Chase VS 18.1 Overkill? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-07-2013, 02:01 PM - Thread Starter
carter840's Avatar
Hi everyone ,
I am looking at purchasing a Chase Home Theater VS 18.1. I have read a lot of the reviews on this site and also spoken with Craig at Chase (he was very helpful). I was hoping to get some members opinions on whether this subwoofer is overkill in the room I am designing. In addition to having a 18" woofer the VS 18.1 also has an extra large cabinet. I do have room for this in my home theater, but I just want to make sure I'm not putting in something that is larger (and more expensive) then I need. I would also be getting an amplifier from Chase as part of the deal I believe it would be their Sub1 Amplifier.
The room is: 13'W x 22'L x 10'H
Speakers will be: ARX A5 (Front: L&R), ARX A2-C (Center), ARX A1b (Surrounds).
AVR: Denon X2000
From what I have read this subwoofer is a very good value and true performer. I just want to make sure I am not going overboard here. For instance if I have to set the subwoofer on minimum volume the whole time because it is too powerful I worry that I am paying for extra output power that I am not going to use , but obviously have the depth of low frequency will be advantageous.
I have heard a breakdown suggested of what portion of a budget one should spend on speakers, AVR, and Sub. Can someone remind me what a good breakdown is.
Thank you
carter840 is offline
post #2 of 11 Old 12-07-2013, 10:58 PM
Rowan611's Avatar
Quoted: 210 Post(s)
Liked: 233
Originally Posted by carter840 View Post
Hi everyone ,
AVR: Denon X2000
Thank you
You'll run Audyssey on the X2000 and it will set the 18.1 up for you. After that, you can manually adjust more or less bass through the receiver (I'd leave the amp volume alone). More is better. Trust me.
HT: Marantz 7702mkII | Crown Amps | Volt 8s | THTs | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
1299 build on standby
Rowan611 is offline
post #3 of 11 Old 12-08-2013, 04:49 AM
Bigotis's Avatar
Quoted: 18 Post(s)
Liked: 27
Bigger you can go initially the better. Many of us have spent thousands upgrading to be satisfied, I have. I've got 2 SS 18.2's and an amp on order from Chase, looking forward to hearing them.
Bigotis is offline
post #4 of 11 Old 12-08-2013, 06:28 AM
Quoted: 73 Post(s)
Liked: 112
Get the most you can afford.
rnatalli is offline
post #5 of 11 Old 12-08-2013, 08:38 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 913
Agreed.
Iv gone from a pro sub 600 to a lv12r to dual fv15hps
I'm very content with the dual fv15hps..
The only advice id have is to go duals.. even if it means buying 2 slightly smaller/cheaper subs and maybe raise total budget .
It will be worth it in the end IMO
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
post #6 of 11 Old 12-08-2013, 09:18 PM
Hopinater's Avatar
Quoted: 1779 Post(s)
Liked: 4382
^^^ This is good advice. The forums are littered with a lot of guys who have upgraded multiple times and wish they had just bought the right sub from the start.
As newc33 said, dual subs are usually considered better than running a single because it smooths out the bass across the listening positions.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #7 of 11 Old 12-08-2013, 09:25 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
It is not overkill since the room is long and you have a descent amount of space to fill. I have an SS 18.2 and a pair of stacked SS 18.1's. They are great subs. I power them with a Berhinger that will give you a lot more flexibility than the Dayton or Sub 1 amp. Either way, all should be good. Look at the Chase post on the Berhinger I Nuke DSP amps.
derrickdj1 is offline
post #8 of 11 Old 12-09-2013, 04:17 PM - Thread Starter
carter840's Avatar
I posted this in the chase owners thread too, but can you explain why I might want to go with these different amplifier? Will settuo be much more difficult and are you recomending the 3000 or the 6000?
post #9 of 11 Old 12-10-2013, 01:06 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
For one or two of the SS 18.1 or SV 18.1 subs the I Nuke 3000 DSP is enough. Check out the Chase forum for more info on the I Nuke.
post #10 of 11 Old 12-10-2013, 09:41 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
There is no such thing as overkill with sub's.
Reefdvr27 is offline
post #11 of 11 Old 12-10-2013, 10:41 AM
Gooddoc's Avatar
Quoted: 2672 Post(s)
Liked: 1845
Confucius Say,
Gooddoc is offline
Denon Avr X2000 7 1 Channel Home Theater Receiver
