who are you kidding. Most of us would have to go on a diet for six months to fit in that room. tongue.gif
Just saying, setting up a room properly and audiophile are not necessarily synonymous.
In my opinion, properly set up means meeting the expectations of the owner of the room. What are his requirements besides a single subwoofer, under a thousand dollars?
Are you having your friend follow this thread? As a suggestion, he should be monitoring this thread so he'll see the conversation develop.
i see you've put an order in.....good luck and I hope your buddy finds happiness with his choice.
BeeMan458 is offline
post #23 of 72 Old 11-22-2013, 09:43 AM
Hopinater's Avatar
Liked: 4390
For ~$1,000:
Good choices here. Another option might be the SVS PB12-NSD ($769 shipped).
post #24 of 72 Old 11-22-2013, 10:16 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
as having had the pb12, xv15, and xs30. I wouldnt suggest the pb12. its not even in the same league as the other 3 mentioned, and its only a 30$ savings. that 30$ is a nobrainer
Brian Fineberg is offline
post #25 of 72 Old 11-22-2013, 11:59 AM
ainsworth's Avatar
Quoted: 21 Post(s)
Would the Outlaw LFM-1-EX be in the same league? It has 20-80hz avg of 110.4 db as shown on data bass, I am also looking at some of these, so trying to understand smile.gif
ainsworth is offline
post #26 of 72 Old 11-22-2013, 01:08 PM
shadyJ's Avatar
Liked: 1350
The Outlaw will get louder than the PB12 but isn't quite as clean or linear. The same is true for the XV15. It gets louder in mid bass frequencies, but can not play back as much deep bass as cleanly as the PB12. They each have their strengths.
shadyJ is offline
post #27 of 72 Old 11-22-2013, 01:53 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5212
Thats false...turn them both down to match the PB12NSD output and they both will play just as clean on paper. Aside from that most of the THD sweeps on data-bass are not audible real world usage anyway. Max burst testing is much more demanding then source content. The fact that owners(who have owned all the subs in question) have stepped in threads like this and even stated what sub is better proves this.
post #28 of 72 Old 11-22-2013, 02:34 PM
Hopinater's Avatar
Liked: 4390
I do agree with you on the $30 being a no brainer, that's exactly why I went with the XV15 recently, I was just mentioning it as a decent option for a 2000 cu ft room. Good to hear from someone who has first hand experience with those three subs too. I know they are completely different subs but how did the XS30 and the XV15 compare, I assume you used them in the same room as the PB12 NSD (perhaps this is a bad assumption).
post #29 of 72 Old 11-22-2013, 04:01 PM
Liked: 3514
You are completely wrong. The xv15 is tuned lower than the pb12. The xv15 is much more closely compared to the pb12+ NOT the pb12
Yes they were/are all in the same room
The xs30 digs deeper and is louder above 25 hz. Its a far better sub then the xv15 which really is saying somthing! I really like the sound of a sealed sub compared to ported but that is personal preference
In my room i was flat to about 14hz with the xv15 but then it dropped like a rock
I am currently flat to 8hz with the xs30
Hope that helps a little.
I
post #30 of 72 Old 11-22-2013, 04:22 PM
shadyJ's Avatar
Liked: 1350
No, they do not play just when you level match them, especially on paper. The XV15 and Outlaw have a considerably greater percentage of distortion at the 105 and 110 dB sweeps, it looks like twice as much overall, and perhaps more for the XV15 when you include its upper bass distortion. Owner testimonials don't mean anything when they are not A/B tested. On top of that dirty bass will always sound more powerful than clean bass, do they know to listen for that?
shadyJ is offline
Hsu Vtf 15h Subwoofer , Hsu Vtf3 Mk4 , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Premier Acoustic Pa 150 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
