Thumping Subwoofer, NOT Rumbling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-22-2013, 07:42 PM - Thread Starter
malimited's Avatar
Small apartment and like $400 budget. My question is this. What subwoofers can I look at that make a more thumping sound instead of a rumbling sound. This is the biggest factor for me as I find too much 'rumbling' and not enough 'thumping'. Any and all recommendations are greatly appreciated.
malimited is offline
post #2 of 9 Old 11-22-2013, 07:50 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5247
That could be more of a room response issue then the subwoofer. That being said the PA-150 should thump nicely.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #3 of 9 Old 11-22-2013, 07:51 PM
eljaycanuck's Avatar
Quoted: 1232 Post(s)
Liked: 1804
SVS PB-1000 or SB-1000. $499 for either one, including shipping and free return shipping within 45 days.
eljaycanuck is online now
post #4 of 9 Old 11-22-2013, 07:52 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
If you ask me, a thumping sound is higher pitched than a rumble, but they are kinda subjective terms. I would get a sub that has more emphasis on mid bass from your description. This sub here has a ton of mid and upper bass but not a lot of deep bass, that might fill your order nicely. You can make a lower offer on it from that page, click on the "make your best offer" button, and see if they will go for $400. It should be a very punchy and powerful sub.
shadyJ is offline
post #5 of 9 Old 11-22-2013, 07:57 PM
basshead81's Avatar
Quoted: 180 Post(s)
Liked: 5247
Hey we agree on something....look out worlds are going to collide. lol
post #6 of 9 Old 11-22-2013, 08:47 PM
Bill Fitzmaurice's Avatar
Liked: 4661
+1, one man's thump is another man's rumble, so a definitive answer isn't possible.
Bill Fitzmaurice is offline
post #7 of 9 Old 11-22-2013, 08:57 PM
Hopinater's Avatar
Quoted: 1787 Post(s)
Liked: 4398
Ahhh….. I'm not sure how to handle this! Bassman and shady are agreeing. :D
I agree with eljay, for a little more the pb1000 is a good option.
But then again, we don't know the size of your room. Everthing could change if we find out you have a 5000 cu ft HT. What is the size of your room?
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #8 of 9 Old 11-23-2013, 02:29 PM - Thread Starter
malimited's Avatar
Thanks for all the responses.  The size of my room is about 1000 cubic feet with hardwood floors throughout (no carpet, not sure if that makes a difference).  Is it true that more mid-range gives more of a thumping rather than rumbling.  I should probably qualify why I'm looking for more thumping than rumbling.  I listen to a lot more music than movies on my surround sound and when the bass plays on the music, it's 'rumbly' instead of thumping...not the sound I'm looking for in music.  I hope this makes sense, I used to be an audiophile many many years ago and just fell off it...
post #9 of 9 Old 11-23-2013, 02:40 PM
shadyJ's Avatar
Liked: 1350
I think that rumble you are referring to might be the awful muddiness that you get from home-theater-in-a-box 'subwoofers', which really is just a port in a plastic cabinet. They have no bass definition, it's all inarticulate boom. The aforementioned PA-150 will be light years better. You might also consider a Hsu STF2 which will sound pretty clean and sharp next to other budget subwoofers as well, but it won't have nearly the output of the PA-150. However, you wouldn't be able to take advantage of the PA-150's potential anyway in a small apartment.
shadyJ is offline
Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer
