Two Sub-Woofers and one 7.1 Receiver Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2013, 08:33 AM - Thread Starter
fatcat220's Avatar
I have Harmon Kardon 3650, which is 7.1 system. I bought a used Polk surround speaker set that included a powered sub-woofer. I already had a powered sub-woofer, but wanted the other speakers to upgrade my system. So now I've got an extra powered sub woofer and I've got a newbie question. Can I hook up my two sub-woofers in parallel so the one signal from my receiver drives both? Should I - does having the second sub-woofer buy me anything in sound quality? FYI, I can separate one sub-woofer toward the front of my room and place the second near the back. FYI, my room is octagonal shaped and it measures 19' from flat wall to t flat wall. Thanks.
fatcat220 is offline
post #2 of 4 Old 12-01-2013, 08:51 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4951 Post(s)
Liked: 8373
In most circumstances you will reap a benefit from using two subs. If they are relatively similar in capability, you definitely want to use them both. Positioning them for maximum effect is a bit of a complex issue. It'll help if you could post some info about both subs.
Mark Henninger
imagic is offline
post #3 of 4 Old 12-01-2013, 09:41 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
All you need is a Y cable like this. Most 7.2 receivers have an internal Y cable so it wouldn't be any different.
http://www.amazon.com/RCA-AH25-Y-Adaptor-Cable/dp/B00005T3G9/ref=sr_1_15?ie=UTF8&qid=1385915981&sr=8-15&keywords=subwoofer+Y+cable
Afro GT
afrogt is online now
post #4 of 4 Old 12-01-2013, 11:35 AM - Thread Starter
fatcat220's Avatar
Hi Guys, thanks for the help.
Imagic, I've got one Velodyne 10" VX-10B and one Polk 10" PSW10 sub-woofer. Both have low pass freq. adjustments (Velodyne:n50-200Hz, Polk: 80-160Hz), volume control, and a 0-180 phase toggle switch. Can you give me any guidance on setting the two up so the play nice with each other?
Afrogt, thanks for the Amazon link.
Harman Kardon Avr 3650 Audio Video Receiver , Polk Audio Psw10 10 Inch Monitor Series Powered Subwoofer Single Black
