1 sub or 2 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-01-2013, 10:00 AM - Thread Starter
greenpathy's Avatar
i really can't decide if i should run 2 subs (bic america f-12)  or just 1( bic accoustech pl200.)
my room size is 17x22 with 11' ceilings...   my fronts are infinity beta 50's.. they have (2) 8" subs per side, but still feel better asking folks up hear.  any help would be greatly appreciated.
greenpathy is offline
post #2 of 8 Old 12-01-2013, 10:39 AM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
IMO, go duals, but also consider buying better subs. Example: Get an SVS PB-1000 now, add another one later on. They're $499, shipped, and SVS offers free return shipping within 45 days.
eljaycanuck is offline
post #3 of 8 Old 12-01-2013, 10:51 AM
Mark Henninger
imagic's Avatar
Quoted: 6469 Post(s)
Liked: 11216
In a choice between two lesser subs and one better sub, I'm biased towards buying the better sub. The PL-200 sure gets a lot of love in the AVS Forum review section.
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #4 of 8 Old 12-01-2013, 10:54 AM - Thread Starter
greenpathy's Avatar
reason i was going with bic was money, more less, the price of 2 f-12's was almost the same as 1 pl200...thats the real reason, i'm sure i can fork over a little more for 1 better sub, but its really going to be pushing it, this close to the holiday season ya know..
post #5 of 8 Old 12-01-2013, 02:36 PM
Hopinater's Avatar
Quoted: 2286 Post(s)
Liked: 5685
I would buy the better sub to start. But going duals is usually recommended so I buy the first one (of the better subs) and then I would save up for a while and buy a 2nd. Then in a year or so you will have dual subs for smoother bass and they will be good subs.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is online now
post #6 of 8 Old 12-01-2013, 03:23 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
Agree... I would start with 1 of the "better" model, then save up for a second.
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #7 of 8 Old 12-01-2013, 04:55 PM
Bill Fitzmaurice's Avatar
Liked: 5684
Define 'better'. If that means lower extension that is better, but if it means louder that's not necessarily better. Two subs will go 6dB louder than one, so you really can quantify the dBs per dollar, if you have actual measured output capabilities, such as those shown at data-bass.com. Given the smoother room response that two subs have I'd say that's worth a couple more dB in what two will do compared to one.
Bill Fitzmaurice is offline
post #8 of 8 Old 12-01-2013, 05:26 PM - Thread Starter
greenpathy's Avatar
ok 2 it is then, thank you all for your help with this.
