bass managment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-02-2013, 05:34 AM - Thread Starter
half-pants's Avatar
Sooru I'm a noob my subwoofer is not a great one but its not in the budget for a new one right now any sugestions on settings to help take some of the load off the sub
half-pants is offline
post #2 of 9 Old 12-02-2013, 05:39 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
Without knowing the make and model of your sub, your speakers or your AVR, I'll suggest you set the crossover in your AVR's speaker set-up menu to 80Hz for all channels (except the LPF of LFE - leave that at 120Hz).
eljaycanuck is offline
post #3 of 9 Old 12-02-2013, 06:26 AM - Thread Starter
half-pants's Avatar
Avr is denon 1315
Center and fronts are omage impact
Rears are polk audio m1
My sub is a powered pasive sub
8 inch speaker
post #4 of 9 Old 12-02-2013, 12:07 PM
Liked: 1798
I can't find anything useful on the Omage speakers. The Polks are rated to 85Hz @ -3dB. I would set the crossovers for all speakers to no lower than 100Hz - although, to be safe, 120Hz might be better.
Avr is denon 1315
Denon doesn't have an AVR-1315, although I do see a PMA-1315R. Perhaps you mean the AVR-1513?
If 'yes', go into the speaker set-up menu (see the manual for how to do this) and set the crossover levels for all speakers channels to 120Hz. If you also have the option to adjust the "LPF of LFE", make sure it's set to 120Hz. (If you don't have that option, don't worry about it - it's probably "hard-coded" to 120Hz anyway.)
A passive sub is basically just a box with a driver in it, powered by either an external amplifier or, in "budget" cases, by a powered subwoofer channel in an HTiB (home theater in a box) receiver. If your sub has a built-in amp - I suspect it does - it's an active sub.
post #5 of 9 Old 12-02-2013, 12:18 PM - Thread Starter
half-pants's Avatar
Sorry I meant I powered a passive sub and replaced the 6 inch speaker with a 8 inch speaker
post #6 of 9 Old 12-02-2013, 12:47 PM
Liked: 1798
post #7 of 9 Old 12-02-2013, 01:30 PM - Thread Starter
half-pants's Avatar
But it seems to sound loose
post #8 of 9 Old 12-02-2013, 01:36 PM
Liked: 1798
I'm not sure what that means. If your sub is not up to the task of being a sub, you need to consider replacing it. A well-rated and inexpensive option is the Dayton SUB-1200 from parts-express.com. It's currently on sale for $109, shipped.
post #9 of 9 Old 12-02-2013, 02:03 PM - Thread Starter
half-pants's Avatar
I'll take a look at it thanks
