Muffled sound from subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-30-2013, 09:38 PM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
Hey guys, interesting issue creeping up with my subwoofer and I am trying to determine the source, but have no clue where to start.
It is strange, I thought it was only happening with TV from my Dish STB, but tonight I noticed it with a movie form my popcornhour over HDMI. My STB is connected via SPDIF, so the sources are different, but the issue is the same.
I have and SVS PC12-Plus, the thing has been great to date. My receiver is and Onkyo TX-SR805 and I am using sub out as expected, and going to I the the R input on the sub.
In the Onkyo THX Subwoofer is set to no
LPF of LFE is set to 80Hz
beyond that, I have nothing special. The sound I hear is like a muffled/statick like sound from the sub. I never thought much of it till last night I was watching a movie and it sounded sort of like quiet thunder or stadium crowd in the background. The sub still functions normal when there is normal bass to play, it shakes the room, so the sub itself seems fine, so I don't know if it is getting a bad signal or a signal it should not be receiving because like I said, when it comes to the real bass, it plays fine. Is it potentially the Hz setting of the Sub? Is 80Hz right or should this be like 120Hz as I have seen noted elsewhere?
I actually have all my speakers currently set to 80Hz, so maybe I am doing things wrong all around, but first things first is the subwoofer as the added output is annoying as it makes it seem like it is raining in the distance or bombs are exploding over a mountain when that does't fit the scene at all.
Thanks for any help provided.
smakovits is offline
post #2 of 17 Old 12-01-2013, 12:15 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Bypass LPF on the sub amp. Keep it on max available setting on the sub and control bass management from AVR only. Just a thought.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 17 Old 12-02-2013, 11:52 AM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
You have to excuse my ignorance, but how do I bypass the LPF on the SUB amp?
Second, I assume max setting it max volume and then controlling the bass from the AVR refers to the dB level setting, +1, -2, etc.?
post #4 of 17 Old 12-02-2013, 12:53 PM
eljaycanuck's Avatar
Quoted: 1225 Post(s)
Liked: 1794
... how do I bypass the LPF on the SUB amp?
The amps on some subwoofers have a "disable" or "bypass" switch for the LPF. If your subwoofer's amp doesn't have one, just max out the LPF (crank the knob fully clockwise). That will effectively disable it.
Set the LPF - not the gain ("volume") - on the sub to max.
Set the gain on the sub to around "noon" and calibrate. If the sub's level ("volume") in your AVR's speaker set-up menu is too high, raise the gain on the sub; if it's too low, lower the gain on the sub. Re-calibrate.
Repeat until you have a sub level that is close to the levels of the speakers (erring on the side of a bit lower than the levels of the speakers).
From that point on, adjust the level of the sub in the AVR's speaker set-up menu (not on the sub itself).
eljaycanuck is online now
post #5 of 17 Old 12-02-2013, 12:56 PM
Alan P's Avatar
Quoted: 4694 Post(s)
Liked: 3321
So this was NOT happening before....just started recently? And nothing in your system has changed? Have you tried a different sub cable?
To answer a couple of your questions:
Yes, your crossovers should be set to 80hz (the 120hz you probably saw mentioned is in reference to the "LPF for LFE" setting, something completely different), unless Audyssey set them higher. Never lower a crossover that Audyssey set....however, it is fine to raise them to 80hz if Audyssey sets them lower.
Do not set the gain on your sub to max...you should set it to wherever Audyssey calibrates it closest to 0db...typically this is around 1 o'clock, but can vary greatly from sub to sub.
Alan P is offline
post #6 of 17 Old 12-02-2013, 01:22 PM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
I see I have some work to do. I will need to take a closer look at the sub amp, check what options are there. At that point I will go back into the AVR and report my findings.
As far as things changing, the only thing I did recently was change LPF of LFE from 120 to 80Hz. Thought I mentioned it in the OP, but after a quick glance maybe not. I was reading in someone else's post and they mentioned this change. But that was at least 2 months ago so i am surprised I would not have noticed this sooner?
Would it also be suggested to go through an Audyssey calibration again?
post #7 of 17 Old 12-02-2013, 04:05 PM
Alan P's Avatar
Liked: 3321
Changing the LPF to 80hz should not cause the symptoms your describing, but you should leave it at 120hz all the same.
If you've made any changes to the sub gain (on the sub), then yes, you need to re-run Audyssey.
Alan P is offline
post #8 of 17 Old 12-02-2013, 08:13 PM
Quoted: 311 Post(s)
Liked: 273
You have two LPF engaged causing cascading effect, which will yield low bass around the crossover. Keep LPF at max on sub and control bass management from avr only.
post #9 of 17 Old 12-03-2013, 09:41 AM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
to make life simple, this is the back of my SVS sub amp
Sonic filter is set based on instruction for having none of the port plugs in place.
To confirm, Crossover switch is in the disabled position
The one thing that does appear potentially off is the phase not being at 0...kids... take a look, let me know
post #10 of 17 Old 12-03-2013, 10:48 AM
Alan P's Avatar
Liked: 3321
If you have no way to measure your room (REW, OmniMic, etc.) than I would recommend you leave the phase at 0.
Alan P is offline
post #11 of 17 Old 12-03-2013, 11:14 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
How does it sound on troublesome content with the sub turned off? At 80 Hz, at least to me, the term "muffled" would not apply. You're about a third of an octave above where a lot of engineers/mixers bump up the kick drum for that "hit you in the chest" feeling (60 Hz, although some like 50 Hz). Static/muffling, to me, would be way higher in the frequency range. But of course we're in an arena where individual "definitions" of slippery terms create difficulties in communication.
I do agree that if something seems missing, eliminating double low pass filters could absolutely help.
I suppose another possibility is that you are overloading the input stage of the sub, causing distortion that would indeed get far higher in frequency. If your AVR's sub output is far into the "+" range, turn up the sub's gain control, and recalibrate with a lower AVR output level.
Just a semiuseless WAG . . .
JHAz is offline
post #12 of 17 Old 12-05-2013, 10:49 PM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
Ok, so I finally managed to get in the basement again. Seems like the issue is not static, so let's eliminate that from the discussion. Instead it is best described as muffled. Almost like If you are talking and put your hand over your mouth.
So it is like non bass/sub stuff is sent to the sub. I say this because tonight I was watching nhl 2night and the music during highlights was outputting muffled from the sub. Now, if there is something that is real bass, that works fine, the room shakes so in that sense the sub is Ok. Instead it just seems my onkyo is sending stuff to the sub that perhaps it shouldn't? Or is it the sub that should be like I am not playing that...
Now, at the same time this is not the exact same as was during the movie which was more like thunder in the distance, but I think it was similar. The sub outputting something that is not chest pumping bass so instead it just sounds bad. If that makes sense anyway...
post #13 of 17 Old 12-06-2013, 09:09 AM
Alan P's Avatar
Liked: 3321
Where are you speaker crossovers set in your AVR? Sounds to me like you have the crossovers set too high.
Alan P is offline
post #14 of 17 Old 12-06-2013, 04:29 PM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
If we are talking the same thing, 80hz across the board
post #15 of 17 Old 12-06-2013, 05:44 PM
Alan P's Avatar
Liked: 3321
Do you have the sub hooked to the sub out on your AVR?
Alan P is offline
post #16 of 17 Old 12-06-2013, 06:02 PM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
Yes. I believe it is called subwoofer preout
post #17 of 17 Old 12-06-2013, 08:14 PM - Thread Starter
smakovits's Avatar
Quoted: 30 Post(s)
digging around, may have found something. since I did change sub crossover from 120 to 80Hz, and before things were set from Audyssee, since I made this change I didnt re-calibrate so the Onkyo is not filtering correctly. Let me try to switch things back to 120 and see what happens and then report it back .
Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer
