Sound meter - AVS Forum | Home Theater Discussions And Reviews
Old 12-09-2013, 09:29 AM - Thread Starter
Ozzie Isaac's Avatar
Liked: 101
I'm looking into getting a sound meter. What SPL meters do you guys recommend? I would like something that provides weighted averages if possible.
Ozzie Isaac is online now
Old 12-09-2013, 09:41 AM
BeeMan458's Avatar
Liked: 813
The forum standard is the Radio Shack digital sound meter. I have and have used the Radio Shack sound meter for over ten years.
This is the one I use and love.
The only shortcoming is, the backlight will only stay on five seconds and you can't change the timer as we watch movies in the dark.
BeeMan458 is offline
Old 12-09-2013, 11:21 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4946 Post(s)
Liked: 8368
If you have an iPhone, iPad, or Android device, you could also look into buying a calibrated mic and using an app like Audio Tool. The key is to use a mic that has a calibration file, which you load into the app. Dayton makes one, the iMM-6, that is very economical yet accurate.
Mark Henninger
imagic is online now
Old 12-09-2013, 12:18 PM - Thread Starter
Liked: 101
Can the mic be used with REW and a laptop also?
Two birds with one stone would be great.
Old 12-09-2013, 12:31 PM
BeeMan458's Avatar
Liked: 813
If you get a USB microphone, the microphone marries up to the laptop and REW nicely.
Old 12-09-2013, 02:22 PM - Thread Starter
Liked: 101
Thanks for the input guys. I'll look into all three options. Standalone, mic input, and USB.
Old 12-09-2013, 02:34 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
I bought this one at my local Radio Shack as it was between this or an analog model.
http://www.amazon.com/Radio-Shack-Digital-Sound-Level/dp/B000A1EHGW
I also have a Dayton Omni mic, which thanks to Archara for tipping me off to it in the AVS classifieds.
http://www.parts-express.com/dayton-audio-omnimic-v2-precision-measurement-system--390-792
Reefdvr27 is offline
