I bought a new subwoofer. Giving it back and looking for a better - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 152 Old 01-16-2014, 04:38 PM
Bill Fitzmaurice's Avatar
Liked: 4635
Originally Posted by bear123 View Post
Pretty sure he stated 6 dB regardless of placement.  But since the FR will differ at the LP based on differing placement, it wont be an identical FR curve.  Therefore it is not an identical and excact 6 dB increase at every frequency.  It should end up being smoother, raising some of the low spots in the FR more than 6 dB(hence smoothing), but perhaps less in the peak FR of the single sub.  But average of 6dB.  So according to this, my previous understanding of the way running dual subs was incorrect, and placing them apart makes even more sense than i thought.
+1. You don't magically get more output from two subs mutually coupled than when they aren't. When you double the sub (or any speaker) count you double the total cone excursion. That gives a 6dB increase in output. When mutually coupled what you will get is 6dB at every frequency at every spot in the room. When separated the increase will vary depending on the listener's position. There will even be some spots where there will be a lower level, where the waves from the subs, direct or reflected, meet 180 degrees out of phase. That works in our favor when that happens in a spot where one sub alone has a response peak at that frequency.
audiofan1 likes this.
Bill Fitzmaurice is online now
post #152 of 152 Old 10-29-2014, 02:21 PM
asere's Avatar
Quoted: 1376 Post(s)
Liked: 261
I realize this thread is kinda old now but I own one DXD 12012 and it sounds really nice and it does pressurize my 5400cf room.
asere is online now
Ken Kreisel Dxd 12012 Subwoofer , Kreisel , Svs , Rythmik , Rythmik Audio , Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer , Svs Pb13 Ultra , Hsu Research , Jtr , Seaton Sound Submersive H P , Seaton Sound Submersive F2 , Seaton Sound
